RTEMS 6.3
Tests a fatal error caused by an invalid application configuration. More...
Files | |
| file | testsuites/validation/tr-fatal-init-task-construct-failed.c |
| file | testsuites/validation/tr-fatal-init-task-construct-failed.h |
| struct | AcfgValFatalInitTaskConstructFailed_Context |
| Test context for spec:/acfg/val/fatal-init-task-construct-failed test case. More... | |
| void | AcfgValFatalInitTaskConstructFailed_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void AcfgValFatalInitTaskConstructFailed_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code ) |
| source | is fatal source. |
| code | is fatal code. |
