9#ifndef _FSL_SMARTCARD_H_
10#define _FSL_SMARTCARD_H_
12#include "fsl_common.h"
27#define FSL_SMARTCARD_DRIVER_VERSION (MAKE_VERSION(2, 2, 2))
32#define SMARTCARD_INIT_DELAY_CLOCK_CYCLES (42000u)
35#define SMARTCARD_EMV_ATR_DURATION_ETU (20150u)
38#define SMARTCARD_TS_DIRECT_CONVENTION (0x3Bu)
41#define SMARTCARD_TS_INVERSE_CONVENTION (0x3Fu)
64 kSMARTCARD_EnableADT = 0x0u,
65 kSMARTCARD_DisableADT = 0x1u,
66 kSMARTCARD_EnableGTV = 0x2u,
67 kSMARTCARD_DisableGTV = 0x3u,
68 kSMARTCARD_ResetWWT = 0x4u,
69 kSMARTCARD_EnableWWT = 0x5u,
70 kSMARTCARD_DisableWWT = 0x6u,
71 kSMARTCARD_ResetCWT = 0x7u,
72 kSMARTCARD_EnableCWT = 0x8u,
73 kSMARTCARD_DisableCWT = 0x9u,
74 kSMARTCARD_ResetBWT = 0xAu,
75 kSMARTCARD_EnableBWT = 0xBu,
76 kSMARTCARD_DisableBWT = 0xCu,
77 kSMARTCARD_EnableInitDetect = 0xDu,
78 kSMARTCARD_EnableAnack = 0xEu,
79 kSMARTCARD_DisableAnack = 0xFu,
80 kSMARTCARD_ConfigureBaudrate = 0x10u,
81 kSMARTCARD_SetupATRMode = 0x11u,
82 kSMARTCARD_SetupT0Mode = 0x12u,
83 kSMARTCARD_SetupT1Mode = 0x13u,
84 kSMARTCARD_EnableReceiverMode = 0x14u,
85 kSMARTCARD_DisableReceiverMode = 0x15u,
86 kSMARTCARD_EnableTransmitterMode = 0x16u,
87 kSMARTCARD_DisableTransmitterMode = 0x17u,
88 kSMARTCARD_ResetWaitTimeMultiplier = 0x18u,
94 kSMARTCARD_VoltageClassUnknown = 0x0u,
95 kSMARTCARD_VoltageClassA5_0V = 0x1u,
96 kSMARTCARD_VoltageClassB3_3V = 0x2u,
97 kSMARTCARD_VoltageClassC1_8V = 0x3u
103 kSMARTCARD_IdleState = 0x0u,
104 kSMARTCARD_WaitingForTSState = 0x1u,
105 kSMARTCARD_InvalidTSDetecetedState = 0x2u,
106 kSMARTCARD_ReceivingState = 0x3u,
107 kSMARTCARD_TransmittingState = 0x4u,
113 kSMARTCARD_ColdReset = 0x0u,
114 kSMARTCARD_WarmReset = 0x1u,
115 kSMARTCARD_NoColdReset = 0x2u,
116 kSMARTCARD_NoWarmReset = 0x3u,
122 kSMARTCARD_T0Transport = 0x0u,
123 kSMARTCARD_T1Transport = 0x1u
129 kSMARTCARD_EvenParity = 0x0u,
130 kSMARTCARD_OddParity = 0x1u
136 kSMARTCARD_DirectConvention = 0x0u,
137 kSMARTCARD_InverseConvention = 0x1u
143 kSMARTCARD_InterfaceSetVcc = 0x00u,
144 kSMARTCARD_InterfaceSetClockToResetDelay = 0x01u,
145 kSMARTCARD_InterfaceReadStatus = 0x02u
151 kSMARTCARD_Receive = 0u,
152 kSMARTCARD_Transmit = 1u
#define MAKE_STATUS(group, code)
Construct a status code value from a group and code number.
Definition fsl_common.h:47
@ kStatusGroup_SMARTCARD
Definition fsl_common.h:119
volatile bool initCharTimerExpired
Definition fsl_smartcard.h:198
volatile bool wtxRequested
Definition fsl_smartcard.h:265
struct _smartcard_timers_state smartcard_timers_state_t
Smart card defines the state of the EMV timers in the Smart card driver.
uint8_t irqPin
Definition fsl_smartcard.h:214
smartcard_direction_t direction
Definition fsl_smartcard.h:230
void * interfaceCallbackParam
Definition fsl_smartcard.h:251
bool faulty
Definition fsl_smartcard.h:186
smartcard_card_convention_t convention
Definition fsl_smartcard.h:187
smartcard_interface_callback_t interfaceCallback
Definition fsl_smartcard.h:249
size_t size
Definition fsl_smartcard.h:232
uint8_t vsel0Port
Definition fsl_smartcard.h:217
smartcard_card_voltage_class_t vcc
Definition fsl_smartcard.h:210
uint8_t dataPort
Definition fsl_smartcard.h:221
_smartcard_interface_control
Defines Smart card interface IC control types.
Definition fsl_smartcard.h:142
_smartcard_transfer_state
Defines Smart card I/O transfer states.
Definition fsl_smartcard.h:102
uint8_t resetPin
Definition fsl_smartcard.h:216
uint8_t resetPort
Definition fsl_smartcard.h:215
uint8_t modeNegotiable
Definition fsl_smartcard.h:176
uint8_t txFifoEntryCount
Definition fsl_smartcard.h:246
_smartcard_direction
Defines transfer direction.
Definition fsl_smartcard.h:150
enum _smartcard_transfer_state smartcard_transfer_state_t
void * transferCallbackParam
Definition fsl_smartcard.h:252
uint8_t dataPin
Definition fsl_smartcard.h:222
uint8_t vsel0Pin
Definition fsl_smartcard.h:218
enum _smartcard_card_convention smartcard_card_convention_t
Defines data Convention format.
uint8_t dataPinMux
Definition fsl_smartcard.h:223
_smartcard_reset_type
Defines Smart card reset types.
Definition fsl_smartcard.h:112
smartcard_time_delay_t timeDelay
Definition fsl_smartcard.h:253
_smartcard_parity_type
Defines Smart card data parity types.
Definition fsl_smartcard.h:128
uint8_t WI
Definition fsl_smartcard.h:169
bool t1Indicated
Definition fsl_smartcard.h:181
smartcard_parity_type_t parity
Definition fsl_smartcard.h:262
uint8_t rxFifoThreshold
Definition fsl_smartcard.h:247
void(*) smartcard_time_delay_t(uint32_t us)
Time Delay function used to passive waiting using RTOS [us].
Definition fsl_smartcard.h:161
volatile bool adtExpired
Definition fsl_smartcard.h:194
uint8_t status
Definition fsl_smartcard.h:179
smartcard_reset_type_t resetType
Definition fsl_smartcard.h:254
uint8_t fMax
Definition fsl_smartcard.h:168
Definition fsl_smartcard.h:242
uint8_t GTN
Definition fsl_smartcard.h:174
bool active
Definition fsl_smartcard.h:185
enum _smartcard_direction smartcard_direction_t
uint8_t tsTimerId
Definition fsl_smartcard.h:224
volatile bool wwtExpired
Definition fsl_smartcard.h:195
volatile bool txtCrossed
Definition fsl_smartcard.h:264
uint8_t controlPort
Definition fsl_smartcard.h:211
uint8_t IFSC
Definition fsl_smartcard.h:175
struct _smartcard_interface_config smartcard_interface_config_t
Defines user specified configuration of Smart card interface.
enum _smartcard_interface_control smartcard_interface_control_t
_smartcard_control
Control codes for the Smart card protocol timers and misc.
Definition fsl_smartcard.h:63
uint8_t vsel1Pin
Definition fsl_smartcard.h:220
uint8_t BWI
Definition fsl_smartcard.h:171
smartcard_transfer_callback_t transferCallback
Definition fsl_smartcard.h:250
uint8_t * xBuff
Definition fsl_smartcard.h:243
uint8_t Di
Definition fsl_smartcard.h:170
struct _smartcard_context smartcard_context_t
Runtime state of the Smart card driver.
volatile smartcard_transfer_state_t transferState
Definition fsl_smartcard.h:257
uint8_t controlPin
Definition fsl_smartcard.h:212
void(*) smartcard_interface_callback_t(void *smartcardContext, void *param)
Smart card interface interrupt callback function type.
Definition fsl_smartcard.h:156
uint8_t CWI
Definition fsl_smartcard.h:172
Definition fsl_smartcard.h:135
volatile bool xIsBusy
Definition fsl_smartcard.h:245
bool present
Definition fsl_smartcard.h:184
volatile bool rxtCrossed
Definition fsl_smartcard.h:263
enum _smartcard_card_voltage_class smartcard_card_voltage_class_t
Defines Smart card interface voltage class values.
enum _smartcard_transport_type smartcard_transport_type_t
Defines Smart card transport protocol types.
Definition fsl_smartcard.h:93
smartcard_interface_config_t interfaceConfig
Definition fsl_smartcard.h:269
void * base
Definition fsl_smartcard.h:241
uint8_t BGI
Definition fsl_smartcard.h:173
uint8_t clockModuleSourceClock
Definition fsl_smartcard.h:209
enum _smartcard_reset_type smartcard_reset_type_t
smartcard_card_params_t cardParams
Definition fsl_smartcard.h:260
enum _smartcard_parity_type smartcard_parity_type_t
volatile bool bwtExpired
Definition fsl_smartcard.h:197
enum _smartcard_control smartcard_control_t
uint8_t clockModule
Definition fsl_smartcard.h:207
uint8_t statusBytes[2]
Definition fsl_smartcard.h:267
smartcard_transport_type_t tType
Definition fsl_smartcard.h:255
volatile size_t xSize
Definition fsl_smartcard.h:244
volatile bool parityError
Definition fsl_smartcard.h:266
void(*) smartcard_transfer_callback_t(void *smartcardContext, void *param)
Smart card transfer interrupt callback function type.
Definition fsl_smartcard.h:158
uint8_t IFSD
Definition fsl_smartcard.h:261
smartcard_timers_state_t timersState
Definition fsl_smartcard.h:258
Definition fsl_smartcard.h:121
volatile bool cwtExpired
Definition fsl_smartcard.h:196
struct _smartcard_xfer smartcard_xfer_t
Defines user transfer structure used to initialize transfer.
uint32_t smartCardClock
Definition fsl_smartcard.h:205
uint8_t vsel1Port
Definition fsl_smartcard.h:219
bool abortTransfer
Definition fsl_smartcard.h:270
uint32_t clockToResetDelay
Definition fsl_smartcard.h:206
uint8_t clockModuleChannel
Definition fsl_smartcard.h:208
bool atrComplete
Definition fsl_smartcard.h:182
bool atrValid
Definition fsl_smartcard.h:183
uint16_t Fi
Definition fsl_smartcard.h:167
uint8_t * buff
Definition fsl_smartcard.h:231
struct _smartcard_card_params smartcard_card_params_t
Defines card-specific parameters for Smart card driver.
uint8_t irqPort
Definition fsl_smartcard.h:213
uint8_t currentD
Definition fsl_smartcard.h:177
bool t0Indicated
Definition fsl_smartcard.h:180
@ kStatus_SMARTCARD_TxBusy
Definition fsl_smartcard.h:47
@ kStatus_SMARTCARD_InvalidInput
Definition fsl_smartcard.h:56
@ kStatus_SMARTCARD_RxBusy
Definition fsl_smartcard.h:48
@ kStatus_SMARTCARD_Initialized
Definition fsl_smartcard.h:51
@ kStatus_SMARTCARD_NoTransferInProgress
Definition fsl_smartcard.h:49
@ kStatus_SMARTCARD_OtherError
Definition fsl_smartcard.h:58
@ kStatus_SMARTCARD_CardNotActivated
Definition fsl_smartcard.h:55
@ kStatus_SMARTCARD_Timeout
Definition fsl_smartcard.h:50
@ kStatus_SMARTCARD_PhyInitialized
Definition fsl_smartcard.h:53
@ kStatus_SMARTCARD_Success
Definition fsl_smartcard.h:46
Definition fsl_smartcard.h:165
Definition fsl_smartcard.h:239
Definition fsl_smartcard.h:204
Definition fsl_smartcard.h:193
Definition fsl_smartcard.h:229
