RTEMS 6.3
| #define | ADC_SOFTWARE_START (LL_ADC_REG_TRIG_SOFTWARE) |
| #define | ADC_EXTERNALTRIG_T1_CC1 (LL_ADC_REG_TRIG_EXT_TIM1_CH1) |
| #define | ADC_EXTERNALTRIG_T1_CC2 (LL_ADC_REG_TRIG_EXT_TIM1_CH2) |
| #define | ADC_EXTERNALTRIG_T1_CC3 (LL_ADC_REG_TRIG_EXT_TIM1_CH3) |
| #define | ADC_EXTERNALTRIG_T2_CC2 (LL_ADC_REG_TRIG_EXT_TIM2_CH2) |
| #define | ADC_EXTERNALTRIG_T3_TRGO (LL_ADC_REG_TRIG_EXT_TIM3_TRGO) |
| #define | ADC_EXTERNALTRIG_T4_CC4 (LL_ADC_REG_TRIG_EXT_TIM4_CH4) |
| #define | ADC_EXTERNALTRIG_EXT_IT11 (LL_ADC_REG_TRIG_EXT_EXTI_LINE11) |
| #define | ADC_EXTERNALTRIG_T8_TRGO (LL_ADC_REG_TRIG_EXT_TIM8_TRGO) |
| #define | ADC_EXTERNALTRIG_T8_TRGO2 (LL_ADC_REG_TRIG_EXT_TIM8_TRGO2) |
| #define | ADC_EXTERNALTRIG_T1_TRGO (LL_ADC_REG_TRIG_EXT_TIM1_TRGO) |
| #define | ADC_EXTERNALTRIG_T1_TRGO2 (LL_ADC_REG_TRIG_EXT_TIM1_TRGO2) |
| #define | ADC_EXTERNALTRIG_T2_TRGO (LL_ADC_REG_TRIG_EXT_TIM2_TRGO) |
| #define | ADC_EXTERNALTRIG_T4_TRGO (LL_ADC_REG_TRIG_EXT_TIM4_TRGO) |
| #define | ADC_EXTERNALTRIG_T6_TRGO (LL_ADC_REG_TRIG_EXT_TIM6_TRGO) |
| #define | ADC_EXTERNALTRIG_T15_TRGO (LL_ADC_REG_TRIG_EXT_TIM15_TRGO) |
| #define | ADC_EXTERNALTRIG_T3_CC4 (LL_ADC_REG_TRIG_EXT_TIM3_CH4) |
| #define | ADC_EXTERNALTRIG_HR1_ADCTRG1 (LL_ADC_REG_TRIG_EXT_HRTIM_TRG1) |
| #define | ADC_EXTERNALTRIG_HR1_ADCTRG3 (LL_ADC_REG_TRIG_EXT_HRTIM_TRG3) |
| #define | ADC_EXTERNALTRIG_LPTIM1_OUT (LL_ADC_REG_TRIG_EXT_LPTIM1_OUT) |
| #define | ADC_EXTERNALTRIG_LPTIM2_OUT (LL_ADC_REG_TRIG_EXT_LPTIM2_OUT) |
| #define | ADC_EXTERNALTRIG_LPTIM3_OUT (LL_ADC_REG_TRIG_EXT_LPTIM3_OUT) |
| #define ADC_EXTERNALTRIG_EXT_IT11 (LL_ADC_REG_TRIG_EXT_EXTI_LINE11) |
ADC group regular conversion trigger from external peripheral: external interrupt line 11 event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_HR1_ADCTRG1 (LL_ADC_REG_TRIG_EXT_HRTIM_TRG1) |
ADC group regular conversion trigger from external peripheral: HRTIM TRG1 event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_HR1_ADCTRG3 (LL_ADC_REG_TRIG_EXT_HRTIM_TRG3) |
ADC group regular conversion trigger from external peripheral: HRTIM TRG3 event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_LPTIM1_OUT (LL_ADC_REG_TRIG_EXT_LPTIM1_OUT) |
ADC group regular conversion trigger from external peripheral: LPTIM1 OUT event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_LPTIM2_OUT (LL_ADC_REG_TRIG_EXT_LPTIM2_OUT) |
ADC group regular conversion trigger from external peripheral: LPTIM2 OUT event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_LPTIM3_OUT (LL_ADC_REG_TRIG_EXT_LPTIM3_OUT) |
ADC group regular conversion trigger from external peripheral: LPTIM3 event OUT. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T15_TRGO (LL_ADC_REG_TRIG_EXT_TIM15_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM15 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T1_CC1 (LL_ADC_REG_TRIG_EXT_TIM1_CH1) |
ADC group regular conversion trigger from external peripheral: TIM1 channel 1 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T1_CC2 (LL_ADC_REG_TRIG_EXT_TIM1_CH2) |
ADC group regular conversion trigger from external peripheral: TIM1 channel 2 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T1_CC3 (LL_ADC_REG_TRIG_EXT_TIM1_CH3) |
ADC group regular conversion trigger from external peripheral: TIM1 channel 3 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T1_TRGO (LL_ADC_REG_TRIG_EXT_TIM1_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM1 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T1_TRGO2 (LL_ADC_REG_TRIG_EXT_TIM1_TRGO2) |
ADC group regular conversion trigger from external peripheral: TIM1 TRGO2 event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T2_CC2 (LL_ADC_REG_TRIG_EXT_TIM2_CH2) |
ADC group regular conversion trigger from external peripheral: TIM2 channel 2 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T2_TRGO (LL_ADC_REG_TRIG_EXT_TIM2_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM2 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T3_CC4 (LL_ADC_REG_TRIG_EXT_TIM3_CH4) |
ADC group regular conversion trigger from external peripheral: TIM3 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T3_TRGO (LL_ADC_REG_TRIG_EXT_TIM3_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM3 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T4_CC4 (LL_ADC_REG_TRIG_EXT_TIM4_CH4) |
ADC group regular conversion trigger from external peripheral: TIM4 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T4_TRGO (LL_ADC_REG_TRIG_EXT_TIM4_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM4 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T6_TRGO (LL_ADC_REG_TRIG_EXT_TIM6_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM6 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T8_TRGO (LL_ADC_REG_TRIG_EXT_TIM8_TRGO) |
ADC group regular conversion trigger from external peripheral: TIM8 TRGO event. Trigger edge set to rising edge (default setting).
| #define ADC_EXTERNALTRIG_T8_TRGO2 (LL_ADC_REG_TRIG_EXT_TIM8_TRGO2) |
ADC group regular conversion trigger from external peripheral: TIM8 TRGO2 event. Trigger edge set to rising edge (default setting).
| #define ADC_SOFTWARE_START (LL_ADC_REG_TRIG_SOFTWARE) |
ADC group regular conversion trigger internal: SW start.
