RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
gradcdac.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* ADC / DAC (GRADCDAC) interface
4
5
* COPYRIGHT (c) 2009.
6
* Cobham Gaisler AB.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
17
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27
* POSSIBILITY OF SUCH DAMAGE.
28
29
30
#ifndef __GRADCDAC_H__
31
#define __GRADCDAC_H__
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
36
37
struct
gradcdac_regs
38
volatile
unsigned
int
config;
/* 0x00 Configuration Register */
39
volatile
unsigned
int
status;
/* 0x04 Status Register */
40
int
unused0[2];
41
volatile
unsigned
int
adc_din;
/* 0x10 ADC Data Input Register */
42
volatile
unsigned
int
dac_dout;
/* 0x14 DAC Data Output Register */
43
int
unused1[2];
44
volatile
unsigned
int
adrin;
/* 0x20 Address Input Register */
45
volatile
unsigned
int
adrout;
/* 0x24 Address Output Register */
46
volatile
unsigned
int
adrdir;
/* 0x28 Address Direction Register */
47
int
unused2[1];
48
volatile
unsigned
int
data_in;
/* 0x30 Data Input Register */
49
volatile
unsigned
int
data_out;
/* 0x34 Data Output Register */
50
volatile
unsigned
int
data_dir;
/* 0x38 Data Direction Register */
51
52
53
#define GRADCDAC_CFG_DACWS 0x00f80000
54
#define GRADCDAC_CFG_WRPOL 0x00040000
55
#define GRADCDAC_CFG_DACDW 0x00030000
56
#define GRADCDAC_CFG_ADCWS 0x0000f800
57
#define GRADCDAC_CFG_RCPOL 0x00000400
58
#define GRADCDAC_CFG_CSMODE 0x00000300
59
#define GRADCDAC_CFG_CSPOL 0x00000080
60
#define GRADCDAC_CFG_RDYMODE 0x00000040
61
#define GRADCDAC_CFG_RDYPOL 0x00000020
62
#define GRADCDAC_CFG_TRIGPOL 0x00000010
63
#define GRADCDAC_CFG_TRIGMODE 0x0000000c
64
#define GRADCDAC_CFG_ADCDW 0x00000003
65
66
#define GRADCDAC_CFG_DACWS_BIT 19
67
#define GRADCDAC_CFG_WRPOL_BIT 18
68
#define GRADCDAC_CFG_DACDW_BIT 16
69
#define GRADCDAC_CFG_ADCWS_BIT 11
70
#define GRADCDAC_CFG_RCPOL_BIT 10
71
#define GRADCDAC_CFG_CSMODE_BIT 8
72
#define GRADCDAC_CFG_CSPOL_BIT 7
73
#define GRADCDAC_CFG_RDYMODE_BIT 6
74
#define GRADCDAC_CFG_RDYPOL_BIT 5
75
#define GRADCDAC_CFG_TRIGPOL_BIT 4
76
#define GRADCDAC_CFG_TRIGMODE_BIT 2
77
#define GRADCDAC_CFG_ADCDW_BIT 0
78
79
#define GRADCDAC_STATUS_DACNO 0x40
80
#define GRADCDAC_STATUS_DACRDY 0x20
81
#define GRADCDAC_STATUS_DACON 0x10
82
#define GRADCDAC_STATUS_ADCTO 0x08
83
#define GRADCDAC_STATUS_ADCNO 0x04
84
#define GRADCDAC_STATUS_ADCRDY 0x02
85
#define GRADCDAC_STATUS_ADCON 0x01
86
87
#define GRADCDAC_STATUS_DACNO_BIT 6
88
#define GRADCDAC_STATUS_DACRDY_BIT 5
89
#define GRADCDAC_STATUS_DACON_BIT 4
90
#define GRADCDAC_STATUS_ADCTO_BIT 3
91
#define GRADCDAC_STATUS_ADCNO_BIT 2
92
#define GRADCDAC_STATUS_ADCRDY_BIT 1
93
#define GRADCDAC_STATUS_ADCON_BIT 0
94
95
#define GRADCDAC_IRQ_DAC 1
96
#define GRADCDAC_IRQ_ADC 0
97
98
struct
gradcdac_config
99
unsigned
char
dac_ws;
100
char
wr_pol;
101
unsigned
char
dac_dw;
102
unsigned
char
adc_ws;
103
char
rc_pol;
104
unsigned
char
cs_mode;
105
char
cs_pol;
106
char
ready_mode;
107
char
ready_pol;
108
char
trigg_pol;
109
unsigned
char
trigg_mode;
110
unsigned
char
adc_dw;
111
112
113
extern
void
*gradcdac_open(
char
*devname);
114
115
extern
void
gradcdac_set_config(
void
*cookie,
struct
gradcdac_config
*cfg);
116
117
extern
void
gradcdac_get_config(
void
*cookie,
struct
gradcdac_config
*cfg);
118
119
extern
void
gradcdac_set_cfg(
void
*cookie,
unsigned
int
config);
120
121
extern
unsigned
int
gradcdac_get_cfg(
void
*cookie);
122
123
extern
unsigned
int
gradcdac_get_status(
void
*cookie);
124
125
static
int
__inline__ gradcdac_DAC_ReqRej(
unsigned
int
status)
126
127
return
(status & GRADCDAC_STATUS_DACNO);
128
129
130
static
int
__inline__ gradcdac_DAC_isCompleted(
unsigned
int
status)
131
132
return
(status & GRADCDAC_STATUS_DACRDY);
133
134
135
static
int
__inline__ gradcdac_DAC_isOngoing(
unsigned
int
status)
136
137
return
(status & GRADCDAC_STATUS_DACON);
138
139
140
static
int
__inline__ gradcdac_ADC_isTimeouted(
unsigned
int
status)
141
142
return
(status & GRADCDAC_STATUS_ADCTO);
143
144
145
static
int
__inline__ gradcdac_ADC_ReqRej(
unsigned
int
status)
146
147
return
(status & GRADCDAC_STATUS_ADCNO);
148
149
150
static
int
__inline__ gradcdac_ADC_isCompleted(
unsigned
int
status)
151
152
return
(status & GRADCDAC_STATUS_ADCRDY);
153
154
155
static
int
__inline__ gradcdac_ADC_isOngoing(
unsigned
int
status)
156
157
return
(status & GRADCDAC_STATUS_ADCON);
158
159
160
#define GRADCDAC_ISR_BOTH 3
161
#define GRADCDAC_ISR_DAC 2
162
#define GRADCDAC_ISR_ADC 1
163
164
/* Install IRQ handler for ADC and/or DAC interrupt.
165
* The installed IRQ handler(ISR) must read the status
166
* register to clear the pending interrupt avoiding multiple
167
* entries to the ISR caused by the same IRQ.
168
169
* \param adc 1=ADC interrupt, 2=ADC interrupt, 3=ADC and DAC interrupt
170
* \param isr Interrupt service routine called when IRQ is fired
171
* \param arg custom argument passed to ISR when called.
172
173
extern
int
gradcdac_install_irq_handler
174
void
*cookie,
int
adc,
void
(*isr)(
void
*cookie,
void
*arg),
void
*arg);
175
176
extern
void
gradcdac_uninstall_irq_handler(
void
*cookie,
int
adc);
177
178
/* Make the ADC circuitry initialize a analogue to digital
179
* conversion. The result can be read out by gradcdac_adc_convert_try
180
* or gradcdac_adc_convert.
181
182
extern
void
gradcdac_adc_convert_start(
void
*cookie);
183
184
/* Tries to read the conversion result. If the circuitry is busy
185
* converting the function return a non-zero value, if the conversion
186
* has successfully finished the function return zero.
187
188
* \param digital_value the resulting converted value is placed here
189
* \return zero = ADC conversion complete, digital_value contain current conversion result
190
* positive = ADC busy, digital_value contain previous conversion result
191
* negative = Conversion request failed.
192
193
extern
int
gradcdac_adc_convert_try(
void
*cookie,
unsigned
short
*digital_value);
194
195
/* Waits until the ADC circuity has finished a digital to analogue
196
* conversion. The Waiting is implemented as a busy loop utilizing
197
* 100% CPU load.
198
199
* \return zero = Conversion ok
200
201
202
extern
int
gradcdac_adc_convert(
void
*cookie,
unsigned
short
*digital_value);
203
204
/* Try to make the DAC circuitry initialize a digital to analogue
205
* conversion. If the circuitry is busy by a previous conversion
206
* the function return a non-zero value, if the conversion is
207
* successfully initialized the function return zero.
208
209
extern
int
gradcdac_dac_convert_try(
void
*cookie,
unsigned
short
digital_value);
210
211
/* Initializes a digital to analogue conversion by waiting until
212
* previous conversions is finished before procceding with the
213
214
* 100% CPU load.
215
216
extern
void
gradcdac_dac_convert(
void
*cookie,
unsigned
short
digital_value);
217
218
extern
unsigned
int
gradcdac_get_adrinput(
void
*cookie);
219
extern
void
gradcdac_set_adrinput(
void
*cookie,
unsigned
int
input);
220
221
extern
unsigned
int
gradcdac_get_adroutput(
void
*cookie);
222
extern
void
gradcdac_set_adroutput(
void
*cookie,
unsigned
int
output);
223
224
extern
unsigned
int
gradcdac_get_adrdir(
void
*cookie);
225
extern
void
gradcdac_set_adrdir(
void
*cookie,
unsigned
int
dir);
226
227
extern
unsigned
int
gradcdac_get_datainput(
void
*cookie);
228
extern
void
gradcdac_set_datainput(
void
*cookie,
unsigned
int
input);
229
230
extern
unsigned
int
gradcdac_get_dataoutput(
void
*cookie);
231
extern
void
gradcdac_set_dataoutput(
void
*cookie,
unsigned
int
output);
232
233
extern
unsigned
int
gradcdac_get_datadir(
void
*cookie);
234
extern
void
gradcdac_set_datadir(
void
*cookie,
unsigned
int
dir);
235
236
/* Show one or all GRADCDAC cores. If cookie is NULL all GRADCDAC's are shown */
237
extern
void
grAdcDacShow(
void
*cookie);
238
239
/* Register Driver routine */
240
extern
void
gradcdac_register_drv (
void
241
242
#ifdef __cplusplus
243
244
#endif
245
246
#endif
gradcdac_config
Definition
gradcdac.h:98
gradcdac_regs
Definition
gradcdac.h:37
