RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
grascs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Header file for GRASCS RTEMS driver
5
6
* COPYRIGHT (c) 2008.
7
* Cobham Gaisler AB.
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
18
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28
* POSSIBILITY OF SUCH DAMAGE.
29
30
31
#ifndef __GRASCS_H__
32
#define __GRASCS_H__
33
34
#ifdef __cplusplus
35
extern
"C"
36
#endif
37
38
/* Minimum and maximum system frequency */
39
#define GRASCS_MIN_SFREQ 10000
40
#define GRASCS_MAX_SFREQ 255000
41
42
/* Default, minimum and maximum ETR pulse frequency */
43
#define GRASCS_DEFAULT_ETRFREQ 10
44
#define GRASCS_MIN_ETRFREQ 1
45
#define GRASCS_MAX_ETRFREQ 100
46
47
/* Maximum number of external time markers */
48
#define GRASCS_MAX_TMS 6
49
50
/* Error codes */
51
#define GRASCS_ERROR_STARTSTOP 1
/* Serial/synch interface is running/stopped */
52
#define GRASCS_ERROR_TRANSACTIVE 2
/* Busy with transaction */
53
#define GRASCS_ERROR_CAPFAULT 3
/* Core capabilities prohibit request */
54
55
/* Command register */
56
#define GRASCS_CMD_RESET (1 << 0)
57
#define GRASCS_CMD_STARTSTOP (1 << 1)
58
#define GRASCS_CMD_ESTARTSTOP (1 << 2)
59
#define GRASCS_CMD_SENDTM (1 << 3)
60
#define GRASCS_CMD_ETRCTRL (7 << 4)
61
#define GRASCS_CMD_ETRCTRL_BITS 4
62
#define GRASCS_CMD_SLAVESEL (15 << 8)
63
#define GRASCS_CMD_SLAVESEL_BITS 8
64
#define GRASCS_CMD_TCDONE (1 << 12)
65
#define GRASCS_CMD_TMDONE (1 << 13)
66
#define GRASCS_CMD_US1 (255 << 16)
67
#define GRASCS_CMD_US1_BITS 16
68
#define GRASCS_CMD_US1C (1 << 24)
69
70
/* Clock scale register */
71
#define GRASCS_CLK_ETRFREQ_BITS 12
72
73
/* Status register */
74
#define GRASCS_STS_RUNNING (1 << 0)
75
#define GRASCS_STS_ERUNNING (1 << 1)
76
#define GRASCS_STS_TCDONE (1 << 4)
77
#define GRASCS_STS_TMDONE (1 << 5)
78
#define GRASCS_STS_DBITS_BITS 8
79
#define GRASCS_STS_NSLAVES_BITS 13
80
#define GRASCS_STS_USCONF_BITS 18
81
#define GRASCS_STS_TMCONF_BITS 19
82
83
extern
int
ASCS_init(
void
84
85
extern
int
ASCS_input_select(
int
slave);
86
87
extern
int
ASCS_etr_select(
int
etr,
int
freq);
88
89
extern
void
ASCS_start(
void
90
91
extern
void
ASCS_stop(
void
92
93
extern
int
ASCS_iface_status(
void
94
95
extern
int
ASCS_TC_send(
int
*word);
96
97
extern
int
ASCS_TC_send_block(
int
*block,
int
ntrans);
98
99
extern
void
ASCS_TC_sync_start(
void
100
101
extern
void
ASCS_TC_sync_stop(
void
102
103
extern
int
ASCS_TM_recv(
int
*word);
104
105
extern
int
ASCS_TM_recv_block(
int
*block,
int
ntrans);
106
107
#ifdef __cplusplus
108
109
#endif
110
111
#endif
