RTEMS 6.3
typedef enum ALT_CLK_PLL_LOCK_STATUS_e ALT_CLK_PLL_LOCK_STATUS_t
enum  ALT_CLK_PLL_LOCK_STATUS_e {
  ALT_MAIN_PLL_LOCK_ACHV = 0x00000001 , ALT_PERIPH_PLL_LOCK_ACHV = 0x00000002 , ALT_SDR_PLL_LOCK_ACHV = 0x00000004 , ALT_MAIN_PLL_LOCK_LOST = 0x00000008 ,
  ALT_PERIPH_PLL_LOCK_LOST = 0x00000010 , ALT_SDR_PLL_LOCK_LOST = 0x00000020
ALT_STATUS_CODE alt_clk_lock_status_clear (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask)
uint32_t alt_clk_lock_status_get (void)
ALT_STATUS_CODE alt_clk_pll_is_locked (ALT_CLK_t pll)
This functional group provides status information on various aspects and properties of the Clock Manager state.
Typedef Documentation
◆ ALT_CLK_PLL_LOCK_STATUS_t
This type definition defines the lock condition status codes for each of the PLLs. If the PLL lock status condition is enabled (See: alt_clk_irq_enable()) then it contributes to the overall clkmgr_IRQ signal assertion state.
◆ ALT_CLK_PLL_LOCK_STATUS_e
This condition is set if the Main PLL has achieved lock at least once since this condition was last cleared.
This condition is set if the Peripheral PLL has achieved lock at least once since this condition was last cleared.
This condition is set if the SDRAM PLL has achieved lock at least once since this condition was last cleared.
This condition is set if the Main PLL has lost lock at least once since this condition was last cleared.
This condition is set if the Peripheral PLL has lost lock at least once since this condition was last cleared.
This condition is set if the SDRAM PLL has lost lock at least once since this condition was last cleared.
◆ alt_clk_lock_status_clear()
ALT_STATUS_CODE alt_clk_lock_status_clear ( ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask)
Clear the selected PLL lock status conditions.
This function clears assertions of one or more of the PLL lock status conditions.
NOTE: This function is used to clear clkmgr_IRQ interrupt signal source assertion conditions.
Parameters
lock_stat_maskSpecifies the PLL lock status conditions to clear. lock_stat_mask is a mask of logically OR'ed ALT_CLK_PLL_LOCK_STATUS_t values designating the PLL lock conditions to clear.
Return values
ALT_E_SUCCESSSuccessful status.
ALT_E_BAD_ARGThe lock_stat_mask argument contains an unknown condition value.
◆ alt_clk_lock_status_get()
uint32_t alt_clk_lock_status_get ( void )
Returns the PLL lock status condition values.
This function returns the value of the PLL lock status conditions.
Returns
The current values of the PLL lock status conditions as defined by the ALT_CLK_PLL_LOCK_STATUS_t mask bits. If the corresponding bit is set then the condition is asserted.
◆ alt_clk_pll_is_locked()
ALT_STATUS_CODE alt_clk_pll_is_locked ( ALT_CLK_t pll)
Returns ALT_E_TRUE if the designated PLL is currently locked and ALT_E_FALSE otherwise.
Parameters
pllThe PLL to return the lock status of.
Return values
ALT_E_TRUEThe specified PLL is currently locked.
ALT_E_FALSEThe specified PLL is currently not locked.
ALT_E_BAD_ARGThe pll argument designates a non PLL clock value.
