RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
gr_rasta_tmtc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* GR-RASTA-TMTC PCI Target driver.
4
5
* COPYRIGHT (c) 2008.
6
* Cobham Gaisler AB.
7
8
* Configures the GR-RASTA-TMTC interface PCI board.
9
* This driver provides a AMBA PnP bus by using the general part
10
* of the AMBA PnP bus driver (ambapp_bus.c).
11
12
* Driver resources for the AMBA PnP bus provided can be set using
13
* gr_rasta_tmtc_set_resources().
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef __GR_RASTA_TMTC_H__
38
#define __GR_RASTA_TMTC_H__
39
40
drvmgr/drvmgr.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
/* GPIO TM/TC configuration pin definitions
47
* --31 PWRX (1=PW2APB, 0=TM VC3/4)
48
* --30 PWTC (1=APB2PW, 0=TC MAP1/2)
49
* --29 Redundant TM (1=enable, 0=disable)
50
* --28 Redundant TC (1=enable, 0=disable)
51
* --27 Select TM output (1=GRTM, 0=PTME)
52
* --26 Loop back PW (1=enable, 0=disable)
53
* --25 Transponder clock (1=PLL, 0=PLL bypass)
54
* --24 PWTX-SELECT (0=TX0-0, 1=TX0-1)
55
* --23 PDEC Map Switch (1=on, 0=off)
56
* --22 PDEC Ext CPDU (1=on, 0=off)
57
* --21 PDEC Super User (1=on, 0=off)
58
* --20 PDEC RM On (1=on, 0=off)
59
* --19 PDEC AU Enable (1=on, 0=off)
60
* --18 PDEC Dynamic Mode (1=on, 0=off)
61
* --17 PDEC Priority (1=on, 0=off)
62
* --16 TC PSS Support (1=on, 0=off)
63
* --15 TC Mark (1=on, 0=off)
64
* --14 TC Pseudo (1=on, 0=off)
65
* --13 TC Rising Clock (1=rise, 0=fall)
66
* --12 TC Active High (1=high, 0=low)
67
* --11 Bit Lock Positive (1=high, 0=low)
68
* --10 RF Avail Positive (1=high, 0=low)
69
* -- 9 : 0 SpaceCraft ID
70
71
72
#define GR_TMTC_GPIO_PWRX (1<<31)
73
#define GR_TMTC_GPIO_PWTC (1<<30)
74
#define GR_TMTC_GPIO_RED_TM (1<<29)
75
#define GR_TMTC_GPIO_RED_TC (1<<28)
76
#define GR_TMTC_GPIO_GRTM_SEL (1<<27)
77
#define GR_TMTC_GPIO_LB_PW (1<<26)
78
#define GR_TMTC_GPIO_TRANSP_CLK (1<<25)
79
#define GR_TMTC_GPIO_PWTX_SEL (1<<24)
80
#define GR_TMTC_GPIO_PDEC_MAP (1<<23)
81
#define GR_TMTC_GPIO_PDEC_CPDU (1<<22)
82
#define GR_TMTC_GPIO_PDEC_SU (1<<21)
83
#define GR_TMTC_GPIO_PDEC_RM (1<<20)
84
#define GR_TMTC_GPIO_PDEC_AU (1<<19)
85
#define GR_TMTC_GPIO_PDEC_DYN_MODE (1<<18)
86
#define GR_TMTC_GPIO_PDEC_PRIO (1<<17)
87
#define GR_TMTC_GPIO_TC_PSS (1<<16)
88
#define GR_TMTC_GPIO_TC_MARK (1<<15)
89
#define GR_TMTC_GPIO_TC_PSEUDO (1<<14)
90
#define GR_TMTC_GPIO_TC_RISING_CLK (1<<13)
91
#define GR_TMTC_GPIO_TC_ACTIVE_HIGH (1<<12)
92
#define GR_TMTC_GPIO_TC_BIT_LOCK (1<<11)
93
#define GR_TMTC_GPIO_TC_RF_AVAIL (1<<10)
94
#define GR_TMTC_GPIO_SCID (0x000003ff)
95
96
/* An array of pointers to GR-RASTA-TMTC bus resources. The resources will be
97
* used by the device drivers controlling the cores on the GR-RASTA-IO target
98
* AMBA bus.
99
100
* The array is defined weak, and defaults to no resources. The array must be
101
* terminated with a NULL resource.
102
103
extern
struct
drvmgr_bus_res
*gr_rasta_tmtc_resources[];
104
105
/* Options to gr_rasta_io_print function */
106
#define RASTA_TMTC_OPTIONS_AMBA 0x01
/* Print AMBA bus devices */
107
#define RASTA_TMTC_OPTIONS_IRQ 0x02
/* Print current IRQ setup */
108
109
/* Print information about GR-RASTA-TMTC PCI boards */
110
void
gr_rasta_tmtc_print(
int
options);
111
112
/* Print information about a GR-RASTA-TMTC PCI boards */
113
void
gr_rasta_tmtc_print_dev(
struct
drvmgr_dev
*dev,
int
options);
114
115
/* Register GR-RASTA-TMTC driver */
116
void
gr_rasta_tmtc_register_drv(
void
117
118
#ifdef __cplusplus
119
120
#endif
121
122
#endif
drvmgr.h
Driver Manager Interface.
drvmgr_bus_res
Definition
drvmgr.h:238
drvmgr_dev
Definition
drvmgr.h:299
