RTEMS 6.3
CTRL - Control Register | |
| #define | EWM_CTRL_EWMEN_MASK (0x1U) |
| #define | EWM_CTRL_EWMEN_SHIFT (0U) |
| #define | EWM_CTRL_EWMEN(x) |
| #define | EWM_CTRL_ASSIN_MASK (0x2U) |
| #define | EWM_CTRL_ASSIN_SHIFT (1U) |
| #define | EWM_CTRL_ASSIN(x) |
| #define | EWM_CTRL_INEN_MASK (0x4U) |
| #define | EWM_CTRL_INEN_SHIFT (2U) |
| #define | EWM_CTRL_INEN(x) |
| #define | EWM_CTRL_INTEN_MASK (0x8U) |
| #define | EWM_CTRL_INTEN_SHIFT (3U) |
| #define | EWM_CTRL_INTEN(x) |
SERV - Service Register | |
| #define | EWM_SERV_SERVICE_MASK (0xFFU) |
| #define | EWM_SERV_SERVICE_SHIFT (0U) |
| #define | EWM_SERV_SERVICE(x) |
CMPL - Compare Low Register | |
| #define | EWM_CMPL_COMPAREL_MASK (0xFFU) |
| #define | EWM_CMPL_COMPAREL_SHIFT (0U) |
| #define | EWM_CMPL_COMPAREL(x) |
CMPH - Compare High Register | |
| #define | EWM_CMPH_COMPAREH_MASK (0xFFU) |
| #define | EWM_CMPH_COMPAREH_SHIFT (0U) |
| #define | EWM_CMPH_COMPAREH(x) |
CLKCTRL - Clock Control Register | |
| #define | EWM_CLKCTRL_CLKSEL_MASK (0x3U) |
| #define | EWM_CLKCTRL_CLKSEL_SHIFT (0U) |
| #define | EWM_CLKCTRL_CLKSEL(x) |
CLKPRESCALER - Clock Prescaler Register | |
| #define | EWM_CLKPRESCALER_CLK_DIV_MASK (0xFFU) |
| #define | EWM_CLKPRESCALER_CLK_DIV_SHIFT (0U) |
| #define | EWM_CLKPRESCALER_CLK_DIV(x) |
| #define EWM_CLKCTRL_CLKSEL | ( | x | ) |
CLKSEL - CLKSEL
CLKSEL - CLKSEL
CLKSEL - CLKSEL
| #define EWM_CLKPRESCALER_CLK_DIV | ( | x | ) |
CLK_DIV - CLK_DIV
CLK_DIV - CLK_DIV
CLK_DIV - CLK_DIV
| #define EWM_CMPH_COMPAREH | ( | x | ) |
COMPAREH - COMPAREH
COMPAREH - COMPAREH
COMPAREH - COMPAREH
| #define EWM_CMPL_COMPAREL | ( | x | ) |
COMPAREL - COMPAREL
COMPAREL - COMPAREL
COMPAREL - COMPAREL
| #define EWM_CTRL_ASSIN | ( | x | ) |
ASSIN - EWM_in's Assertion State Select.
ASSIN - EWM_in's Assertion State Select. 0b0..Default assert state of the EWM_in signal. 0b1..Inverts the assert state of EWM_in signal.
| #define EWM_CTRL_EWMEN | ( | x | ) |
EWMEN - EWM enable.
EWMEN - EWM enable. 0b0..EWM module is disabled. 0b1..EWM module is enabled.
| #define EWM_CTRL_INEN | ( | x | ) |
INEN - Input Enable.
INEN - Input Enable. 0b0..EWM_in port is disabled. 0b1..EWM_in port is enabled.
| #define EWM_CTRL_INTEN | ( | x | ) |
INTEN - Interrupt Enable.
INTEN - Interrupt Enable. 0b1..Generates an interrupt request, when EWM_OUT_b is asserted. 0b0..Deasserts the interrupt request.
| #define EWM_SERV_SERVICE | ( | x | ) |
SERVICE - SERVICE
SERVICE - SERVICE
SERVICE - SERVICE
