RTEMS 6.3
OSC_48M_CTRL - 48MHz RCOSC Control Register
#define ANADIG_OSC_OSC_48M_CTRL_TEN_MASK   (0x2U)
#define ANADIG_OSC_OSC_48M_CTRL_TEN_SHIFT   (1U)
#define ANADIG_OSC_OSC_48M_CTRL_TEN(x)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_MASK   (0x1000000U)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_SHIFT   (24U)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN(x)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_MASK   (0x40000000U)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_SHIFT   (30U)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE(x)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_MASK   (0x80000000U)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_SHIFT   (31U)
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE(x)
OSC_24M_CTRL - 24MHz OSC Control Register
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_MASK   (0x1U)
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_SHIFT   (0U)
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK(x)
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_MASK   (0x2U)
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_SHIFT   (1U)
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN(x)
#define ANADIG_OSC_OSC_24M_CTRL_LP_EN_MASK   (0x4U)
#define ANADIG_OSC_OSC_24M_CTRL_LP_EN_SHIFT   (2U)
#define ANADIG_OSC_OSC_24M_CTRL_LP_EN(x)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_MASK   (0x8U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_SHIFT   (3U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE(x)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_EN_MASK   (0x10U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_EN_SHIFT   (4U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_EN(x)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_MASK   (0x80U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_SHIFT   (7U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE(x)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_MASK   (0x40000000U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_SHIFT   (30U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE(x)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_MASK   (0x80000000U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_SHIFT   (31U)
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE(x)
OSC_400M_CTRL0 - 400MHz RCOSC Control0 Register
#define ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_MASK   (0x80000000U)
#define ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_SHIFT   (31U)
#define ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY(x)
OSC_400M_CTRL1 - 400MHz RCOSC Control1 Register
#define ANADIG_OSC_OSC_400M_CTRL1_PWD_MASK   (0x1U)
#define ANADIG_OSC_OSC_400M_CTRL1_PWD_SHIFT   (0U)
#define ANADIG_OSC_OSC_400M_CTRL1_PWD(x)
#define ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_MASK   (0x2U)
#define ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_SHIFT   (1U)
#define ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG(x)
#define ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_MASK   (0x80000000U)
#define ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_SHIFT   (31U)
#define ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE(x)
OSC_400M_CTRL2 - 400MHz RCOSC Control2 Register
#define ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_MASK   (0x1U)
#define ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_SHIFT   (0U)
#define ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK(x)
#define ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_MASK   (0x400U)
#define ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_SHIFT   (10U)
#define ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP(x)
#define ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_MASK   (0xFF000000U)
#define ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_SHIFT   (24U)
#define ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL(x)
OSC_16M_CTRL - 16MHz RCOSC Control Register
#define ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_MASK   (0x2U)
#define ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_SHIFT   (1U)
#define ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M(x)
#define ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_MASK   (0x8U)
#define ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_SHIFT   (3U)
#define ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE(x)
#define ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_MASK   (0x100U)
#define ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_SHIFT   (8U)
#define ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M(x)
#define ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_MASK   (0x80000000U)
#define ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_SHIFT   (31U)
#define ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE(x)
◆ ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M [1/2]
#define ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_MASK)
EN_IRC4M16M - Enable Clock Output 0b0..Disable 0b1..Enable
◆ ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M [2/2]
Value:
◆ ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE [1/2]
#define ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_MASK)
EN_POWER_SAVE - Power Save Enable 0b0..Disable 0b1..Enable
◆ ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE [2/2]
Value:
◆ ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE [1/2]
#define ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_MASK)
RC_16M_CONTROL_MODE - Control Mode for 16MHz Oscillator 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
◆ ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE [2/2]
Value:
◆ ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M [1/2]
#define ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_MASK)
SOURCE_SEL_16M - Source select 0b0..16MHz Oscillator 0b1..24MHz Oscillator
◆ ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_MASK)
BYPASS_CLK - 24MHz OSC Bypass Clock
◆ ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_MASK)
BYPASS_EN - 24MHz OSC Bypass Enable 0b0..Disable 0b1..Enable
◆ ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_LP_EN [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_LP_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_LP_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_LP_EN_MASK)
LP_EN - 24MHz OSC Low-Power Mode Enable 0b0..High Gain mode (HP) 0b1..Low-power mode (LP)
◆ ANADIG_OSC_OSC_24M_CTRL_LP_EN [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_MASK)
OSC_24M_CONTROL_MODE - 24MHz OSC Control Mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_MASK)
OSC_24M_GATE - 24MHz OSC Gate Control 0b0..Not Gated 0b1..Gated
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_MASK)
OSC_24M_STABLE - 24MHz OSC Stable 0b0..Not Stable 0b1..Stable
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_MASK)
OSC_COMP_MODE - 24MHz OSC Comparator Mode 0b0..Single-ended mode (default) 0b1..Differential mode (test mode)
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE [2/2]
Value:
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_EN [1/2]
#define ANADIG_OSC_OSC_24M_CTRL_OSC_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_EN_MASK)
OSC_EN - 24MHz OSC Enable 0b0..Disable 0b1..Enable
◆ ANADIG_OSC_OSC_24M_CTRL_OSC_EN [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY [1/2]
#define ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_MASK)
OSC400M_AI_BUSY - 400MHz OSC AI BUSY
◆ ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG [1/2]
#define ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_MASK)
CLKGATE_400MEG - Clock gate control for 400MHz RCOSC 0b0..Not Gated 0b1..Gated
◆ ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL1_PWD [1/2]
#define ANADIG_OSC_OSC_400M_CTRL1_PWD ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_PWD_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_PWD_MASK)
PWD - Power down control for 400MHz RCOSC 0b0..No Power down 0b1..Power down
◆ ANADIG_OSC_OSC_400M_CTRL1_PWD [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE [1/2]
#define ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_MASK)
RC_400M_CONTROL_MODE - 400MHz RCOSC Control mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
◆ ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK [1/2]
#define ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_MASK)
ENABLE_CLK - Clock enable 0b0..Clock is disabled before entering GPC mode 0b1..Clock is enabled before entering GPC mode
◆ ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL [1/2]
#define ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_MASK)
OSC_TUNE_VAL - Oscillator Tune Value
◆ ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL [2/2]
Value:
◆ ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP [1/2]
#define ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_MASK)
TUNE_BYP - Bypass tuning logic 0b0..Use the output of tuning logic to run the oscillator 0b1..Bypass the tuning logic and use the programmed OSC_TUNE_VAL to run the oscillator
◆ ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP [2/2]
Value:
◆ ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE [1/2]
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_MASK)
RC_48M_CONTROL_MODE - 48MHz RCOSC Control Mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
◆ ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE [2/2]
Value:
◆ ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE [1/2]
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_MASK)
RC_48M_DIV2_CONTROL_MODE - RCOSC_48M_DIV2 Control Mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
◆ ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE [2/2]
Value:
◆ ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN [1/2]
#define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_MASK)
RC_48M_DIV2_EN - RCOSC_48M_DIV2 Enable 0b0..Disable 0b1..Enable
◆ ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN [2/2]
Value:
◆ ANADIG_OSC_OSC_48M_CTRL_TEN [1/2]
#define ANADIG_OSC_OSC_48M_CTRL_TEN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_TEN_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_TEN_MASK)
TEN - 48MHz RCOSC Enable 0b0..Power down 0b1..Power up
◆ ANADIG_OSC_OSC_48M_CTRL_TEN [2/2]
Value:
