RTEMS 6.3
PMU_LDO_LPSR_ANA - PMU_LDO_LPSR_ANA_REGISTER | |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_MASK (0x1U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_SHIFT (0U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_MASK (0x4U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_SHIFT (2U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_MASK (0x8U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_SHIFT (3U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_MASK (0x10U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_SHIFT (4U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_MASK (0x20U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_SHIFT (5U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_MASK (0x40U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_SHIFT (6U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_MASK (0x100U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_SHIFT (8U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_MASK (0x80000U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_SHIFT (19U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_MASK (0x100000U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_SHIFT (20U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN(x) |
PMU_LDO_LPSR_DIG_2 - PMU_LDO_LPSR_DIG_2_REGISTER | |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_MASK (0x3U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_SHIFT (0U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC(x) |
PMU_LDO_LPSR_DIG - PMU_LDO_LPSR_DIG_REGISTER | |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_MASK (0x4U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_SHIFT (2U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_MASK (0x20U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_SHIFT (5U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_MASK (0x40U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_SHIFT (6U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_MASK (0x20000U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_SHIFT (17U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_MASK (0x40000U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_SHIFT (18U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE(x) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_MASK (0x1F00000U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_SHIFT (20U) |
| #define | ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT(x) |
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN | ( | x | ) |
ALWAYS_4MA_PULLDOWN_EN - always_4ma_pulldown_en
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN | ( | x | ) |
BYPASS_MODE_EN - bypass_mode_en
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE | ( | x | ) |
LPSR_ANA_CONTROL_MODE - LPSR_ANA_CONTROL_MODE 0b0..SW Control 0b1..HW Control
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN | ( | x | ) |
PULL_DOWN_20UA_EN - pull_down_20ua_en
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN | ( | x | ) |
PULL_DOWN_2MA_EN - pull_down_2ma_en
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE | ( | x | ) |
REG_DISABLE - reg_disable
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN | ( | x | ) |
REG_LP_EN - reg_lp_en
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN | ( | x | ) |
STANDBY_EN - standby_en
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN | ( | x | ) |
TRACK_MODE_EN - Track Mode Enable 0b0..Normal use 0b1..Switch preparation
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC | ( | x | ) |
VOLTAGE_STEP_INC - voltage_step_inc
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE | ( | x | ) |
BYPASS_MODE - bypass_mode
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE | ( | x | ) |
LPSR_DIG_CONTROL_MODE - LPSR_DIG_CONTROL_MODE 0b0..SW Control 0b1..HW Control
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN | ( | x | ) |
REG_EN - ENABLE_ILIMIT
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN | ( | x | ) |
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE | ( | x | ) |
TRACKING_MODE - tracking_mode
| #define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT | ( | x | ) |
VOLTAGE_SELECT - VOLTAGE_SELECT 0b00000..Stable Voltage (range) 0b00001..Stable Voltage (range) 0b00010..Stable Voltage (range) 0b00011..Stable Voltage (range) 0b00100..Stable Voltage (range) 0b00101..Stable Voltage (range) 0b00110..Stable Voltage (range) 0b00111..Stable Voltage (range) 0b01000..Stable Voltage (range) 0b01001..Stable Voltage (range) 0b01010..Stable Voltage (range) 0b01011..Stable Voltage (range) 0b01100..Stable Voltage (range) 0b01101..Stable Voltage (range) 0b01110..Stable Voltage (range) 0b01111..Stable Voltage (range) 0b10000..Stable Voltage (range) 0b10001..Stable Voltage (range) 0b10010..Stable Voltage (range) 0b10011..Stable Voltage (range) 0b10100..Stable Voltage (range) 0b10101..Stable Voltage (range) 0b10110..Stable Voltage (range) 0b10111..Stable Voltage (range) 0b11000..Stable Voltage (range) 0b11001..Stable Voltage (range) 0b11010..Stable Voltage (range) 0b11011..Stable Voltage (range) 0b11100..Stable Voltage (range) 0b11101..Stable Voltage (range) 0b11110..Stable Voltage (range) 0b11111..Stable Voltage (range)
