RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
gr1553bc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* GR1553B BC driver
4
5
* COPYRIGHT (c) 2010.
6
* Cobham Gaisler AB.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
17
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27
* POSSIBILITY OF SUCH DAMAGE.
28
29
* OVERVIEW
30
31
* This driver controls the BC device, located at an on-chip AMBA or an
32
* AMBA-over-PCI bus. The driver operates the BC device and provides you
33
* with interrupt services and core control. The driver start execution of
34
* a synchronuos and/or an asynchronous BC descriptor List. The list contains
35
* a descriptor table and a software description to make some operations
36
* possible, for example translate descriptor-address into descriptor-number.
37
38
* BC descriptors are generated by the list API, available in gr1553bc_list.h.
39
40
* See gr1553bc_list.h for more information.
41
42
43
#ifndef __GR1553BC_H__
44
#define __GR1553BC_H__
45
46
#ifdef __cplusplus
47
extern
"C"
48
#endif
49
50
/* Forward declaration */
51
struct
gr1553bc_list
52
struct
gr1553bc_major
53
struct
gr1553bc_minor
54
struct
gr1553bc_minor_cfg
55
struct
gr1553bc_major_cfg
56
57
#ifdef __cplusplus
58
59
#endif
60
61
#include <stdint.h>
62
#include "gr1553bc_list.h"
63
64
#ifdef __cplusplus
65
extern
"C"
66
#endif
67
68
/* Register GR1553B driver needed by BC driver */
69
extern
void
gr1553bc_register(
void
70
71
/* A BC descriptor accessed as is */
72
struct
gr1553bc_bd_raw
73
volatile
uint32_t words[4];
74
75
76
/* A BC descriptor accessed as a transfer descriptor */
77
struct
gr1553bc_bd_tr
78
volatile
uint32_t settings[2];
79
volatile
uint32_t dptr;
80
volatile
uint32_t status;
81
82
83
/* A BC descriptor accessed as a conditional descriptor */
84
struct
gr1553bc_bd_cond
85
volatile
uint32_t cond;
86
volatile
uint32_t bdptr;
87
volatile
uint32_t padding[2];
88
89
90
/* A BC descriptor accessed any way */
91
union
gr1553bc_bd
92
struct
gr1553bc_bd_raw
raw;
93
struct
gr1553bc_bd_tr
tr;
94
struct
gr1553bc_bd_cond
cond;
95
96
97
/* Current state of the BC hardware */
98
struct
gr1553bc_status
99
unsigned
int
status;
100
unsigned
int
time;
101
102
103
#define KEEP_TIMESLOT 0x10
104
/* Initialize a BC descriptor. The words written is controllable by
105
* the flags argument.
106
107
* flags:
108
* bit[N=0..3]: 1 = set BD wordN according to argument wordN,
109
* 0 = do not modify BD wordN
110
111
* If bit KEEP_TIMESLOT is set the time slot of word0 is preserved,
112
* this bit only have an affect when the descriptor is a transfer
113
* descriptor.
114
115
extern
void
gr1553bc_bd_init(
116
union
gr1553bc_bd
*bd,
117
unsigned
int
flags,
118
uint32_t word0,
119
uint32_t word1,
120
uint32_t word2,
121
uint32_t word3
122
123
124
/* Initialize a Transfer descriptor
125
126
* Arguments:
127
* struct gr1553bc_bd_tr *bd
128
* uint32_t setting0
129
* uint32_t setting1
130
* uint32_t data
131
* uint32_t status
132
133
#define gr1553bc_bd_tr_init(bd, set0, set1, data, status) \
134
gr1553bc_bd_init((union gr1553bc_bd *)bd,\
135
0xf, set0, set1, data, status)
136
/* Initializa a Condition descriptor
137
138
* Arguments:
139
* struct gr1553bc_bd_cond *bd
140
* uint32_t cond
141
* uint32_t jump_adr
142
143
#define gr1553bc_bd_cond_init(bd, cond, jump_adr) \
144
gr1553bc_bd_init((union gr1553bc_bd *)bd, \
145
0xf, cond, jump_adr, 0, 0)
146
147
/* Size of a descriptor */
148
#define GR1553BC_BD_SIZE sizeof(struct gr1553bc_bd_raw)
149
150
/* Alignment of a descriptor */
151
#define GR1553BC_BD_ALIGN 16
152
153
/* End of list marker */
154
#define GR1553BC_TR_EOL 0x80ffffff
155
156
#define GR1553BC_BD_TYPE 0x80000000
157
158
/* Condition descriptor bits */
159
#define GR1553BC_UNCOND_JMP 0x820000ff
160
#define GR1553BC_UNCOND_IRQ 0x860000ff
161
#define GR1553BC_UNCOND_NOJMP 0x82000000
162
163
/* Transfer descriptor bits */
164
#define GR1553BC_TR_DUMMY_0 0x00000000
165
#define GR1553BC_TR_DUMMY_1 0x80000000
166
167
#define GR1553BC_TR_TIME 0x0000ffff
168
169
#define GR1553BC_TR_EXTTRIG 0x40000000
170
171
/* Take a GR1553BC hardware device identified by instance index (minor).
172
* A pointer is returned that is used internally by the GR1553BC
173
* driver, it is used as an input paramter 'bc' to all other
174
* functions that manipulate the hardware.
175
176
extern
void
*gr1553bc_open(
int
minor);
177
178
extern
void
gr1553bc_close(
void
*bc);
179
180
/* Stores Current Major/Minor frame number and the Slot number executing
181
* into the location indicated by 'mid'. There may be two lists executing
182
* in "parallel", the 'async' argument select for which list the MID is
183
* looked up, the Syncronous (async=0) list or the Asynchronous (async=1)
184
* list.
185
186
187
extern
int
gr1553bc_indication(
void
*bc,
int
async,
int
*mid);
188
189
/* Trigger external time sync by writing to the BC action register.
190
* This may be good for debugging or if the time management is
191
* implemented in software.
192
193
* if trig=0 the external trigger memory is cleared.
194
* if trig!=0 the external trigger memory is set.
195
196
extern
void
gr1553bc_ext_trig(
void
*bc,
int
trig);
197
198
/* Configure the GR1553BC driver */
199
/*extern int gr1553bc_config(struct gr1553bc_config *cfg);*/
200
201
/* Start major frame processing. At least one list pointer must be
202
* non-zero to affect BC operation. The BC communication is enabled
203
* depending on list and Interrupts are enabled. This function can
204
* be called multiple times.
205
206
* If a list is already executing it will be replaced with the new
207
* list.
208
209
* list - Schedule Transfer List
210
* list_async - Asynchronous list
211
212
extern
int
gr1553bc_start
213
214
void
*bc,
215
struct
gr1553bc_list
*list,
216
struct
gr1553bc_list
*list_async
217
218
219
/* Pause GR1553B BC scheduled transfers.
220
221
* Does not affect asynchronous operation.
222
223
extern
int
gr1553bc_pause(
void
*bc);
224
225
/* Restart GR1553B BC scheduled transfers, after being paused
226
227
228
229
extern
int
gr1553bc_restart(
void
*bc);
230
231
/* Stop BC transmission.
232
233
* OPTIONS
234
* bit0 - 1=STOP schedule list
235
* bit1 - 1=STOP asynchronous list
236
237
extern
int
gr1553bc_stop(
void
*bc,
int
options);
238
239
/* Standard IRQ function setup. IRQ can be generated by condition descriptors
240
* or by transfer descriptors or by errors.
241
242
* Condition descriptors are inserted into the list by user, each condition
243
* may have a custom function and data assigned to it, see
244
* gr1553bc_slot_irq_prepare(). IRQs generated by condition descriptors are
245
* not handled by this function.
246
247
* Transfer descriptors can generate IRQ if enabled by user.
248
249
* IRQs generated by transfer descriptors or by BC errors (DMA error etc.)
250
* is handled by this standard ISR handler.
251
252
extern
int
gr1553bc_irq_setup
253
254
void
*bc,
255
bcirq_func_t func,
256
void
*data
257
258
259
/* Get Current BC hardware state/status. The Status is stored into the
260
* area pointed to by status. See "struct gr1553bc_status" for more
261
* info.
262
263
extern
void
gr1553bc_status
void
*bc,
struct
gr1553bc_status
*status);
264
265
#ifdef __cplusplus
266
267
#endif
268
269
#endif
/* __GR1553BC_H__ */
gr1553bc_bd_cond
Definition
gr1553bc.h:84
gr1553bc_bd_raw
Definition
gr1553bc.h:72
gr1553bc_bd_tr
Definition
gr1553bc.h:77
gr1553bc_list
Definition
gr1553bc_list.h:260
gr1553bc_major_cfg
Definition
gr1553bc_list.h:242
gr1553bc_major
Definition
gr1553bc_list.h:352
gr1553bc_minor_cfg
Definition
gr1553bc_list.h:237
gr1553bc_minor
Definition
gr1553bc_list.h:359
gr1553bc_status
Definition
gr1553bc.h:98
gr1553bc_bd
Definition
gr1553bc.h:91
