RTEMS 6.3
Tests the effect of application configuration options. More...
file  testsuites/validation/tc-acfg-one-cpu.c
void __real__Scheduler_priority_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
void __wrap__Scheduler_priority_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 T_TEST_CASE (AcfgValOneCpu)
This test case performs the following actions:
  • Check the effect of application configuration options.
    • Check that the CONFIGURE_MAXIMUM_PRIORITY application configuration option resulted in the expected system setting using spec:/rtems/task/if/maximum-priority.
    • Check that the Deterministic Priority Scheduler which was configured by the CONFIGURE_SCHEDULER_PRIORITY application configuration in the test suite.
    • Check that we are able to identify the scheduler by the name configured by the CONFIGURE_SCHEDULER_PRIORITY application configuration option in the test suite.
