RTEMS
6.3
Toggle main menu visibility
bsps
sparc
leon3
include
bsp
gr740-thsens-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2021, 2023 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
38
* This file is part of the RTEMS quality process and was automatically
39
* generated. If you find something that needs to be fixed or
40
* worded better please post a report or patch to an RTEMS mailing list
41
* or raise a bug report:
42
43
* https://www.rtems.org/bugs.html
44
45
* For information on updating and regenerating please refer to the How-To
46
* section in the Software Requirements Engineering chapter of the
47
* RTEMS Software Engineering manual. The manual is provided as a part of
48
* a release. For development sources please refer to the online
49
* documentation at:
50
51
* https://docs.rtems.org
52
53
54
/* Generated from spec:/bsp/sparc/leon3/if/gr740-thsens-header */
55
56
#ifndef _BSP_GR740_THSENS_REGS_H
57
#define _BSP_GR740_THSENS_REGS_H
58
59
#include <stdint.h>
60
61
#ifdef __cplusplus
62
extern
"C"
63
#endif
64
65
/* Generated from spec:/bsp/sparc/leon3/if/gr740-thsens */
66
77
85
86
#define GR740_THSENS_CTRL_DIV_SHIFT 16
87
#define GR740_THSENS_CTRL_DIV_MASK 0x3ff0000U
88
#define GR740_THSENS_CTRL_DIV_GET( _reg ) \
89
( ( ( _reg ) & GR740_THSENS_CTRL_DIV_MASK ) >> \
90
GR740_THSENS_CTRL_DIV_SHIFT )
91
#define GR740_THSENS_CTRL_DIV_SET( _reg, _val ) \
92
( ( ( _reg ) & ~GR740_THSENS_CTRL_DIV_MASK ) | \
93
( ( ( _val ) << GR740_THSENS_CTRL_DIV_SHIFT ) & \
94
GR740_THSENS_CTRL_DIV_MASK ) )
95
#define GR740_THSENS_CTRL_DIV( _val ) \
96
97
98
99
#define GR740_THSENS_CTRL_ALEN 0x100U
100
101
#define GR740_THSENS_CTRL_PDN 0x80U
102
103
#define GR740_THSENS_CTRL_DCORRECT_SHIFT 2
104
#define GR740_THSENS_CTRL_DCORRECT_MASK 0x7cU
105
#define GR740_THSENS_CTRL_DCORRECT_GET( _reg ) \
106
( ( ( _reg ) & GR740_THSENS_CTRL_DCORRECT_MASK ) >> \
107
GR740_THSENS_CTRL_DCORRECT_SHIFT )
108
#define GR740_THSENS_CTRL_DCORRECT_SET( _reg, _val ) \
109
( ( ( _reg ) & ~GR740_THSENS_CTRL_DCORRECT_MASK ) | \
110
( ( ( _val ) << GR740_THSENS_CTRL_DCORRECT_SHIFT ) & \
111
GR740_THSENS_CTRL_DCORRECT_MASK ) )
112
#define GR740_THSENS_CTRL_DCORRECT( _val ) \
113
114
115
116
#define GR740_THSENS_CTRL_SRSTN 0x2U
117
118
#define GR740_THSENS_CTRL_CLKEN 0x1U
119
121
129
130
#define GR740_THSENS_STATUS_MAX_SHIFT 24
131
#define GR740_THSENS_STATUS_MAX_MASK 0x7f000000U
132
#define GR740_THSENS_STATUS_MAX_GET( _reg ) \
133
( ( ( _reg ) & GR740_THSENS_STATUS_MAX_MASK ) >> \
134
GR740_THSENS_STATUS_MAX_SHIFT )
135
#define GR740_THSENS_STATUS_MAX_SET( _reg, _val ) \
136
( ( ( _reg ) & ~GR740_THSENS_STATUS_MAX_MASK ) | \
137
( ( ( _val ) << GR740_THSENS_STATUS_MAX_SHIFT ) & \
138
GR740_THSENS_STATUS_MAX_MASK ) )
139
#define GR740_THSENS_STATUS_MAX( _val ) \
140
141
142
143
#define GR740_THSENS_STATUS_MIN_SHIFT 16
144
#define GR740_THSENS_STATUS_MIN_MASK 0x7f0000U
145
#define GR740_THSENS_STATUS_MIN_GET( _reg ) \
146
( ( ( _reg ) & GR740_THSENS_STATUS_MIN_MASK ) >> \
147
GR740_THSENS_STATUS_MIN_SHIFT )
148
#define GR740_THSENS_STATUS_MIN_SET( _reg, _val ) \
149
( ( ( _reg ) & ~GR740_THSENS_STATUS_MIN_MASK ) | \
150
( ( ( _val ) << GR740_THSENS_STATUS_MIN_SHIFT ) & \
151
GR740_THSENS_STATUS_MIN_MASK ) )
152
#define GR740_THSENS_STATUS_MIN( _val ) \
153
154
155
156
#define GR740_THSENS_STATUS_SCLK 0x8000U
157
158
#define GR740_THSENS_STATUS_WE 0x400U
159
160
#define GR740_THSENS_STATUS_UPD 0x200U
161
162
#define GR740_THSENS_STATUS_ALACT 0x100U
163
164
#define GR740_THSENS_STATUS_DATA_SHIFT 0
165
#define GR740_THSENS_STATUS_DATA_MASK 0x7fU
166
#define GR740_THSENS_STATUS_DATA_GET( _reg ) \
167
( ( ( _reg ) & GR740_THSENS_STATUS_DATA_MASK ) >> \
168
GR740_THSENS_STATUS_DATA_SHIFT )
169
#define GR740_THSENS_STATUS_DATA_SET( _reg, _val ) \
170
( ( ( _reg ) & ~GR740_THSENS_STATUS_DATA_MASK ) | \
171
( ( ( _val ) << GR740_THSENS_STATUS_DATA_SHIFT ) & \
172
GR740_THSENS_STATUS_DATA_MASK ) )
173
#define GR740_THSENS_STATUS_DATA( _val ) \
174
175
176
178
186
187
#define GR740_THSENS_THRES_THRES_SHIFT 0
188
#define GR740_THSENS_THRES_THRES_MASK 0x7fU
189
#define GR740_THSENS_THRES_THRES_GET( _reg ) \
190
( ( ( _reg ) & GR740_THSENS_THRES_THRES_MASK ) >> \
191
GR740_THSENS_THRES_THRES_SHIFT )
192
#define GR740_THSENS_THRES_THRES_SET( _reg, _val ) \
193
( ( ( _reg ) & ~GR740_THSENS_THRES_THRES_MASK ) | \
194
( ( ( _val ) << GR740_THSENS_THRES_THRES_SHIFT ) & \
195
GR740_THSENS_THRES_THRES_MASK ) )
196
#define GR740_THSENS_THRES_THRES( _val ) \
197
198
199
201
206
typedef
struct
gr740_thsens
210
uint32_t
ctrl
211
215
uint32_t
status
216
220
uint32_t
thres
221
gr740_thsens
222
224
225
#ifdef __cplusplus
226
227
#endif
228
229
#endif
/* _BSP_GR740_THSENS_REGS_H */
gr740_thsens
This structure defines the GR740 Temperatur Sensor Controller register block memory map.
Definition
gr740-thsens-regs.h:206
gr740_thsens::ctrl
uint32_t ctrl
See Control register (CTRL).
Definition
gr740-thsens-regs.h:210
gr740_thsens::status
uint32_t status
See Status register (STATUS).
Definition
gr740-thsens-regs.h:215
gr740_thsens::thres
uint32_t thres
See Threshold register (THRES).
Definition
gr740-thsens-regs.h:220
