RTEMS 6.3
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_RISING_EDGE() |
| Enable the COMP1 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_RISING_EDGE() |
| Disable the COMP1 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_FALLING_EDGE() |
| Enable the COMP1 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_FALLING_EDGE() |
| Disable the COMP1 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable the COMP1 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable the COMP1 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_IT() |
| Enable the COMP1 EXTI line in interrupt mode. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_IT() |
| Disable the COMP1 EXTI line in interrupt mode. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_EVENT() |
| Enable the COMP1 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_EVENT() |
| Disable the COMP1 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP1_EXTI_GET_FLAG() |
| Check whether the COMP1 EXTI line flag is set or not. | |
| #define | __HAL_COMP_COMP1_EXTI_CLEAR_FLAG() |
| Clear the COMP1 EXTI flag. | |
| #define | __HAL_COMP_COMP1_EXTI_GENERATE_SWIT() |
| Generate a software interrupt on the COMP1 EXTI line. | |
| #define | __HAL_COMP_COMP1_EXTID3_ENABLE_EVENT() |
| Enable the COMP1 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP1_EXTID3_DISABLE_EVENT() |
| Disable the COMP1 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_RISING_EDGE() |
| Enable the COMP2 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_RISING_EDGE() |
| Disable the COMP2 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_FALLING_EDGE() |
| Enable the COMP2 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_FALLING_EDGE() |
| Disable the COMP2 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable the COMP2 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable the COMP2 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_IT() |
| Enable the COMP2 EXTI line. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_IT() |
| Disable the COMP2 EXTI line. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_EVENT() |
| Enable the COMP2 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_EVENT() |
| Disable the COMP2 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_GET_FLAG() |
| Check whether the COMP2 EXTI line flag is set or not. | |
| #define | __HAL_COMP_COMP2_EXTI_CLEAR_FLAG() |
| Clear the the COMP2 EXTI flag. | |
| #define | __HAL_COMP_COMP2_EXTID3_ENABLE_EVENT() |
| Enable the COMP2 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTID3_DISABLE_EVENT() |
| Disable the COMP2 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_GENERATE_SWIT() |
| Generate a software interrupt on the COMP2 EXTI line. | |
| #define | __HAL_COMP_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Checks if the specified COMP interrupt source is enabled or disabled. | |
| #define | __HAL_COMP_GET_FLAG(__FLAG__) |
| Checks whether the specified COMP flag is set or not. | |
| #define | __HAL_COMP_CLEAR_FLAG(__FLAG__) |
| Clears the specified COMP pending flag. | |
| #define | __HAL_COMP_CLEAR_C1IFLAG() |
| Clear the COMP C1I flag. | |
| #define | __HAL_COMP_CLEAR_C2IFLAG() |
| Clear the COMP C2I flag. | |
| #define | __HAL_COMP_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified COMP interrupt. | |
| #define | __HAL_COMP_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified COMP interrupt. | |
| #define __HAL_COMP_CLEAR_C1IFLAG | ( | ) |
| None |
| #define __HAL_COMP_CLEAR_C2IFLAG | ( | ) |
| None |
| #define __HAL_COMP_CLEAR_FLAG | ( | __FLAG__ | ) |
| __FLAG__ | specifies the flag to check. This parameter can be any combination of the following values:
| None |
| #define __HAL_COMP_COMP1_EXTI_CLEAR_FLAG | ( | ) |
| #define __HAL_COMP_COMP1_EXTI_DISABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_DISABLE_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_DISABLE_IT | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_DISABLE_RISING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_DISABLE_RISING_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_ENABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_ENABLE_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_ENABLE_IT | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_ENABLE_RISING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_ENABLE_RISING_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_GENERATE_SWIT | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTI_GET_FLAG | ( | ) |
| RESET | or SET |
| #define __HAL_COMP_COMP1_EXTID3_DISABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP1_EXTID3_ENABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_CLEAR_FLAG | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_DISABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_DISABLE_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_DISABLE_IT | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_DISABLE_RISING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_DISABLE_RISING_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_ENABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_ENABLE_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_ENABLE_IT | ( | ) |
| #define __HAL_COMP_COMP2_EXTI_ENABLE_RISING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_ENABLE_RISING_FALLING_EDGE | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_GENERATE_SWIT | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTI_GET_FLAG | ( | ) |
| RESET | or SET |
| #define __HAL_COMP_COMP2_EXTID3_DISABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_COMP2_EXTID3_ENABLE_EVENT | ( | ) |
| None |
| #define __HAL_COMP_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ ) |
| __HANDLE__ | specifies the COMP Handle. |
| __INTERRUPT__ | specifies the COMP interrupt source to enable. This parameter can be one of the following values:
| None |
| #define __HAL_COMP_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ ) |
| None |
| #define __HAL_COMP_GET_FLAG | ( | __FLAG__ | ) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of FLAG (TRUE or FALSE) |
| #define __HAL_COMP_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ ) |
| __HANDLE__ | specifies the COMP Handle. This parameter can be COMP1 where x: 1 or 2 to select the COMP peripheral. |
| __INTERRUPT__ | specifies the COMP interrupt source to check. This parameter can be one of the following values:
| The | new state of IT (TRUE or FALSE) |
