RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
grethgbit-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2021 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
37
* This file is part of the RTEMS quality process and was automatically
38
* generated. If you find something that needs to be fixed or
39
* worded better please post a report or patch to an RTEMS mailing list
40
* or raise a bug report:
41
42
* https://www.rtems.org/bugs.html
43
44
* For information on updating and regenerating please refer to the How-To
45
* section in the Software Requirements Engineering chapter of the
46
* RTEMS Software Engineering manual. The manual is provided as a part of
47
* a release. For development sources please refer to the online
48
* documentation at:
49
50
* https://docs.rtems.org
51
52
53
/* Generated from spec:/dev/grlib/if/grethgbit-header */
54
55
#ifndef _GRLIB_GRETHGBIT_REGS_H
56
#define _GRLIB_GRETHGBIT_REGS_H
57
58
#include <stdint.h>
59
60
#ifdef __cplusplus
61
extern
"C"
62
#endif
63
64
/* Generated from spec:/dev/grlib/if/grethgbit */
65
75
83
84
#define GRETHGBIT_CR_EA 0x80000000U
85
86
#define GRETHGBIT_CR_BS_SHIFT 28
87
#define GRETHGBIT_CR_BS_MASK 0x70000000U
88
#define GRETHGBIT_CR_BS_GET( _reg ) \
89
( ( ( _reg ) & GRETHGBIT_CR_BS_MASK ) >> \
90
GRETHGBIT_CR_BS_SHIFT )
91
#define GRETHGBIT_CR_BS_SET( _reg, _val ) \
92
( ( ( _reg ) & ~GRETHGBIT_CR_BS_MASK ) | \
93
( ( ( _val ) << GRETHGBIT_CR_BS_SHIFT ) & \
94
GRETHGBIT_CR_BS_MASK ) )
95
#define GRETHGBIT_CR_BS( _val ) \
96
97
98
99
#define GRETHGBIT_CR_GA 0x8000000U
100
101
#define GRETHGBIT_CR_MA 0x4000000U
102
103
#define GRETHGBIT_CR_MC 0x2000000U
104
105
#define GRETHGBIT_CR_ED 0x4000U
106
107
#define GRETHGBIT_CR_RD 0x2000U
108
109
#define GRETHGBIT_CR_DD 0x1000U
110
111
#define GRETHGBIT_CR_ME 0x800U
112
113
#define GRETHGBIT_CR_PI 0x400U
114
115
#define GRETHGBIT_CR_BM 0x200U
116
117
#define GRETHGBIT_CR_GB 0x100U
118
119
#define GRETHGBIT_CR_SP 0x80U
120
121
#define GRETHGBIT_CR_RS 0x40U
122
123
#define GRETHGBIT_CR_PM 0x20U
124
125
#define GRETHGBIT_CR_FD 0x10U
126
127
#define GRETHGBIT_CR_RI 0x8U
128
129
#define GRETHGBIT_CR_TI 0x4U
130
131
#define GRETHGBIT_CR_RE 0x2U
132
133
#define GRETHGBIT_CR_TE 0x1U
134
136
144
145
#define GRETHGBIT_SR_PS 0x100U
146
147
#define GRETHGBIT_SR_IA 0x80U
148
149
#define GRETHGBIT_SR_TS 0x40U
150
151
#define GRETHGBIT_SR_TA 0x20U
152
153
#define GRETHGBIT_SR_RA 0x10U
154
155
#define GRETHGBIT_SR_TI 0x8U
156
157
#define GRETHGBIT_SR_RI 0x4U
158
159
#define GRETHGBIT_SR_TE 0x2U
160
161
#define GRETHGBIT_SR_RE 0x1U
162
164
172
173
#define GRETHGBIT_MACMSB_MSB_SHIFT 0
174
#define GRETHGBIT_MACMSB_MSB_MASK 0xffffU
175
#define GRETHGBIT_MACMSB_MSB_GET( _reg ) \
176
( ( ( _reg ) & GRETHGBIT_MACMSB_MSB_MASK ) >> \
177
GRETHGBIT_MACMSB_MSB_SHIFT )
178
#define GRETHGBIT_MACMSB_MSB_SET( _reg, _val ) \
179
( ( ( _reg ) & ~GRETHGBIT_MACMSB_MSB_MASK ) | \
180
( ( ( _val ) << GRETHGBIT_MACMSB_MSB_SHIFT ) & \
181
GRETHGBIT_MACMSB_MSB_MASK ) )
182
#define GRETHGBIT_MACMSB_MSB( _val ) \
183
184
185
187
195
196
#define GRETHGBIT_MACLSB_LSB_SHIFT 0
197
#define GRETHGBIT_MACLSB_LSB_MASK 0xffffffffU
198
#define GRETHGBIT_MACLSB_LSB_GET( _reg ) \
199
( ( ( _reg ) & GRETHGBIT_MACLSB_LSB_MASK ) >> \
200
GRETHGBIT_MACLSB_LSB_SHIFT )
201
#define GRETHGBIT_MACLSB_LSB_SET( _reg, _val ) \
202
( ( ( _reg ) & ~GRETHGBIT_MACLSB_LSB_MASK ) | \
203
( ( ( _val ) << GRETHGBIT_MACLSB_LSB_SHIFT ) & \
204
GRETHGBIT_MACLSB_LSB_MASK ) )
205
#define GRETHGBIT_MACLSB_LSB( _val ) \
206
207
208
210
218
219
#define GRETHGBIT_MDIO_DATA_SHIFT 16
220
#define GRETHGBIT_MDIO_DATA_MASK 0xffff0000U
221
#define GRETHGBIT_MDIO_DATA_GET( _reg ) \
222
( ( ( _reg ) & GRETHGBIT_MDIO_DATA_MASK ) >> \
223
GRETHGBIT_MDIO_DATA_SHIFT )
224
#define GRETHGBIT_MDIO_DATA_SET( _reg, _val ) \
225
( ( ( _reg ) & ~GRETHGBIT_MDIO_DATA_MASK ) | \
226
( ( ( _val ) << GRETHGBIT_MDIO_DATA_SHIFT ) & \
227
GRETHGBIT_MDIO_DATA_MASK ) )
228
#define GRETHGBIT_MDIO_DATA( _val ) \
229
230
231
232
#define GRETHGBIT_MDIO_PHYADDR_SHIFT 11
233
#define GRETHGBIT_MDIO_PHYADDR_MASK 0xf800U
234
#define GRETHGBIT_MDIO_PHYADDR_GET( _reg ) \
235
( ( ( _reg ) & GRETHGBIT_MDIO_PHYADDR_MASK ) >> \
236
GRETHGBIT_MDIO_PHYADDR_SHIFT )
237
#define GRETHGBIT_MDIO_PHYADDR_SET( _reg, _val ) \
238
( ( ( _reg ) & ~GRETHGBIT_MDIO_PHYADDR_MASK ) | \
239
( ( ( _val ) << GRETHGBIT_MDIO_PHYADDR_SHIFT ) & \
240
GRETHGBIT_MDIO_PHYADDR_MASK ) )
241
#define GRETHGBIT_MDIO_PHYADDR( _val ) \
242
243
244
245
#define GRETHGBIT_MDIO_REGADDR_SHIFT 6
246
#define GRETHGBIT_MDIO_REGADDR_MASK 0x7c0U
247
#define GRETHGBIT_MDIO_REGADDR_GET( _reg ) \
248
( ( ( _reg ) & GRETHGBIT_MDIO_REGADDR_MASK ) >> \
249
GRETHGBIT_MDIO_REGADDR_SHIFT )
250
#define GRETHGBIT_MDIO_REGADDR_SET( _reg, _val ) \
251
( ( ( _reg ) & ~GRETHGBIT_MDIO_REGADDR_MASK ) | \
252
( ( ( _val ) << GRETHGBIT_MDIO_REGADDR_SHIFT ) & \
253
GRETHGBIT_MDIO_REGADDR_MASK ) )
254
#define GRETHGBIT_MDIO_REGADDR( _val ) \
255
256
257
258
#define GRETHGBIT_MDIO_BU 0x8U
259
260
#define GRETHGBIT_MDIO_LF 0x4U
261
262
#define GRETHGBIT_MDIO_RD 0x2U
263
264
#define GRETHGBIT_MDIO_WR 0x1U
265
267
276
277
#define GRETHGBIT_TDTBA_BASEADDR_SHIFT 10
278
#define GRETHGBIT_TDTBA_BASEADDR_MASK 0xfffffc00U
279
#define GRETHGBIT_TDTBA_BASEADDR_GET( _reg ) \
280
( ( ( _reg ) & GRETHGBIT_TDTBA_BASEADDR_MASK ) >> \
281
GRETHGBIT_TDTBA_BASEADDR_SHIFT )
282
#define GRETHGBIT_TDTBA_BASEADDR_SET( _reg, _val ) \
283
( ( ( _reg ) & ~GRETHGBIT_TDTBA_BASEADDR_MASK ) | \
284
( ( ( _val ) << GRETHGBIT_TDTBA_BASEADDR_SHIFT ) & \
285
GRETHGBIT_TDTBA_BASEADDR_MASK ) )
286
#define GRETHGBIT_TDTBA_BASEADDR( _val ) \
287
288
289
290
#define GRETHGBIT_TDTBA_DESCPNT_SHIFT 3
291
#define GRETHGBIT_TDTBA_DESCPNT_MASK 0x3f8U
292
#define GRETHGBIT_TDTBA_DESCPNT_GET( _reg ) \
293
( ( ( _reg ) & GRETHGBIT_TDTBA_DESCPNT_MASK ) >> \
294
GRETHGBIT_TDTBA_DESCPNT_SHIFT )
295
#define GRETHGBIT_TDTBA_DESCPNT_SET( _reg, _val ) \
296
( ( ( _reg ) & ~GRETHGBIT_TDTBA_DESCPNT_MASK ) | \
297
( ( ( _val ) << GRETHGBIT_TDTBA_DESCPNT_SHIFT ) & \
298
GRETHGBIT_TDTBA_DESCPNT_MASK ) )
299
#define GRETHGBIT_TDTBA_DESCPNT( _val ) \
300
301
302
304
313
314
#define GRETHGBIT_RDTBA_BASEADDR_SHIFT 10
315
#define GRETHGBIT_RDTBA_BASEADDR_MASK 0xfffffc00U
316
#define GRETHGBIT_RDTBA_BASEADDR_GET( _reg ) \
317
( ( ( _reg ) & GRETHGBIT_RDTBA_BASEADDR_MASK ) >> \
318
GRETHGBIT_RDTBA_BASEADDR_SHIFT )
319
#define GRETHGBIT_RDTBA_BASEADDR_SET( _reg, _val ) \
320
( ( ( _reg ) & ~GRETHGBIT_RDTBA_BASEADDR_MASK ) | \
321
( ( ( _val ) << GRETHGBIT_RDTBA_BASEADDR_SHIFT ) & \
322
GRETHGBIT_RDTBA_BASEADDR_MASK ) )
323
#define GRETHGBIT_RDTBA_BASEADDR( _val ) \
324
325
326
327
#define GRETHGBIT_RDTBA_DESCPNT_SHIFT 3
328
#define GRETHGBIT_RDTBA_DESCPNT_MASK 0x3f8U
329
#define GRETHGBIT_RDTBA_DESCPNT_GET( _reg ) \
330
( ( ( _reg ) & GRETHGBIT_RDTBA_DESCPNT_MASK ) >> \
331
GRETHGBIT_RDTBA_DESCPNT_SHIFT )
332
#define GRETHGBIT_RDTBA_DESCPNT_SET( _reg, _val ) \
333
( ( ( _reg ) & ~GRETHGBIT_RDTBA_DESCPNT_MASK ) | \
334
( ( ( _val ) << GRETHGBIT_RDTBA_DESCPNT_SHIFT ) & \
335
GRETHGBIT_RDTBA_DESCPNT_MASK ) )
336
#define GRETHGBIT_RDTBA_DESCPNT( _val ) \
337
338
339
341
349
350
#define GRETHGBIT_EDCLMACMSB_MSB_SHIFT 0
351
#define GRETHGBIT_EDCLMACMSB_MSB_MASK 0xffffU
352
#define GRETHGBIT_EDCLMACMSB_MSB_GET( _reg ) \
353
( ( ( _reg ) & GRETHGBIT_EDCLMACMSB_MSB_MASK ) >> \
354
GRETHGBIT_EDCLMACMSB_MSB_SHIFT )
355
#define GRETHGBIT_EDCLMACMSB_MSB_SET( _reg, _val ) \
356
( ( ( _reg ) & ~GRETHGBIT_EDCLMACMSB_MSB_MASK ) | \
357
( ( ( _val ) << GRETHGBIT_EDCLMACMSB_MSB_SHIFT ) & \
358
GRETHGBIT_EDCLMACMSB_MSB_MASK ) )
359
#define GRETHGBIT_EDCLMACMSB_MSB( _val ) \
360
361
362
364
372
373
#define GRETHGBIT_EDCLMACLSB_LSB_SHIFT 0
374
#define GRETHGBIT_EDCLMACLSB_LSB_MASK 0xffffffffU
375
#define GRETHGBIT_EDCLMACLSB_LSB_GET( _reg ) \
376
( ( ( _reg ) & GRETHGBIT_EDCLMACLSB_LSB_MASK ) >> \
377
GRETHGBIT_EDCLMACLSB_LSB_SHIFT )
378
#define GRETHGBIT_EDCLMACLSB_LSB_SET( _reg, _val ) \
379
( ( ( _reg ) & ~GRETHGBIT_EDCLMACLSB_LSB_MASK ) | \
380
( ( ( _val ) << GRETHGBIT_EDCLMACLSB_LSB_SHIFT ) & \
381
GRETHGBIT_EDCLMACLSB_LSB_MASK ) )
382
#define GRETHGBIT_EDCLMACLSB_LSB( _val ) \
383
384
385
387
391
typedef
struct
grethgbit
395
uint32_t
cr
396
400
uint32_t
sr
401
405
uint32_t
macmsb
406
410
uint32_t
maclsb
411
415
uint32_t
mdio
416
420
uint32_t
tdtba
421
425
uint32_t
rdtba
426
427
uint32_t reserved_1c_28[ 3 ];
428
432
uint32_t
edclmacmsb
433
437
uint32_t
edclmaclsb
438
grethgbit
439
441
442
#ifdef __cplusplus
443
444
#endif
445
446
#endif
/* _GRLIB_GRETHGBIT_REGS_H */
grethgbit
This structure defines the GRETH_GBIT register block memory map.
Definition
grethgbit-regs.h:391
grethgbit::tdtba
uint32_t tdtba
See transmitter descriptor table base address register. (TDTBA).
Definition
grethgbit-regs.h:420
grethgbit::sr
uint32_t sr
See status register. (SR).
Definition
grethgbit-regs.h:400
grethgbit::edclmaclsb
uint32_t edclmaclsb
See EDCL MAC address LSB. (EDCLMACLSB).
Definition
grethgbit-regs.h:437
grethgbit::mdio
uint32_t mdio
See MDIO control/status register. (MDIO).
Definition
grethgbit-regs.h:415
grethgbit::cr
uint32_t cr
See control register (CR).
Definition
grethgbit-regs.h:395
grethgbit::rdtba
uint32_t rdtba
See receiver descriptor table base address register. (RDTBA).
Definition
grethgbit-regs.h:425
grethgbit::maclsb
uint32_t maclsb
See MAC address LSB. (MACLSB).
Definition
grethgbit-regs.h:410
grethgbit::macmsb
uint32_t macmsb
See MAC address MSB. (MACMSB).
Definition
grethgbit-regs.h:405
grethgbit::edclmacmsb
uint32_t edclmacmsb
See EDCL MAC address MSB. (EDCLMACMSB).
Definition
grethgbit-regs.h:432
