RTEMS 6.3
#define ALT_DMA_CCR_OPT_SAF   (0 << 0)
#define ALT_DMA_CCR_OPT_SAI   (1 << 0)
#define ALT_DMA_CCR_OPT_SA_DEFAULT   ALT_DMA_CCR_OPT_SAI
#define ALT_DMA_CCR_OPT_SS8   (0 << 1)
#define ALT_DMA_CCR_OPT_SS16   (1 << 1)
#define ALT_DMA_CCR_OPT_SS32   (2 << 1)
#define ALT_DMA_CCR_OPT_SS64   (3 << 1)
#define ALT_DMA_CCR_OPT_SS128   (4 << 1)
#define ALT_DMA_CCR_OPT_SS_DEFAULT   ALT_DMA_CCR_OPT_SS8
#define ALT_DMA_CCR_OPT_SB1   (0x0 << 4)
#define ALT_DMA_CCR_OPT_SB2   (0x1 << 4)
#define ALT_DMA_CCR_OPT_SB3   (0x2 << 4)
#define ALT_DMA_CCR_OPT_SB4   (0x3 << 4)
#define ALT_DMA_CCR_OPT_SB5   (0x4 << 4)
#define ALT_DMA_CCR_OPT_SB6   (0x5 << 4)
#define ALT_DMA_CCR_OPT_SB7   (0x6 << 4)
#define ALT_DMA_CCR_OPT_SB8   (0x7 << 4)
#define ALT_DMA_CCR_OPT_SB9   (0x8 << 4)
#define ALT_DMA_CCR_OPT_SB10   (0x9 << 4)
#define ALT_DMA_CCR_OPT_SB11   (0xa << 4)
#define ALT_DMA_CCR_OPT_SB12   (0xb << 4)
#define ALT_DMA_CCR_OPT_SB13   (0xc << 4)
#define ALT_DMA_CCR_OPT_SB14   (0xd << 4)
#define ALT_DMA_CCR_OPT_SB15   (0xe << 4)
#define ALT_DMA_CCR_OPT_SB16   (0xf << 4)
#define ALT_DMA_CCR_OPT_SB_DEFAULT   ALT_DMA_CCR_OPT_SB1
#define ALT_DMA_CCR_OPT_SP(imm3)
#define ALT_DMA_CCR_OPT_SP_DEFAULT   ALT_DMA_CCR_OPT_SP(0)
#define ALT_DMA_CCR_OPT_SC(imm4)
#define ALT_DMA_CCR_OPT_SC_DEFAULT   ALT_DMA_CCR_OPT_SC(0)
#define ALT_DMA_CCR_OPT_DAF   (0 << 14)
#define ALT_DMA_CCR_OPT_DAI   (1 << 14)
#define ALT_DMA_CCR_OPT_DA_DEFAULT   ALT_DMA_CCR_OPT_DAI
#define ALT_DMA_CCR_OPT_DS8   (0 << 15)
#define ALT_DMA_CCR_OPT_DS16   (1 << 15)
#define ALT_DMA_CCR_OPT_DS32   (2 << 15)
#define ALT_DMA_CCR_OPT_DS64   (3 << 15)
#define ALT_DMA_CCR_OPT_DS128   (4 << 15)
#define ALT_DMA_CCR_OPT_DS_DEFAULT   ALT_DMA_CCR_OPT_DS8
#define ALT_DMA_CCR_OPT_DB1   (0x0 << 18)
#define ALT_DMA_CCR_OPT_DB2   (0x1 << 18)
#define ALT_DMA_CCR_OPT_DB3   (0x2 << 18)
#define ALT_DMA_CCR_OPT_DB4   (0x3 << 18)
#define ALT_DMA_CCR_OPT_DB5   (0x4 << 18)
#define ALT_DMA_CCR_OPT_DB6   (0x5 << 18)
#define ALT_DMA_CCR_OPT_DB7   (0x6 << 18)
#define ALT_DMA_CCR_OPT_DB8   (0x7 << 18)
#define ALT_DMA_CCR_OPT_DB9   (0x8 << 18)
#define ALT_DMA_CCR_OPT_DB10   (0x9 << 18)
#define ALT_DMA_CCR_OPT_DB11   (0xa << 18)
#define ALT_DMA_CCR_OPT_DB12   (0xb << 18)
#define ALT_DMA_CCR_OPT_DB13   (0xc << 18)
#define ALT_DMA_CCR_OPT_DB14   (0xd << 18)
#define ALT_DMA_CCR_OPT_DB15   (0xe << 18)
#define ALT_DMA_CCR_OPT_DB16   (0xf << 18)
#define ALT_DMA_CCR_OPT_DB_DEFAULT   ALT_DMA_CCR_OPT_DB1
#define ALT_DMA_CCR_OPT_DP(imm3)
#define ALT_DMA_CCR_OPT_DP_DEFAULT   ALT_DMA_CCR_OPT_DP(0)
#define ALT_DMA_CCR_OPT_DC(imm4)
#define ALT_DMA_CCR_OPT_DC_DEFAULT   ALT_DMA_CCR_OPT_DC(0)
#define ALT_DMA_CCR_OPT_ES8   (0 << 28)
#define ALT_DMA_CCR_OPT_ES16   (1 << 28)
#define ALT_DMA_CCR_OPT_ES32   (2 << 28)
#define ALT_DMA_CCR_OPT_ES64   (3 << 28)
#define ALT_DMA_CCR_OPT_ES128   (4 << 28)
#define ALT_DMA_CCR_OPT_ES_DEFAULT   ALT_DMA_CCR_OPT_ES8
#define ALT_DMA_CCR_OPT_DEFAULT
The ALT_DMA_CCR_OPT_* macro definitions are defined here to facilitate the dynamic microcode programming of the assembler directive:
DMAMOV CCR, [SB<1-16>] [SS<8|16|32|64|128>] [SA<I|F>]
            [SP<imm3>] [SC<imm4>]
            [DB<1-16>] [DS<8|16|32|64|128>] [DA<I|F>]
            [DP<imm3>] [DC<imm4>]
            [ES<8|16|32|64|128>]
with a DMAMOV instruction (see: alt_dma_program_DMAMOV()).
For example the assembler directive:
DMAMOV CCR SB1 SS32 DB1 DS32
would be dynamically programmed with the following API call:
alt_dma_program_DMAMOV( pgm,
                        ALT_DMA_PROGRAM_REG_CCR,
                        (   ALT_DMA_CCR_OPT_SB1
                          | ALT_DMA_CCR_OPT_DB1
                          | ALT_DMA_CCR_OPT_ES8
Each CCR option category should be specified regardless of whether it specifies a custom value or the normal default value (i.e. an ALT_DMA_CCR_OPT_*_DEFAULT.
◆ ALT_DMA_CCR_OPT_DA_DEFAULT
Destination Address Default value.
◆ ALT_DMA_CCR_OPT_DAF
Destination Address Fixed address burst.
◆ ALT_DMA_CCR_OPT_DAI
Destination Address Incrementing address burst.
◆ ALT_DMA_CCR_OPT_DB1
Destination Burst length of 1 transfer.
◆ ALT_DMA_CCR_OPT_DB10
Destination Burst length of 10 transfers.
◆ ALT_DMA_CCR_OPT_DB11
Destination Burst length of 11 transfers.
◆ ALT_DMA_CCR_OPT_DB12
Destination Burst length of 12 transfers.
◆ ALT_DMA_CCR_OPT_DB13
Destination Burst length of 13 transfers.
◆ ALT_DMA_CCR_OPT_DB14
Destination Burst length of 14 transfers.
◆ ALT_DMA_CCR_OPT_DB15
Destination Burst length of 15 transfers.
◆ ALT_DMA_CCR_OPT_DB16
Destination Burst length of 16 transfers.
◆ ALT_DMA_CCR_OPT_DB2
Destination Burst length of 2 transfers.
◆ ALT_DMA_CCR_OPT_DB3
Destination Burst length of 3 transfers.
◆ ALT_DMA_CCR_OPT_DB4
Destination Burst length of 4 transfers.
◆ ALT_DMA_CCR_OPT_DB5
Destination Burst length of 5 transfers.
◆ ALT_DMA_CCR_OPT_DB6
Destination Burst length of 6 transfers.
◆ ALT_DMA_CCR_OPT_DB7
Destination Burst length of 7 transfers.
◆ ALT_DMA_CCR_OPT_DB8
Destination Burst length of 8 transfers.
◆ ALT_DMA_CCR_OPT_DB9
Destination Burst length of 9 transfers.
◆ ALT_DMA_CCR_OPT_DB_DEFAULT
Destination Burst length default transfers.
◆ ALT_DMA_CCR_OPT_DC
#define ALT_DMA_CCR_OPT_DC ( imm4)
Value:
((imm4) << 25)
Destination Cache bits for AXI bus AWCACHE[3,1:0].
◆ ALT_DMA_CCR_OPT_DC_DEFAULT
Destination Cache bits default value.
◆ ALT_DMA_CCR_OPT_DEFAULT
Value:
ALT_DMA_CCR_OPT_SP(0) | ALT_DMA_CCR_OPT_SC(0) | \
ALT_DMA_CCR_OPT_DP(0) | ALT_DMA_CCR_OPT_DC(0) | \
Definition alt_dma_program.h:855
Definition alt_dma_program.h:917
Definition alt_dma_program.h:767
Definition alt_dma_program.h:837
Definition alt_dma_program.h:847
Definition alt_dma_program.h:791
Definition alt_dma_program.h:925
Definition alt_dma_program.h:871
Definition alt_dma_program.h:775
Default CCR register options for a DMAMOV CCR assembler directive.
◆ ALT_DMA_CCR_OPT_DP
#define ALT_DMA_CCR_OPT_DP ( imm3)
Value:
((imm3) << 22)
Destination Protection bits for AXI bus AWPROT[2:0].
◆ ALT_DMA_CCR_OPT_DP_DEFAULT
Destination Protection bits default value.
◆ ALT_DMA_CCR_OPT_DS128
Destination burst Size of 128 bits.
◆ ALT_DMA_CCR_OPT_DS16
Destination burst Size of 16 bits.
◆ ALT_DMA_CCR_OPT_DS32
Destination burst Size of 32 bits.
◆ ALT_DMA_CCR_OPT_DS64
Destination burst Size of 64 bits.
◆ ALT_DMA_CCR_OPT_DS8
Destination burst Size of 8 bits.
◆ ALT_DMA_CCR_OPT_DS_DEFAULT
Destination burst Size default bits.
◆ ALT_DMA_CCR_OPT_ES128
Endian Swap: Swap bytes within 128-bit data.
◆ ALT_DMA_CCR_OPT_ES16
Endian Swap: Swap bytes within 16-bit data.
◆ ALT_DMA_CCR_OPT_ES32
Endian Swap: Swap bytes within 32-bit data.
◆ ALT_DMA_CCR_OPT_ES64
Endian Swap: Swap bytes within 64-bit data.
◆ ALT_DMA_CCR_OPT_ES8
Endian Swap: No swap, 8-bit data.
◆ ALT_DMA_CCR_OPT_ES_DEFAULT
Endian Swap: Default byte swap.
◆ ALT_DMA_CCR_OPT_SA_DEFAULT
Source Address Default value.
◆ ALT_DMA_CCR_OPT_SAF
Source Address Fixed address burst.
◆ ALT_DMA_CCR_OPT_SAI
Source Address Incrementing address burst.
◆ ALT_DMA_CCR_OPT_SB1
Source Burst length of 1 transfer.
◆ ALT_DMA_CCR_OPT_SB10
Source Burst length of 10 transfers.
◆ ALT_DMA_CCR_OPT_SB11
Source Burst length of 11 transfers.
◆ ALT_DMA_CCR_OPT_SB12
Source Burst length of 12 transfers.
◆ ALT_DMA_CCR_OPT_SB13
Source Burst length of 13 transfers.
◆ ALT_DMA_CCR_OPT_SB14
Source Burst length of 14 transfers.
◆ ALT_DMA_CCR_OPT_SB15
Source Burst length of 15 transfers.
◆ ALT_DMA_CCR_OPT_SB16
Source Burst length of 16 transfers.
◆ ALT_DMA_CCR_OPT_SB2
Source Burst length of 2 transfers.
◆ ALT_DMA_CCR_OPT_SB3
Source Burst length of 3 transfers.
◆ ALT_DMA_CCR_OPT_SB4
Source Burst length of 4 transfers.
◆ ALT_DMA_CCR_OPT_SB5
Source Burst length of 5 transfers.
◆ ALT_DMA_CCR_OPT_SB6
Source Burst length of 6 transfers.
◆ ALT_DMA_CCR_OPT_SB7
Source Burst length of 7 transfers.
◆ ALT_DMA_CCR_OPT_SB8
Source Burst length of 8 transfers.
◆ ALT_DMA_CCR_OPT_SB9
Source Burst length of 9 transfers.
◆ ALT_DMA_CCR_OPT_SB_DEFAULT
Source Burst length default transfers.
◆ ALT_DMA_CCR_OPT_SC
#define ALT_DMA_CCR_OPT_SC ( imm4)
Value:
((imm4) << 11)
Source Cache bits for AXI bus ARCACHE[2:0].
◆ ALT_DMA_CCR_OPT_SC_DEFAULT
Source Cache bits default value.
◆ ALT_DMA_CCR_OPT_SP
#define ALT_DMA_CCR_OPT_SP ( imm3)
Value:
((imm3) << 8)
Source Protection bits for AXI bus ARPROT[2:0].
◆ ALT_DMA_CCR_OPT_SP_DEFAULT
Source Protection bits default value.
◆ ALT_DMA_CCR_OPT_SS128
Source burst Size of 128 bits.
◆ ALT_DMA_CCR_OPT_SS16
Source burst Size of 16 bits.
◆ ALT_DMA_CCR_OPT_SS32
Source burst Size of 32 bits.
◆ ALT_DMA_CCR_OPT_SS64
Source burst Size of 64 bits.
◆ ALT_DMA_CCR_OPT_SS8
Source burst Size of 8 bits.
◆ ALT_DMA_CCR_OPT_SS_DEFAULT
Source burst Size default bits.
