RTEMS 6.3
CRC Extended Exported Macros
#define __HAL_CRC_OUTPUTREVERSAL_ENABLE(__HANDLE__)
 Set CRC output reversal.
#define __HAL_CRC_OUTPUTREVERSAL_DISABLE(__HANDLE__)
 Unset CRC output reversal.
#define __HAL_CRC_POLYNOMIAL_CONFIG(__HANDLE__, __POLYNOMIAL__)
 Set CRC non-default polynomial.
◆ __HAL_CRC_OUTPUTREVERSAL_DISABLE
#define __HAL_CRC_OUTPUTREVERSAL_DISABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT))
#define CRC_CR_REV_OUT
Definition stm32h723xx.h:5791
Parameters
__HANDLE__CRC handle
Return values
None
◆ __HAL_CRC_OUTPUTREVERSAL_ENABLE
#define __HAL_CRC_OUTPUTREVERSAL_ENABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT)
Parameters
Return values
None
◆ __HAL_CRC_POLYNOMIAL_CONFIG
#define __HAL_CRC_POLYNOMIAL_CONFIG ( __HANDLE__,
__POLYNOMIAL__ )
Value:
((__HANDLE__)->Instance->POL = (__POLYNOMIAL__))
Parameters
__POLYNOMIAL__7, 8, 16 or 32-bit polynomial
Return values
None
