RTEMS 6.3
| #define | __HAL_FLASH_SET_LATENCY(__LATENCY__) |
| Set the FLASH Latency. | |
| #define | __HAL_FLASH_GET_LATENCY() |
| Get the FLASH Latency. | |
| #define | __HAL_FLASH_ENABLE_IT_BANK1(__INTERRUPT__) |
| Enable the specified FLASH interrupt. | |
| #define | __HAL_FLASH_ENABLE_IT_BANK2(__INTERRUPT__) |
| #define | __HAL_FLASH_ENABLE_IT(__INTERRUPT__) |
| #define | __HAL_FLASH_DISABLE_IT_BANK1(__INTERRUPT__) |
| Disable the specified FLASH interrupt. | |
| #define | __HAL_FLASH_DISABLE_IT_BANK2(__INTERRUPT__) |
| #define | __HAL_FLASH_DISABLE_IT(__INTERRUPT__) |
| #define | __HAL_FLASH_GET_FLAG_BANK1(__FLAG__) |
| Checks whether the specified FLASH flag is set or not. | |
| #define | __HAL_FLASH_GET_FLAG_BANK2(__FLAG__) |
| #define | __HAL_FLASH_GET_FLAG(__FLAG__) |
| #define | __HAL_FLASH_CLEAR_FLAG_BANK1(__FLAG__) |
| Clear the specified FLASH flag. | |
| #define | __HAL_FLASH_CLEAR_FLAG_BANK2(__FLAG__) |
| #define | __HAL_FLASH_CLEAR_FLAG(__FLAG__) |
| #define __HAL_FLASH_CLEAR_FLAG | ( | __FLAG__ | ) |
| #define __HAL_FLASH_CLEAR_FLAG_BANK1 | ( | __FLAG__ | ) |
| __FLAG__ | specifies the FLASH flags to clear. In case of Bank 1, this parameter can be any combination of the following values:
| none |
| #define __HAL_FLASH_CLEAR_FLAG_BANK2 | ( | __FLAG__ | ) |
| #define __HAL_FLASH_DISABLE_IT | ( | __INTERRUPT__ | ) |
| #define __HAL_FLASH_DISABLE_IT_BANK1 | ( | __INTERRUPT__ | ) |
| __INTERRUPT__ | : FLASH interrupt In case of Bank 1 This parameter can be any combination of the following values:
| none |
| #define __HAL_FLASH_DISABLE_IT_BANK2 | ( | __INTERRUPT__ | ) |
| #define __HAL_FLASH_ENABLE_IT | ( | __INTERRUPT__ | ) |
| #define __HAL_FLASH_ENABLE_IT_BANK1 | ( | __INTERRUPT__ | ) |
| none |
| #define __HAL_FLASH_ENABLE_IT_BANK2 | ( | __INTERRUPT__ | ) |
| #define __HAL_FLASH_GET_FLAG | ( | __FLAG__ | ) |
| #define __HAL_FLASH_GET_FLAG_BANK1 | ( | __FLAG__ | ) |
| __FLAG__ | specifies the FLASH flag to check. In case of Bank 1 This parameter can be one of the following values :
| The | new state of FLASH_FLAG (SET or RESET). |
| #define __HAL_FLASH_GET_FLAG_BANK2 | ( | __FLAG__ | ) |
| #define __HAL_FLASH_GET_LATENCY | ( | ) |
| FLASH | Latency The value of this parameter depend on device used within the same series |
| #define __HAL_FLASH_SET_LATENCY | ( | __LATENCY__ | ) |
| __LATENCY__ | FLASH Latency The value of this parameter depend on device used within the same series |
| none |
