RTEMS 6.3
fsl_sai_sdma.h
1/*
2 * Copyright 2017 - 2021 NXP
3 * All rights reserved.
4 *
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8#ifndef _FSL_SAI_SDMA_H_
9#define _FSL_SAI_SDMA_H_
10
11#include "fsl_sai.h"
12#include "fsl_sdma.h"
13
19
20/*******************************************************************************
21 * Definitions
22 ******************************************************************************/
23
26#define FSL_SAI_SDMA_DRIVER_VERSION (MAKE_VERSION(2, 5, 3))
28
29typedef struct _sai_sdma_handle sai_sdma_handle_t;
30
32typedef void (*sai_sdma_callback_t)(I2S_Type *base, sai_sdma_handle_t *handle, status_t status, void *userData);
33
36{
37 sdma_handle_t *dmaHandle;
38 uint8_t bytesPerFrame;
39 uint8_t channel;
40 uint8_t channelNums;
41 uint8_t channelMask;
42 uint8_t fifoOffset;
43 uint32_t count;
44 uint32_t state;
45 uint32_t eventSource;
47 void *userData;
48 sdma_buffer_descriptor_t bdPool[SAI_XFER_QUEUE_SIZE];
51 volatile uint8_t queueUser;
52 volatile uint8_t queueDriver;
53};
54
55/*******************************************************************************
56 * APIs
57 ******************************************************************************/
58#if defined(__cplusplus)
59extern "C" {
60#endif
65
81 sai_sdma_handle_t *handle,
82 sai_sdma_callback_t callback,
83 void *userData,
84 sdma_handle_t *dmaHandle,
85 uint32_t eventSource);
86
102 sai_sdma_handle_t *handle,
103 sai_sdma_callback_t callback,
104 void *userData,
105 sdma_handle_t *dmaHandle,
106 uint32_t eventSource);
107
124 sai_sdma_handle_t *handle,
126 uint32_t mclkSourceClockHz,
127 uint32_t bclkSourceClockHz);
128
145 sai_sdma_handle_t *handle,
147 uint32_t mclkSourceClockHz,
148 uint32_t bclkSourceClockHz);
149
163status_t SAI_TransferSendSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_transfer_t *xfer);
164
178status_t SAI_TransferReceiveSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_transfer_t *xfer);
179
186void SAI_TransferAbortSendSDMA(I2S_Type *base, sai_sdma_handle_t *handle);
187
194void SAI_TransferAbortReceiveSDMA(I2S_Type *base, sai_sdma_handle_t *handle);
195
202void SAI_TransferTerminateReceiveSDMA(I2S_Type *base, sai_sdma_handle_t *handle);
203
210void SAI_TransferTerminateSendSDMA(I2S_Type *base, sai_sdma_handle_t *handle);
211
219void SAI_TransferRxSetConfigSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_transceiver_t *saiConfig);
220
228void SAI_TransferTxSetConfigSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_transceiver_t *saiConfig);
230
231#if defined(__cplusplus)
232}
233#endif
234
238#endif
int32_t status_t
Type used for all status and error return values.
Definition fsl_common.h:225
struct _sai_transfer_format sai_transfer_format_t
sai transfer format
#define SAI_XFER_QUEUE_SIZE
SAI transfer queue size, user can refine it according to use case.
Definition fsl_sai.h:204
struct _sai_transfer sai_transfer_t
SAI transfer structure.
struct _sai_transceiver sai_transceiver_t
sai transceiver configurations
Terminate all the SAI sdma receive transfer.
void SAI_TransferRxSetFormatSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz)
Configures the SAI Rx audio format.
Performs a non-blocking SAI transfer using DMA.
void SAI_TransferTxSetFormatSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz)
Configures the SAI Tx audio format.
Performs a non-blocking SAI receive using SDMA.
Aborts a SAI receive using SDMA.
Aborts a SAI transfer using SDMA.
void(*) sai_sdma_callback_t(I2S_Type *base, sai_sdma_handle_t *handle, status_t status, void *userData)
SAI SDMA transfer callback function for finish and error.
Definition fsl_sai_sdma.h:32
Terminate all the SAI sdma send transfer.
void SAI_TransferRxCreateHandleSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_sdma_callback_t callback, void *userData, sdma_handle_t *dmaHandle, uint32_t eventSource)
Initializes the SAI Rx SDMA handle.
void SAI_TransferTxCreateHandleSDMA(I2S_Type *base, sai_sdma_handle_t *handle, sai_sdma_callback_t callback, void *userData, sdma_handle_t *dmaHandle, uint32_t eventSource)
Initializes the SAI SDMA handle.
Definition MIMXRT1052.h:23296
SAI DMA transfer handle, users should not touch the content of the handle.
Definition fsl_sai_sdma.h:36
uint32_t count
Definition fsl_sai_sdma.h:43
Definition fsl_sai_sdma.h:46
size_t transferSize[SAI_XFER_QUEUE_SIZE]
Definition fsl_sai_sdma.h:50
Definition fsl_sai_sdma.h:52
void * userData
Definition fsl_sai_sdma.h:47
uint8_t channelNums
Definition fsl_sai_sdma.h:40
sdma_handle_t * dmaHandle
Definition fsl_sai_sdma.h:37
uint8_t channel
Definition fsl_sai_sdma.h:39
Definition fsl_sai_sdma.h:51
Definition fsl_sai_sdma.h:48
uint8_t channelMask
Definition fsl_sai_sdma.h:41
sai_transfer_t saiQueue[SAI_XFER_QUEUE_SIZE]
Definition fsl_sai_sdma.h:49
uint32_t state
Definition fsl_sai_sdma.h:44
Definition fsl_sai_sdma.h:45
uint8_t fifoOffset
Definition fsl_sai_sdma.h:42
Definition fsl_sai_sdma.h:38
Definition mknod-pack_dev.c:254
