RTEMS 6.3
| struct | ALT_QSPI_DEV_SIZE_CONFIG_s |
| struct | ALT_QSPI_TIMING_CONFIG_s |
| struct | ALT_QSPI_DEV_INST_CONFIG_s |
Typedefs | |
| typedef enum ALT_QSPI_MODE_e | ALT_QSPI_MODE_t |
| typedef enum ALT_QSPI_CS_MODE_e | ALT_QSPI_CS_MODE_t |
| typedef enum ALT_QSPI_BAUD_DIV_e | ALT_QSPI_BAUD_DIV_t |
| typedef struct ALT_QSPI_DEV_SIZE_CONFIG_s | ALT_QSPI_DEV_SIZE_CONFIG_t |
| typedef enum ALT_QSPI_CLK_PHASE_e | ALT_QSPI_CLK_PHASE_t |
| typedef enum ALT_QSPI_CLK_POLARITY_e | ALT_QSPI_CLK_POLARITY_t |
| typedef struct ALT_QSPI_TIMING_CONFIG_s | ALT_QSPI_TIMING_CONFIG_t |
| typedef struct ALT_QSPI_DEV_INST_CONFIG_s | ALT_QSPI_DEV_INST_CONFIG_t |
Enumerations | |
| enum | ALT_QSPI_MODE_e { ALT_QSPI_MODE_SINGLE = 0 , ALT_QSPI_MODE_DUAL = 1 , ALT_QSPI_MODE_QUAD = 2 } |
| enum | ALT_QSPI_CS_MODE_e { ALT_QSPI_CS_MODE_SINGLE_SELECT = 0 , ALT_QSPI_CS_MODE_DECODE = 1 } |
| enum | ALT_QSPI_BAUD_DIV_e { ALT_QSPI_BAUD_DIV_2 = 0x0 , ALT_QSPI_BAUD_DIV_4 = 0x1 , ALT_QSPI_BAUD_DIV_6 = 0x2 , ALT_QSPI_BAUD_DIV_8 = 0x3 , ALT_QSPI_BAUD_DIV_10 = 0x4 , ALT_QSPI_BAUD_DIV_12 = 0x5 , ALT_QSPI_BAUD_DIV_14 = 0x6 , ALT_QSPI_BAUD_DIV_16 = 0x7 , ALT_QSPI_BAUD_DIV_18 = 0x8 , ALT_QSPI_BAUD_DIV_20 = 0x9 , ALT_QSPI_BAUD_DIV_22 = 0xA , ALT_QSPI_BAUD_DIV_24 = 0xB , ALT_QSPI_BAUD_DIV_26 = 0xC , ALT_QSPI_BAUD_DIV_28 = 0xD , ALT_QSPI_BAUD_DIV_30 = 0xE , ALT_QSPI_BAUD_DIV_32 = 0xF } |
| enum | ALT_QSPI_CLK_PHASE_e { ALT_QSPI_CLK_PHASE_ACTIVE = 0 , ALT_QSPI_CLK_PHASE_INACTIVE = 1 } |
| enum | ALT_QSPI_CLK_POLARITY_e { ALT_QSPI_CLK_POLARITY_LOW = 0 , ALT_QSPI_CLK_POLARITY_HIGH = 1 } |
The declarations and functions in this group are used to configure the QSPI controller interface to external flash devices.
The following steps describe how to initialize and configure the QSPI controller to operate with a flash device.
| typedef enum ALT_QSPI_BAUD_DIV_e ALT_QSPI_BAUD_DIV_t |
This type enumerates the QSPI controller master baud rate divisor selections.
| typedef enum ALT_QSPI_CLK_PHASE_e ALT_QSPI_CLK_PHASE_t |
This type enumerates the QSPI clock phase activity options outside the SPI word.
| typedef enum ALT_QSPI_CLK_POLARITY_e ALT_QSPI_CLK_POLARITY_t |
This type enumerates the QSPI clock polarity options outside the SPI word.
| typedef enum ALT_QSPI_CS_MODE_e ALT_QSPI_CS_MODE_t |
This type enumerates the mode configurations available for driving the ss_n[3:0] device chip selects. The chip selects may be controlled as either in a '1 of 4' or '4 to 16 decode' mode.
| typedef struct ALT_QSPI_DEV_INST_CONFIG_s ALT_QSPI_DEV_INST_CONFIG_t |
Device Instruction Configuration
This type defines a structure for specifying the optimal instruction set configuration to use with a target flash device.
| typedef struct ALT_QSPI_DEV_SIZE_CONFIG_s ALT_QSPI_DEV_SIZE_CONFIG_t |
Device Size Configuration
This type defines the structure used to specify flash device size and write protect regions.
| typedef enum ALT_QSPI_MODE_e ALT_QSPI_MODE_t |
This type enumerates the operational modes the QSPI controller can be configured for. It may apply to instruction, address, and/or data width interactions between the QSPI controller and the flash device.
| typedef struct ALT_QSPI_TIMING_CONFIG_s ALT_QSPI_TIMING_CONFIG_t |
QSPI Controller Timing Configuration
This type defines the structure used to configure timing paramaters used by the QSPI controller to communicate with a target flash device.
All timing values are defined in cycles of the SPI master ref clock.
| Enumerator | |
| ALT_QSPI_CS_MODE_SINGLE_SELECT | Select 1 of 4 chip select ss_n[3:0] |
| ALT_QSPI_CS_MODE_DECODE | Select external 4 to 16 decode of ss_n[3:0]. |
| ALT_QSPI_BAUD_DIV_t alt_qspi_baud_rate_div_get | ( | void | ) |
Get the current value of the QSPI master baud rate divisor.
| ALT_STATUS_CODE alt_qspi_baud_rate_div_set | ( | const ALT_QSPI_BAUD_DIV_t | baud_rate_div | ) |
Set the current value of the QSPI master baud rate divisor.
Sets the value of the QSPI master baud rate divisor.
| baud_rate_div | The master baud rate divisor. Valid range includes even values 2 to 32. |
| ALT_E_SUCCESS | Indicates successful completion. |
| ALT_E_ERROR | Indicates an error occurred. |
| ALT_STATUS_CODE alt_qspi_chip_select_config_get | ( | uint32_t * | cs, |
| ALT_QSPI_CS_MODE_t * | cs_mode ) |
Get the current QSPI device peripheral chip select output and decode function configuration values.
| cs | [out] The chip select line output values. |
| cs_mode | [out] The decode mode to use for the chip selects. |
| ALT_STATUS_CODE alt_qspi_chip_select_config_set | ( | const uint32_t | cs, |
| const ALT_QSPI_CS_MODE_t | cs_mode ) |
Set the QSPI device peripheral chip select outputs and decode function configuration.
The chip select lines output values operate according to the selected chip select decode mode. If cs_mode is ALT_QSPI_CS_MODE_SINGLE_SELECT then cs[3:0] are output thus:
| cs[3:0] | n_ss_out[3:0] |
| xxx0 | 1110 |
| xx01 | 1101 |
| x011 | 1011 |
| 0111 | 0111 |
| 1111 | 1111 (no peripheral selected) |
Otherwise if cs_mode is ALT_QSPI_CS_MODE_DECODE then cs[3:0] directly drives n_ss_out[3:0].
| cs | The chip select line output values. |
| cs_mode | The decode mode to use for the chip selects. |
| ALT_STATUS_CODE alt_qspi_device_read_config_get | ( | ALT_QSPI_DEV_INST_CONFIG_t * | cfg | ) |
Get the current QSPI device read instruction configuration.
| cfg | [out] Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure to contain the returned QSPI controller instruction configuration used when performing read transactions with the device. |
| ALT_STATUS_CODE alt_qspi_device_read_config_set | ( | const ALT_QSPI_DEV_INST_CONFIG_t * | cfg | ) |
Set the QSPI device read instruction configuration.
This API requires that the QSPI controller be idle, as determined by alt_qspi_is_idle().
| cfg | Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure specifying the desired op code, transfer widths, and dummy cycles for the QSPI controller to use when performing read transactions with the device. |
| ALT_STATUS_CODE alt_qspi_device_size_config_get | ( | ALT_QSPI_DEV_SIZE_CONFIG_t * | cfg | ) |
Get the current flash device size and write protection configuration.
| cfg | [out] Pointer to a ALT_QSPI_DEV_SIZE_CONFIG_t structure to contain the returned flash device size and write protection configuration. |
| ALT_STATUS_CODE alt_qspi_device_size_config_set | ( | const ALT_QSPI_DEV_SIZE_CONFIG_t * | cfg | ) |
Set the flash device size and write protection configuration.
| cfg | Pointer to a ALT_QSPI_DEV_SIZE_CONFIG_t structure containing the flash device size and write protection configuration. |
| ALT_STATUS_CODE alt_qspi_device_write_config_get | ( | ALT_QSPI_DEV_INST_CONFIG_t * | cfg | ) |
Get the current QSPI device write instruction configuration.
| cfg | [out] Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure to contain the returned QSPI controller instruction configuration used when performing write transactions with the device. |
| ALT_STATUS_CODE alt_qspi_device_write_config_set | ( | const ALT_QSPI_DEV_INST_CONFIG_t * | cfg | ) |
Set the QSPI device write instruction configuration.
| cfg | Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure specifying the desired op code, transfer widths, and dummy cycles for the QSPI controller to use when performing write transactions with the device. |
| uint32_t alt_qspi_mode_bit_config_get | ( | void | ) |
Get the current value of the Mode Bit Configuration register.
| ALT_STATUS_CODE alt_qspi_mode_bit_config_set | ( | const uint32_t | mode_bits | ) |
Set the value of the Mode Bit Configuration register.
Set the value of the 8 bits that are sent to the device following the address bytes when the mode bit is enabled (see: alt_qspi_mode_bit_enable())
| mode_bits | The 8 bit value sent to the device following the address bytes. |
| ALT_STATUS_CODE alt_qspi_mode_bit_disable | ( | void | ) |
Disable the mode bits from being sent after the address bytes.
Prevent the mode bits defined in the Mode Bit Configuration register from being sent following the address bytes.
| ALT_STATUS_CODE alt_qspi_mode_bit_enable | ( | void | ) |
Enable the mode bits to be sent after the address bytes.
Ensure the mode bits defined in the Mode Bit Configuration register to be sent following the address bytes.
| ALT_STATUS_CODE alt_qspi_timing_config_get | ( | ALT_QSPI_TIMING_CONFIG_t * | cfg | ) |
Get the QSPI device delay and timing configuration parameters.
This function returns the settings of the chip select delay and timing configurations.
| cfg | [out] Pointer to a ALT_QSPI_TIMING_CONFIG_t structure to return the device timing and delay settings. |
| ALT_STATUS_CODE alt_qspi_timing_config_set | ( | const ALT_QSPI_TIMING_CONFIG_t * | cfg | ) |
Set the QSPI device delay and timing configuration parameters.
This function allows the user to configure how the chip select is driven after each flash access. This is required as each device may have different timing requirements. As the serial clock frequency is increased, these timing parameters become more important and can be adjusted to meet the requirements of a specific flash device. All timings are defined in cycles of the SPI master ref clock.
| cfg | Pointer to a ALT_QSPI_TIMING_CONFIG_t structure specifying the desired timing and delay settings. |
