RTEMS 6.3
ARM_PLL_CTRL - ARM_PLL_CTRL_REGISTER | |
| #define | ANADIG_PLL_ARM_PLL_CTRL_DIV_SELECT_MASK (0xFFU) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_DIV_SELECT_SHIFT (0U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_DIV_SELECT(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_HOLD_RING_OFF_MASK (0x1000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_HOLD_RING_OFF_SHIFT (12U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_HOLD_RING_OFF(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_POWERUP_MASK (0x2000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_POWERUP_SHIFT (13U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_POWERUP(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ENABLE_CLK_MASK (0x4000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ENABLE_CLK_SHIFT (14U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ENABLE_CLK(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_POST_DIV_SEL_MASK (0x18000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_POST_DIV_SEL_SHIFT (15U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_POST_DIV_SEL(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_BYPASS_MASK (0x20000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_BYPASS_SHIFT (17U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_BYPASS(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_STABLE_MASK (0x20000000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_STABLE_SHIFT (29U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_STABLE(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_GATE_MASK (0x40000000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_GATE_SHIFT (30U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_GATE(x) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_CONTROL_MODE(x) |
SYS_PLL3_CTRL - SYS_PLL3_CTRL_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2_MASK (0x8U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2_SHIFT (3U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_PLL_REG_EN_MASK (0x10U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_PLL_REG_EN_SHIFT (4U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_PLL_REG_EN(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_HOLD_RING_OFF_MASK (0x800U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_HOLD_RING_OFF_SHIFT (11U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_HOLD_RING_OFF(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_ENABLE_CLK_MASK (0x2000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_ENABLE_CLK_SHIFT (13U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_ENABLE_CLK(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_BYPASS_MASK (0x10000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_BYPASS_SHIFT (16U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_BYPASS(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_POWERUP_MASK (0x200000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_POWERUP_SHIFT (21U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_POWERUP(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2_CONTROL_MODE_MASK (0x10000000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2_CONTROL_MODE_SHIFT (28U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_STABLE_MASK (0x20000000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_STABLE_SHIFT (29U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_GATE_MASK (0x40000000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_GATE_SHIFT (30U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_GATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_CONTROL_MODE(x) |
SYS_PLL3_UPDATE - SYS_PLL3_UPDATE_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_UPDATE_MASK (0x2U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_UPDATE_SHIFT (1U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_UPDATE_MASK (0x4U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_UPDATE_SHIFT (2U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD2_UPDATE_MASK (0x8U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD2_UPDATE_SHIFT (3U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD2_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_UPDATE_MASK (0x10U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_UPDATE_SHIFT (4U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_CONTROL_MODE_MASK (0x20U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_CONTROL_MODE_SHIFT (5U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_CONTROL_MODE_MASK (0x40U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_CONTROL_MODE_SHIFT (6U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PDF2_CONTROL_MODE_MASK (0x80U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PDF2_CONTROL_MODE_SHIFT (7U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PDF2_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_CONTROL_MODE_MASK (0x100U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_CONTROL_MODE_SHIFT (8U) |
| #define | ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_CONTROL_MODE(x) |
SYS_PLL3_PFD - SYS_PLL3_PFD_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_FRAC_MASK (0x3FU) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_FRAC_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_STABLE_MASK (0x40U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_STABLE_SHIFT (6U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_DIV1_CLKGATE_MASK (0x80U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_DIV1_CLKGATE_SHIFT (7U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD0_DIV1_CLKGATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_FRAC_MASK (0x3F00U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_FRAC_SHIFT (8U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_STABLE_MASK (0x4000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_STABLE_SHIFT (14U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_DIV1_CLKGATE_MASK (0x8000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_DIV1_CLKGATE_SHIFT (15U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD1_DIV1_CLKGATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_FRAC_MASK (0x3F0000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_FRAC_SHIFT (16U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_STABLE_MASK (0x400000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_STABLE_SHIFT (22U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_DIV1_CLKGATE_MASK (0x800000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_DIV1_CLKGATE_SHIFT (23U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD2_DIV1_CLKGATE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_FRAC_MASK (0x3F000000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_FRAC_SHIFT (24U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_STABLE_MASK (0x40000000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_STABLE_SHIFT (30U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_DIV1_CLKGATE_MASK (0x80000000U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_DIV1_CLKGATE_SHIFT (31U) |
| #define | ANADIG_PLL_SYS_PLL3_PFD_PFD3_DIV1_CLKGATE(x) |
SYS_PLL2_CTRL - SYS_PLL2_CTRL_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PLL_REG_EN_MASK (0x8U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PLL_REG_EN_SHIFT (3U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PLL_REG_EN(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_HOLD_RING_OFF_MASK (0x800U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_HOLD_RING_OFF_SHIFT (11U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_HOLD_RING_OFF(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_ENABLE_CLK_MASK (0x2000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_ENABLE_CLK_SHIFT (13U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_ENABLE_CLK(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_BYPASS_MASK (0x10000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_BYPASS_SHIFT (16U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_BYPASS(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_DITHER_ENABLE_MASK (0x20000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_DITHER_ENABLE_SHIFT (17U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_DITHER_ENABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PFD_OFFSET_EN_MASK (0x40000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PFD_OFFSET_EN_SHIFT (18U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PFD_OFFSET_EN(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PLL_DDR_OVERRIDE_MASK (0x80000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PLL_DDR_OVERRIDE_SHIFT (19U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_PLL_DDR_OVERRIDE(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_POWERUP_MASK (0x800000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_POWERUP_SHIFT (23U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_POWERUP(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_STABLE_MASK (0x20000000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_STABLE_SHIFT (29U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_GATE_MASK (0x40000000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_GATE_SHIFT (30U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_GATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_CONTROL_MODE(x) |
SYS_PLL2_UPDATE - SYS_PLL2_UPDATE_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_UPDATE_MASK (0x2U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_UPDATE_SHIFT (1U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_UPDATE_MASK (0x4U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_UPDATE_SHIFT (2U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_UPDATE_MASK (0x8U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_UPDATE_SHIFT (3U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_UPDATE_MASK (0x10U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_UPDATE_SHIFT (4U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_UPDATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_CONTROL_MODE_MASK (0x20U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_CONTROL_MODE_SHIFT (5U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_CONTROL_MODE_MASK (0x40U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_CONTROL_MODE_SHIFT (6U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_CONTROL_MODE_MASK (0x80U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_CONTROL_MODE_SHIFT (7U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_CONTROL_MODE_MASK (0x100U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_CONTROL_MODE_SHIFT (8U) |
| #define | ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_CONTROL_MODE(x) |
SYS_PLL2_SS - SYS_PLL2_SS_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL2_SS_STEP_MASK (0x7FFFU) |
| #define | ANADIG_PLL_SYS_PLL2_SS_STEP_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL2_SS_STEP(x) |
| #define | ANADIG_PLL_SYS_PLL2_SS_ENABLE_MASK (0x8000U) |
| #define | ANADIG_PLL_SYS_PLL2_SS_ENABLE_SHIFT (15U) |
| #define | ANADIG_PLL_SYS_PLL2_SS_ENABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_SS_STOP_MASK (0xFFFF0000U) |
| #define | ANADIG_PLL_SYS_PLL2_SS_STOP_SHIFT (16U) |
| #define | ANADIG_PLL_SYS_PLL2_SS_STOP(x) |
SYS_PLL2_PFD - SYS_PLL2_PFD_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_FRAC_MASK (0x3FU) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_FRAC_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_STABLE_MASK (0x40U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_STABLE_SHIFT (6U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_DIV1_CLKGATE_MASK (0x80U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_DIV1_CLKGATE_SHIFT (7U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD0_DIV1_CLKGATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_FRAC_MASK (0x3F00U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_FRAC_SHIFT (8U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_STABLE_MASK (0x4000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_STABLE_SHIFT (14U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_DIV1_CLKGATE_MASK (0x8000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_DIV1_CLKGATE_SHIFT (15U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD1_DIV1_CLKGATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_FRAC_MASK (0x3F0000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_FRAC_SHIFT (16U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_STABLE_MASK (0x400000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_STABLE_SHIFT (22U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_DIV1_CLKGATE_MASK (0x800000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_DIV1_CLKGATE_SHIFT (23U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD2_DIV1_CLKGATE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_FRAC_MASK (0x3F000000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_FRAC_SHIFT (24U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_FRAC(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_STABLE_MASK (0x40000000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_STABLE_SHIFT (30U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_DIV1_CLKGATE_MASK (0x80000000U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_DIV1_CLKGATE_SHIFT (31U) |
| #define | ANADIG_PLL_SYS_PLL2_PFD_PFD3_DIV1_CLKGATE(x) |
SYS_PLL2_MFD - SYS_PLL2_MFD_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL2_MFD_MFD_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_SYS_PLL2_MFD_MFD_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL2_MFD_MFD(x) |
SYS_PLL1_SS - SYS_PLL1_SS_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL1_SS_STEP_MASK (0x7FFFU) |
| #define | ANADIG_PLL_SYS_PLL1_SS_STEP_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL1_SS_STEP(x) |
| #define | ANADIG_PLL_SYS_PLL1_SS_ENABLE_MASK (0x8000U) |
| #define | ANADIG_PLL_SYS_PLL1_SS_ENABLE_SHIFT (15U) |
| #define | ANADIG_PLL_SYS_PLL1_SS_ENABLE(x) |
| #define | ANADIG_PLL_SYS_PLL1_SS_STOP_MASK (0xFFFF0000U) |
| #define | ANADIG_PLL_SYS_PLL1_SS_STOP_SHIFT (16U) |
| #define | ANADIG_PLL_SYS_PLL1_SS_STOP(x) |
SYS_PLL1_CTRL - SYS_PLL1_CTRL_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_ENABLE_CLK_MASK (0x2000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_ENABLE_CLK_SHIFT (13U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_ENABLE_CLK(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_GATE_MASK (0x4000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_GATE_SHIFT (14U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_GATE(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2_MASK (0x2000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2_SHIFT (25U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5_MASK (0x4000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5_SHIFT (26U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5_CONTROL_MODE_MASK (0x8000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5_CONTROL_MODE_SHIFT (27U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2_CONTROL_MODE_MASK (0x10000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2_CONTROL_MODE_SHIFT (28U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2_CONTROL_MODE(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_STABLE_MASK (0x20000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_STABLE_SHIFT (29U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_STABLE(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_AI_BUSY_MASK (0x40000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_AI_BUSY_SHIFT (30U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_AI_BUSY(x) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_CONTROL_MODE(x) |
SYS_PLL1_DENOMINATOR - SYS_PLL1_DENOMINATOR_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL1_DENOMINATOR_DENOM_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_SYS_PLL1_DENOMINATOR_DENOM_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL1_DENOMINATOR_DENOM(x) |
SYS_PLL1_NUMERATOR - SYS_PLL1_NUMERATOR_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL1_NUMERATOR_NUM_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_SYS_PLL1_NUMERATOR_NUM_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL1_NUMERATOR_NUM(x) |
SYS_PLL1_DIV_SELECT - SYS_PLL1_DIV_SELECT_REGISTER | |
| #define | ANADIG_PLL_SYS_PLL1_DIV_SELECT_DIV_SELECT_MASK (0x7FU) |
| #define | ANADIG_PLL_SYS_PLL1_DIV_SELECT_DIV_SELECT_SHIFT (0U) |
| #define | ANADIG_PLL_SYS_PLL1_DIV_SELECT_DIV_SELECT(x) |
PLL_AUDIO_CTRL - PLL_AUDIO_CTRL_REGISTER | |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_ENABLE_CLK_MASK (0x2000U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_ENABLE_CLK_SHIFT (13U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_ENABLE_CLK(x) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_GATE_MASK (0x4000U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_GATE_SHIFT (14U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_GATE(x) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_STABLE_MASK (0x20000000U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_STABLE_SHIFT (29U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_STABLE(x) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_AI_BUSY_MASK (0x40000000U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_AI_BUSY_SHIFT (30U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_AI_BUSY(x) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_CONTROL_MODE(x) |
PLL_AUDIO_SS - PLL_AUDIO_SS_REGISTER | |
| #define | ANADIG_PLL_PLL_AUDIO_SS_STEP_MASK (0x7FFFU) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_STEP_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_STEP(x) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_ENABLE_MASK (0x8000U) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_ENABLE_SHIFT (15U) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_ENABLE(x) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_STOP_MASK (0xFFFF0000U) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_STOP_SHIFT (16U) |
| #define | ANADIG_PLL_PLL_AUDIO_SS_STOP(x) |
PLL_AUDIO_DENOMINATOR - PLL_AUDIO_DENOMINATOR_REGISTER | |
| #define | ANADIG_PLL_PLL_AUDIO_DENOMINATOR_DENOM_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_PLL_AUDIO_DENOMINATOR_DENOM_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_AUDIO_DENOMINATOR_DENOM(x) |
PLL_AUDIO_NUMERATOR - PLL_AUDIO_NUMERATOR_REGISTER | |
| #define | ANADIG_PLL_PLL_AUDIO_NUMERATOR_NUM_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_PLL_AUDIO_NUMERATOR_NUM_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_AUDIO_NUMERATOR_NUM(x) |
PLL_AUDIO_DIV_SELECT - PLL_AUDIO_DIV_SELECT_REGISTER | |
| #define | ANADIG_PLL_PLL_AUDIO_DIV_SELECT_PLL_AUDIO_DIV_SELECT_MASK (0x7FU) |
| #define | ANADIG_PLL_PLL_AUDIO_DIV_SELECT_PLL_AUDIO_DIV_SELECT_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_AUDIO_DIV_SELECT_PLL_AUDIO_DIV_SELECT(x) |
PLL_VIDEO_CTRL - PLL_VIDEO_CTRL_REGISTER | |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_ENABLE_CLK_MASK (0x2000U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_ENABLE_CLK_SHIFT (13U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_ENABLE_CLK(x) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_GATE_MASK (0x4000U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_GATE_SHIFT (14U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_GATE(x) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_COUNTER_CLR_MASK (0x1000000U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_COUNTER_CLR_SHIFT (24U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_COUNTER_CLR(x) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_STABLE_MASK (0x20000000U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_STABLE_SHIFT (29U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_STABLE(x) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_AI_BUSY_MASK (0x40000000U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_AI_BUSY_SHIFT (30U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_AI_BUSY(x) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_CONTROL_MODE(x) |
PLL_VIDEO_SS - PLL_VIDEO_SS_REGISTER | |
| #define | ANADIG_PLL_PLL_VIDEO_SS_STEP_MASK (0x7FFFU) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_STEP_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_STEP(x) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_ENABLE_MASK (0x8000U) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_ENABLE_SHIFT (15U) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_ENABLE(x) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_STOP_MASK (0xFFFF0000U) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_STOP_SHIFT (16U) |
| #define | ANADIG_PLL_PLL_VIDEO_SS_STOP(x) |
PLL_VIDEO_DENOMINATOR - PLL_VIDEO_DENOMINATOR_REGISTER | |
| #define | ANADIG_PLL_PLL_VIDEO_DENOMINATOR_DENOM_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_PLL_VIDEO_DENOMINATOR_DENOM_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_VIDEO_DENOMINATOR_DENOM(x) |
PLL_VIDEO_NUMERATOR - PLL_VIDEO_NUMERATOR_REGISTER | |
| #define | ANADIG_PLL_PLL_VIDEO_NUMERATOR_NUM_MASK (0x3FFFFFFFU) |
| #define | ANADIG_PLL_PLL_VIDEO_NUMERATOR_NUM_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_VIDEO_NUMERATOR_NUM(x) |
PLL_VIDEO_DIV_SELECT - PLL_VIDEO_DIV_SELECT_REGISTER | |
| #define | ANADIG_PLL_PLL_VIDEO_DIV_SELECT_DIV_SELECT_MASK (0x7FU) |
| #define | ANADIG_PLL_PLL_VIDEO_DIV_SELECT_DIV_SELECT_SHIFT (0U) |
| #define | ANADIG_PLL_PLL_VIDEO_DIV_SELECT_DIV_SELECT(x) |
| #define ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_CONTROL_MODE | ( | x | ) |
ARM_PLL_CONTROL_MODE - pll_arm_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_GATE | ( | x | ) |
ARM_PLL_GATE - ARM_PLL_GATE 0b1..Clock is gated 0b0..Clock is not gated
| #define ANADIG_PLL_ARM_PLL_CTRL_ARM_PLL_STABLE | ( | x | ) |
ARM_PLL_STABLE - ARM_PLL_STABLE 0b1..ARM PLL is stable 0b0..ARM PLL is not stable
| #define ANADIG_PLL_ARM_PLL_CTRL_BYPASS | ( | x | ) |
BYPASS - Bypass the pll. 0b1..Bypass Mode 0b0..Function mode
| #define ANADIG_PLL_ARM_PLL_CTRL_DIV_SELECT | ( | x | ) |
DIV_SELECT - DIV_SELECT
| #define ANADIG_PLL_ARM_PLL_CTRL_ENABLE_CLK | ( | x | ) |
ENABLE_CLK - Enable the clock output. 0b0..Disable the clock 0b1..Enable the clock
| #define ANADIG_PLL_ARM_PLL_CTRL_HOLD_RING_OFF | ( | x | ) |
HOLD_RING_OFF - PLL Start up initialization 0b0..Normal operation 0b1..Initialize PLL start up
| #define ANADIG_PLL_ARM_PLL_CTRL_POST_DIV_SEL | ( | x | ) |
POST_DIV_SEL - POST_DIV_SEL 0b00..Divide by 2 0b01..Divide by 4 0b10..Divide by 8 0b11..Divide by 1
| #define ANADIG_PLL_ARM_PLL_CTRL_POWERUP | ( | x | ) |
POWERUP - Powers up the PLL. 0b1..Power Up the PLL 0b0..Power down the PLL
| #define ANADIG_PLL_PLL_AUDIO_CTRL_ENABLE_CLK | ( | x | ) |
ENABLE_CLK - ENABLE_CLK
| #define ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_AI_BUSY | ( | x | ) |
PLL_AUDIO_AI_BUSY - pll_audio_ai_busy
| #define ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_CONTROL_MODE | ( | x | ) |
PLL_AUDIO_CONTROL_MODE - pll_audio_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_GATE | ( | x | ) |
PLL_AUDIO_GATE - PLL_AUDIO_GATE 0b1..Gate the output 0b0..No gate
| #define ANADIG_PLL_PLL_AUDIO_CTRL_PLL_AUDIO_STABLE | ( | x | ) |
PLL_AUDIO_STABLE - PLL_AUDIO_STABLE
| #define ANADIG_PLL_PLL_AUDIO_DENOMINATOR_DENOM | ( | x | ) |
DENOM - DENOM
DENOM - DENOM
| #define ANADIG_PLL_PLL_AUDIO_DIV_SELECT_PLL_AUDIO_DIV_SELECT | ( | x | ) |
| #define ANADIG_PLL_PLL_AUDIO_NUMERATOR_NUM | ( | x | ) |
NUM - NUM
NUM - NUM
| #define ANADIG_PLL_PLL_AUDIO_SS_ENABLE | ( | x | ) |
ENABLE - ENABLE 0b1..Enable Spread Spectrum 0b0..Disable Spread Spectrum
| #define ANADIG_PLL_PLL_AUDIO_SS_STEP | ( | x | ) |
STEP - STEP
STEP - STEP
| #define ANADIG_PLL_PLL_AUDIO_SS_STOP | ( | x | ) |
STOP - STOP
STOP - STOP
| #define ANADIG_PLL_PLL_VIDEO_CTRL_ENABLE_CLK | ( | x | ) |
| #define ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_AI_BUSY | ( | x | ) |
PLL_VIDEO_AI_BUSY - pll_video_ai_busy
| #define ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_CONTROL_MODE | ( | x | ) |
PLL_VIDEO_CONTROL_MODE - pll_video_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_COUNTER_CLR | ( | x | ) |
PLL_VIDEO_COUNTER_CLR - pll_video_counter_clr
| #define ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_GATE | ( | x | ) |
PLL_VIDEO_GATE - PLL_VIDEO_GATE 0b1..Gate the output 0b0..No gate
| #define ANADIG_PLL_PLL_VIDEO_CTRL_PLL_VIDEO_STABLE | ( | x | ) |
PLL_VIDEO_STABLE - PLL_VIDEO_STABLE
| #define ANADIG_PLL_PLL_VIDEO_DENOMINATOR_DENOM | ( | x | ) |
DENOM - DENOM
DENOM - DENOM
| #define ANADIG_PLL_PLL_VIDEO_DIV_SELECT_DIV_SELECT | ( | x | ) |
| #define ANADIG_PLL_PLL_VIDEO_NUMERATOR_NUM | ( | x | ) |
NUM - NUM
NUM - NUM
| #define ANADIG_PLL_PLL_VIDEO_SS_ENABLE | ( | x | ) |
| #define ANADIG_PLL_PLL_VIDEO_SS_STEP | ( | x | ) |
STEP - STEP
STEP - STEP
| #define ANADIG_PLL_PLL_VIDEO_SS_STOP | ( | x | ) |
STOP - STOP
STOP - STOP
| #define ANADIG_PLL_SYS_PLL1_CTRL_ENABLE_CLK | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_AI_BUSY | ( | x | ) |
SYS_PLL1_AI_BUSY - SYS_PLL1_AI_BUSY
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_CONTROL_MODE | ( | x | ) |
SYS_PLL1_CONTROL_MODE - SYS_PLL1_CONTROL_MODE 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2 | ( | x | ) |
SYS_PLL1_DIV2 - SYS_PLL1_DIV2
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV2_CONTROL_MODE | ( | x | ) |
SYS_PLL1_DIV2_CONTROL_MODE - SYS_PLL1_DIV2_CONTROL_MODE 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5 | ( | x | ) |
SYS_PLL1_DIV5 - SYS_PLL1_DIV5
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_DIV5_CONTROL_MODE | ( | x | ) |
SYS_PLL1_DIV5_CONTROL_MODE - SYS_PLL1_DIV5_CONTROL_MODE 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_GATE | ( | x | ) |
SYS_PLL1_GATE - SYS_PLL1_GATE 0b1..Gate the output 0b0..No gate
| #define ANADIG_PLL_SYS_PLL1_CTRL_SYS_PLL1_STABLE | ( | x | ) |
SYS_PLL1_STABLE - SYS_PLL1_STABLE
| #define ANADIG_PLL_SYS_PLL1_DENOMINATOR_DENOM | ( | x | ) |
DENOM - DENOM
DENOM - DENOM
| #define ANADIG_PLL_SYS_PLL1_DIV_SELECT_DIV_SELECT | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL1_NUMERATOR_NUM | ( | x | ) |
NUM - NUM
NUM - NUM
| #define ANADIG_PLL_SYS_PLL1_SS_ENABLE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL1_SS_STEP | ( | x | ) |
STEP - STEP
STEP - STEP
| #define ANADIG_PLL_SYS_PLL1_SS_STOP | ( | x | ) |
STOP - STOP
STOP - STOP
| #define ANADIG_PLL_SYS_PLL2_CTRL_BYPASS | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL2_CTRL_DITHER_ENABLE | ( | x | ) |
DITHER_ENABLE - DITHER_ENABLE 0b0..Disable Dither 0b1..Enable Dither
| #define ANADIG_PLL_SYS_PLL2_CTRL_ENABLE_CLK | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL2_CTRL_HOLD_RING_OFF | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL2_CTRL_PFD_OFFSET_EN | ( | x | ) |
PFD_OFFSET_EN - PFD_OFFSET_EN
| #define ANADIG_PLL_SYS_PLL2_CTRL_PLL_DDR_OVERRIDE | ( | x | ) |
PLL_DDR_OVERRIDE - PLL_DDR_OVERRIDE
| #define ANADIG_PLL_SYS_PLL2_CTRL_PLL_REG_EN | ( | x | ) |
PLL_REG_EN - Enable Internal PLL Regulator
| #define ANADIG_PLL_SYS_PLL2_CTRL_POWERUP | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_CONTROL_MODE | ( | x | ) |
SYS_PLL2_CONTROL_MODE - SYS_PLL2_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_GATE | ( | x | ) |
SYS_PLL2_GATE - SYS_PLL2_GATE 0b1..Clock is gated 0b0..Clock is not gated
| #define ANADIG_PLL_SYS_PLL2_CTRL_SYS_PLL2_STABLE | ( | x | ) |
SYS_PLL2_STABLE - SYS_PLL2_STABLE
| #define ANADIG_PLL_SYS_PLL2_MFD_MFD | ( | x | ) |
MFD - Denominator
MFD - Denominator
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD0_DIV1_CLKGATE | ( | x | ) |
PFD0_DIV1_CLKGATE - PFD0_DIV1_CLKGATE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD0_FRAC | ( | x | ) |
PFD0_FRAC - PFD0_FRAC
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD0_STABLE | ( | x | ) |
PFD0_STABLE - PFD0_STABLE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD1_DIV1_CLKGATE | ( | x | ) |
PFD1_DIV1_CLKGATE - PFD1_DIV1_CLKGATE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD1_FRAC | ( | x | ) |
PFD1_FRAC - PFD1_FRAC
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD1_STABLE | ( | x | ) |
PFD1_STABLE - PFD1_STABLE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD2_DIV1_CLKGATE | ( | x | ) |
PFD2_DIV1_CLKGATE - PFD2_DIV1_CLKGATE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD2_FRAC | ( | x | ) |
PFD2_FRAC - PFD2_FRAC
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD2_STABLE | ( | x | ) |
PFD2_STABLE - PFD2_STABLE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD3_DIV1_CLKGATE | ( | x | ) |
PFD3_DIV1_CLKGATE - PFD3_DIV1_CLKGATE
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD3_FRAC | ( | x | ) |
PFD3_FRAC - PFD3_FRAC
| #define ANADIG_PLL_SYS_PLL2_PFD_PFD3_STABLE | ( | x | ) |
PFD3_STABLE - PFD3_STABLE
| #define ANADIG_PLL_SYS_PLL2_SS_ENABLE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL2_SS_STEP | ( | x | ) |
STEP - STEP
STEP - STEP
| #define ANADIG_PLL_SYS_PLL2_SS_STOP | ( | x | ) |
STOP - STOP
STOP - STOP
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_CONTROL_MODE | ( | x | ) |
PFD0_CONTROL_MODE - pfd0_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD0_UPDATE | ( | x | ) |
PFD0_UPDATE - PFD0_UPDATE
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_CONTROL_MODE | ( | x | ) |
PFD1_CONTROL_MODE - pfd1_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD1_UPDATE | ( | x | ) |
PFD1_UPDATE - PFD1_UPDATE
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_CONTROL_MODE | ( | x | ) |
PFD2_CONTROL_MODE - pfd2_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD2_UPDATE | ( | x | ) |
PFD2_UPDATE - PFD2_UPDATE
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_CONTROL_MODE | ( | x | ) |
PFD3_CONTROL_MODE - pfd3_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL2_UPDATE_PFD3_UPDATE | ( | x | ) |
PFD3_UPDATE - PFD3_UPDATE
| #define ANADIG_PLL_SYS_PLL3_CTRL_BYPASS | ( | x | ) |
BYPASS - BYPASS 0b1..Bypass Mode 0b0..Function mode
| #define ANADIG_PLL_SYS_PLL3_CTRL_ENABLE_CLK | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_CTRL_HOLD_RING_OFF | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_CTRL_PLL_REG_EN | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_CTRL_POWERUP | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_CONTROL_MODE | ( | x | ) |
SYS_PLL3_CONTROL_MODE - SYS_PLL3_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2 | ( | x | ) |
SYS_PLL3_DIV2 - SYS PLL3 DIV2 gate
| #define ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_DIV2_CONTROL_MODE | ( | x | ) |
SYS_PLL3_DIV2_CONTROL_MODE - SYS_PLL3_DIV2_CONTROL_MODE 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_GATE | ( | x | ) |
SYS_PLL3_GATE - SYS_PLL3_GATE 0b1..Clock is gated 0b0..Clock is not gated
| #define ANADIG_PLL_SYS_PLL3_CTRL_SYS_PLL3_STABLE | ( | x | ) |
SYS_PLL3_STABLE - SYS_PLL3_STABLE
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD0_DIV1_CLKGATE | ( | x | ) |
PFD0_DIV1_CLKGATE - PFD0_DIV1_CLKGATE 0b1..Fractional divider clock (reference ref_pfd0) is off (power savings 0b0..ref_pfd0 fractional divider clock is enabled
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD0_FRAC | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD0_STABLE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD1_DIV1_CLKGATE | ( | x | ) |
PFD1_DIV1_CLKGATE - PFD1_DIV1_CLKGATE 0b1..Fractional divider clock (reference ref_pfd1) is off (power savings) 0b0..ref_pfd1 fractional divider clock is enabled
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD1_FRAC | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD1_STABLE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD2_DIV1_CLKGATE | ( | x | ) |
PFD2_DIV1_CLKGATE - PFD2_DIV1_CLKGATE 0b1..Fractional divider clock (reference ref_pfd2) is off (power savings) 0b0..ref_pfd2 fractional divider clock is enabled
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD2_FRAC | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD2_STABLE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD3_DIV1_CLKGATE | ( | x | ) |
PFD3_DIV1_CLKGATE - PFD3_DIV1_CLKGATE 0b1..Fractional divider clock (reference ref_pfd3) is off (power savings) 0b0..ref_pfd3 fractional divider clock is enabled
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD3_FRAC | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_PFD_PFD3_STABLE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PDF2_CONTROL_MODE | ( | x | ) |
PDF2_CONTROL_MODE - pdf2_control_mode 0b0..Software Mode (Default) 0b1..GPC Mode
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_CONTROL_MODE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD0_UPDATE | ( | x | ) |
PFD0_UPDATE - PFD0_OVERRIDE
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_CONTROL_MODE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD1_UPDATE | ( | x | ) |
PFD1_UPDATE - PFD1_OVERRIDE
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD2_UPDATE | ( | x | ) |
PFD2_UPDATE - PFD2_OVERRIDE
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_CONTROL_MODE | ( | x | ) |
| #define ANADIG_PLL_SYS_PLL3_UPDATE_PFD3_UPDATE | ( | x | ) |
