RTEMS 6.3
Macros for use with bit field definitions (xxx_SHIFT, xxx_MASK).
#define NXP_VAL2FLD(field, value)
 Mask and left-shift a bit field value for use in a register bit range.
#define NXP_FLD2VAL(field, value)
 Mask and right-shift a register value to extract a bit field value.
◆ NXP_FLD2VAL [1/3]
#define NXP_FLD2VAL ( field,
value )
Value:
(((value) & (field ## _MASK)) >> (field ## _SHIFT))
Parameters
fieldName of the register bit field.
valueValue of the register.
Returns
Masked and shifted bit field value.
◆ NXP_FLD2VAL [2/3]
value )
Value:
Parameters
Returns
◆ NXP_FLD2VAL [3/3]
value )
Value:
Parameters
Returns
◆ NXP_VAL2FLD [1/3]
#define NXP_VAL2FLD ( field,
value )
Value:
(((value) << (field ## _SHIFT)) & (field ## _MASK))
Parameters
valueValue of the bit field.
Returns
Masked and shifted value.
◆ NXP_VAL2FLD [2/3]
value )
Value:
Parameters
Returns
◆ NXP_VAL2FLD [3/3]
value )
Value:
Parameters
Returns
