RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
grclkgate-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2021 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
37
* This file is part of the RTEMS quality process and was automatically
38
* generated. If you find something that needs to be fixed or
39
* worded better please post a report or patch to an RTEMS mailing list
40
* or raise a bug report:
41
42
* https://www.rtems.org/bugs.html
43
44
* For information on updating and regenerating please refer to the How-To
45
* section in the Software Requirements Engineering chapter of the
46
* RTEMS Software Engineering manual. The manual is provided as a part of
47
* a release. For development sources please refer to the online
48
* documentation at:
49
50
* https://docs.rtems.org
51
52
53
/* Generated from spec:/dev/grlib/if/grclkgate-header */
54
55
#ifndef _GRLIB_GRCLKGATE_REGS_H
56
#define _GRLIB_GRCLKGATE_REGS_H
57
58
#include <stdint.h>
59
60
#ifdef __cplusplus
61
extern
"C"
62
#endif
63
64
/* Generated from spec:/dev/grlib/if/grclkgate */
65
75
83
84
#define GRCLKGATE_UNLOCK_UNLOCK_SHIFT 0
85
#define GRCLKGATE_UNLOCK_UNLOCK_MASK 0xffffffffU
86
#define GRCLKGATE_UNLOCK_UNLOCK_GET( _reg ) \
87
( ( ( _reg ) & GRCLKGATE_UNLOCK_UNLOCK_MASK ) >> \
88
GRCLKGATE_UNLOCK_UNLOCK_SHIFT )
89
#define GRCLKGATE_UNLOCK_UNLOCK_SET( _reg, _val ) \
90
( ( ( _reg ) & ~GRCLKGATE_UNLOCK_UNLOCK_MASK ) | \
91
( ( ( _val ) << GRCLKGATE_UNLOCK_UNLOCK_SHIFT ) & \
92
GRCLKGATE_UNLOCK_UNLOCK_MASK ) )
93
#define GRCLKGATE_UNLOCK_UNLOCK( _val ) \
94
95
96
98
106
107
#define GRCLKGATE_CLKEN_ENABLE_SHIFT 0
108
#define GRCLKGATE_CLKEN_ENABLE_MASK 0xffffffffU
109
#define GRCLKGATE_CLKEN_ENABLE_GET( _reg ) \
110
( ( ( _reg ) & GRCLKGATE_CLKEN_ENABLE_MASK ) >> \
111
GRCLKGATE_CLKEN_ENABLE_SHIFT )
112
#define GRCLKGATE_CLKEN_ENABLE_SET( _reg, _val ) \
113
( ( ( _reg ) & ~GRCLKGATE_CLKEN_ENABLE_MASK ) | \
114
( ( ( _val ) << GRCLKGATE_CLKEN_ENABLE_SHIFT ) & \
115
GRCLKGATE_CLKEN_ENABLE_MASK ) )
116
#define GRCLKGATE_CLKEN_ENABLE( _val ) \
117
118
119
121
129
130
#define GRCLKGATE_RESET_RESET_SHIFT 0
131
#define GRCLKGATE_RESET_RESET_MASK 0xffffffffU
132
#define GRCLKGATE_RESET_RESET_GET( _reg ) \
133
( ( ( _reg ) & GRCLKGATE_RESET_RESET_MASK ) >> \
134
GRCLKGATE_RESET_RESET_SHIFT )
135
#define GRCLKGATE_RESET_RESET_SET( _reg, _val ) \
136
( ( ( _reg ) & ~GRCLKGATE_RESET_RESET_MASK ) | \
137
( ( ( _val ) << GRCLKGATE_RESET_RESET_SHIFT ) & \
138
GRCLKGATE_RESET_RESET_MASK ) )
139
#define GRCLKGATE_RESET_RESET( _val ) \
140
141
142
144
152
153
#define GRCLKGATE_OVERRIDE_FOVERRIDE_SHIFT 16
154
#define GRCLKGATE_OVERRIDE_FOVERRIDE_MASK 0xf0000U
155
#define GRCLKGATE_OVERRIDE_FOVERRIDE_GET( _reg ) \
156
( ( ( _reg ) & GRCLKGATE_OVERRIDE_FOVERRIDE_MASK ) >> \
157
GRCLKGATE_OVERRIDE_FOVERRIDE_SHIFT )
158
#define GRCLKGATE_OVERRIDE_FOVERRIDE_SET( _reg, _val ) \
159
( ( ( _reg ) & ~GRCLKGATE_OVERRIDE_FOVERRIDE_MASK ) | \
160
( ( ( _val ) << GRCLKGATE_OVERRIDE_FOVERRIDE_SHIFT ) & \
161
GRCLKGATE_OVERRIDE_FOVERRIDE_MASK ) )
162
#define GRCLKGATE_OVERRIDE_FOVERRIDE( _val ) \
163
164
165
166
#define GRCLKGATE_OVERRIDE_OVERRIDE_SHIFT 0
167
#define GRCLKGATE_OVERRIDE_OVERRIDE_MASK 0xfU
168
#define GRCLKGATE_OVERRIDE_OVERRIDE_GET( _reg ) \
169
( ( ( _reg ) & GRCLKGATE_OVERRIDE_OVERRIDE_MASK ) >> \
170
GRCLKGATE_OVERRIDE_OVERRIDE_SHIFT )
171
#define GRCLKGATE_OVERRIDE_OVERRIDE_SET( _reg, _val ) \
172
( ( ( _reg ) & ~GRCLKGATE_OVERRIDE_OVERRIDE_MASK ) | \
173
( ( ( _val ) << GRCLKGATE_OVERRIDE_OVERRIDE_SHIFT ) & \
174
GRCLKGATE_OVERRIDE_OVERRIDE_MASK ) )
175
#define GRCLKGATE_OVERRIDE_OVERRIDE( _val ) \
176
177
178
180
184
typedef
struct
grclkgate
188
uint32_t
unlock
189
193
uint32_t
clken
194
198
uint32_t
reset
199
203
uint32_t
override
204
grclkgate
205
207
208
#ifdef __cplusplus
209
210
#endif
211
212
#endif
/* _GRLIB_GRCLKGATE_REGS_H */
grclkgate
This structure defines the GRCLKGATE register block memory map.
Definition
grclkgate-regs.h:184
grclkgate::unlock
uint32_t unlock
See Unlock register (UNLOCK).
Definition
grclkgate-regs.h:188
grclkgate::clken
uint32_t clken
See Clock enable register (CLKEN).
Definition
grclkgate-regs.h:193
grclkgate::reset
uint32_t reset
See Reset register (RESET).
Definition
grclkgate-regs.h:198
