RTEMS 6.3
fsl_lcdifv2.h
1/*
2 * Copyright 2019-2022 NXP
3 * All rights reserved.
4 *
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8
9#ifndef _FSL_LCDIFV2_H_
10#define _FSL_LCDIFV2_H_
11
12#include "fsl_common.h"
13
14#if (defined(FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET) && (0 != FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET))
15#include "fsl_memory.h"
16#endif
17
22
23/*******************************************************************************
24 * Definitions
25 ******************************************************************************/
26
30#define FSL_LCDIFV2_DRIVER_VERSION (MAKE_VERSION(2, 3, 2))
32
33#if defined(FSL_FEATURE_LCDIFV2_LAYER_COUNT) && (!defined(LCDIFV2_LAYER_COUNT))
34#define LCDIFV2_LAYER_COUNT FSL_FEATURE_LCDIFV2_LAYER_COUNT
35#endif
36
37#if defined(FSL_FEATURE_LCDIFV2_LAYER_CSC_COUNT) && (!defined(LCDIFV2_LAYER_CSC_COUNT))
38#define LCDIFV2_LAYER_CSC_COUNT FSL_FEATURE_LCDIFV2_LAYER_CSC_COUNT
39#endif
40
41#if (defined(FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET) && (0 != FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET))
42#define LCDIFV2_ADDR_CPU_2_IP(addr) (MEMORY_ConvertMemoryMapAddress((uint32_t)(addr), kMEMORY_Local2DMA))
43#else
44#define LCDIFV2_ADDR_CPU_2_IP(addr) (addr)
45#endif /* FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET */
46
48#define LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(layer) (1UL << ((uint32_t)(layer) + 24U))
50#define LCDIFV2_MAKE_DMA_DONE_INTERRUPT(layer) (1UL << ((uint32_t)(layer) + 16U))
52#define LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(layer) (1UL << ((uint32_t)(layer) + 8U))
53
54/* LUT memory entery number. */
55#define LCDIFV2_LUT_ENTRY_NUM 256U
56
76
81{
109};
110
121
126{
127 uint16_t panelWidth;
128 uint16_t panelHeight;
129 uint8_t hsw;
130 uint8_t hfp;
131 uint8_t hbp;
132 uint8_t vsw;
133 uint8_t vfp;
134 uint8_t vbp;
135 uint32_t polarityFlags;
138
146
169
176
187
196
205
215
226
245
263
271
272/*******************************************************************************
273 * APIs
274 ******************************************************************************/
275
276#if defined(__cplusplus)
277extern "C" {
278#endif /* __cplusplus */
279
284
292void LCDIFV2_Init(LCDIFV2_Type *base);
293
299void LCDIFV2_Deinit(LCDIFV2_Type *base);
300
306void LCDIFV2_Reset(LCDIFV2_Type *base);
307
308/* @} */
309
314
337
345
352static inline void LCDIFV2_EnableDisplay(LCDIFV2_Type *base, bool enable)
353{
354 if (enable)
355 {
356 base->DISP_PARA |= LCDIFV2_DISP_PARA_DISP_ON_MASK;
357 }
358 else
359 {
360 base->DISP_PARA &= ~LCDIFV2_DISP_PARA_DISP_ON_MASK;
361 }
362}
363
364/* @} */
365
370
378static inline void LCDIFV2_EnableInterrupts(LCDIFV2_Type *base, uint8_t domain, uint32_t mask)
379{
380 base->INT[domain].INT_ENABLE |= mask;
381}
382
390static inline void LCDIFV2_DisableInterrupts(LCDIFV2_Type *base, uint8_t domain, uint32_t mask)
391{
392 base->INT[domain].INT_ENABLE &= ~mask;
393}
394
402static inline uint32_t LCDIFV2_GetInterruptStatus(LCDIFV2_Type *base, uint8_t domain)
403{
404 return base->INT[domain].INT_STATUS;
405}
406
414static inline void LCDIFV2_ClearInterruptStatus(LCDIFV2_Type *base, uint8_t domain, uint32_t mask)
415{
416 base->INT[domain].INT_STATUS = mask;
417}
418
419/* @} */
420
425
443 LCDIFV2_Type *base, uint8_t layerIndex, const uint32_t *lutData, uint16_t count, bool useShadowLoad);
444
445/* @} */
446
451
462static inline void LCDIFV2_SetLayerSize(LCDIFV2_Type *base, uint8_t layerIndex, uint16_t width, uint16_t height)
463{
464 base->LAYER[layerIndex].CTRLDESCL1 =
465 ((uint32_t)height << LCDIFV2_CTRLDESCL1_HEIGHT_SHIFT) | ((uint32_t)width << LCDIFV2_CTRLDESCL1_WIDTH_SHIFT);
466}
467
476static inline void LCDIFV2_SetLayerOffset(LCDIFV2_Type *base, uint8_t layerIndex, uint16_t offsetX, uint16_t offsetY)
477{
478 base->LAYER[layerIndex].CTRLDESCL2 =
479 ((uint32_t)offsetX << LCDIFV2_CTRLDESCL2_POSX_SHIFT) | ((uint32_t)offsetY << LCDIFV2_CTRLDESCL2_POSY_SHIFT);
480}
481
489void LCDIFV2_SetLayerBufferConfig(LCDIFV2_Type *base, uint8_t layerIndex, const lcdifv2_buffer_config_t *config);
490
500static inline void LCDIFV2_SetLayerBufferAddr(LCDIFV2_Type *base, uint8_t layerIndex, uint32_t addr)
501{
502 base->LAYER[layerIndex].CTRLDESCL4 = LCDIFV2_ADDR_CPU_2_IP(addr);
503}
504
512static inline void LCDIFV2_EnableLayer(LCDIFV2_Type *base, uint8_t layerIndex, bool enable)
513{
514 if (enable)
515 {
516 base->LAYER[layerIndex].CTRLDESCL5 |= LCDIFV2_CTRLDESCL5_EN_MASK;
517 }
518 else
519 {
520 base->LAYER[layerIndex].CTRLDESCL5 &= ~LCDIFV2_CTRLDESCL5_EN_MASK;
521 }
522}
523
535static inline void LCDIFV2_TriggerLayerShadowLoad(LCDIFV2_Type *base, uint8_t layerIndex)
536{
537 base->LAYER[layerIndex].CTRLDESCL5 |= LCDIFV2_CTRLDESCL5_SHADOW_LOAD_EN_MASK;
538}
539
549static inline void LCDIFV2_SetLayerBackGroundColor(LCDIFV2_Type *base, uint8_t layerIndex, uint32_t backGroundColor)
550{
551 base->LAYER[layerIndex].CTRLDESCL6 = backGroundColor;
552}
553
561void LCDIFV2_SetLayerBlendConfig(LCDIFV2_Type *base, uint8_t layerIndex, const lcdifv2_blend_config_t *config);
562
572void LCDIFV2_SetCscMode(LCDIFV2_Type *base, uint8_t layerIndex, lcdifv2_csc_mode_t mode);
573
574/* @} */
575
580
605 lcdifv2_pd_layer_t layer,
606 lcdifv2_blend_config_t *config);
607
608/* @} */
609
614
645status_t LCDIFV2_GetMultiLayerGlobalAlpha(const uint8_t blendedAlpha[], uint8_t globalAlpha[], uint8_t layerCount);
646
647/* @} */
648
649#if defined(__cplusplus)
650}
651#endif /* __cplusplus */
652
653/* @} */
654
655#endif /*_FSL_LCDIFV2_H_*/
#define LCDIFV2_CTRLDESCL5_YUV_FORMAT(x)
Definition MIMXRT1166_cm4.h:58353
#define LCDIFV2_CTRLDESCL5_BPP(x)
Definition MIMXRT1166_cm4.h:58376
int32_t status_t
Type used for all status and error return values.
Definition fsl_common.h:225
lcdifv2_pd_factor_mode_t pdFactorMode
Definition fsl_lcdifv2.h:242
lcdifv2_alpha_mode_t alphaMode
Definition fsl_lcdifv2.h:235
_lcdifv2_interrupt
The LCDIF v2 interrupts.
Definition fsl_lcdifv2.h:81
Definition fsl_lcdifv2.h:135
Deinitializes the LCDIF peripheral.
Definition fsl_lcdifv2.c:134
enum _lcdifv2_alpha_mode lcdifv2_alpha_mode_t
LCDIF v2 layer alpha blending mode.
Reset the LCDIF v2.
Definition fsl_lcdifv2.c:150
uint16_t strideBytes
Definition fsl_lcdifv2.h:173
Set the color space conversion mode.
Definition fsl_lcdifv2.c:217
Initializes the LCDIF v2.
Definition fsl_lcdifv2.c:115
enum _lcdifv2_line_order lcdifv2_line_order_t
The LCDIF v2 output line order.
uint8_t vfp
Definition fsl_lcdifv2.h:133
status_t LCDIFV2_SetLut(LCDIFV2_Type *base, uint8_t layerIndex, const uint32_t *lutData, uint16_t count, bool useShadowLoad)
Set the LUT data.
Definition fsl_lcdifv2.c:299
lcdifv2_line_order_t lineOrder
Definition fsl_lcdifv2.h:136
enum _lcdifv2_pd_blend_mode lcdifv2_pd_blend_mode_t
LCDIFv2 Porter Duff blend mode. Note: Don't change the enum item value.
_lcdifv2_alpha_mode
Definition fsl_lcdifv2.h:181
_lcdifv2_line_order
Definition fsl_lcdifv2.h:113
uint8_t hbp
Definition fsl_lcdifv2.h:131
_lcdifv2_pd_alpha_mode
LCDIF v2 PoterDuff alpha mode.
Definition fsl_lcdifv2.h:192
_lcdifv2_pd_layer
LCDIFv2 Porter Duff layer. Note: Don't change the enum item value.
Definition fsl_lcdifv2.h:266
LCDIF v2 FIFO empty interrupt.
Definition fsl_lcdifv2.h:48
struct _lcdifv2_buffer_config lcdifv2_buffer_config_t
LCDIF v2 source buffer configuration.
Set the layer source buffer configuration.
Definition fsl_lcdifv2.c:266
enum _lcdifv2_pd_layer lcdifv2_pd_layer_t
struct _lcdifv2_display_config lcdifv2_display_config_t
LCDIF v2 display configure structure.
lcdifv2_pixel_format_t pixelFormat
Definition fsl_lcdifv2.h:174
enum _lcdifv2_pixel_format lcdifv2_pixel_format_t
LCDIF v2 pixel format.
Definition fsl_lcdifv2.h:149
_lcdifv2_polarity_flags
LCDIF v2 signal polarity flags.
Definition fsl_lcdifv2.h:61
_lcdifv2_pd_color_mode
LCDIF v2 PoterDuff color mode.
Definition fsl_lcdifv2.h:201
uint8_t hsw
Definition fsl_lcdifv2.h:129
Definition fsl_lcdifv2.h:128
lcdifv2_pd_global_alpha_mode_t pdGlobalAlphaMode
Definition fsl_lcdifv2.h:240
lcdifv2_pd_alpha_mode_t pdAlphaMode
Definition fsl_lcdifv2.h:236
_lcdifv2_csc_mode
LCDIF v2 color space conversion mode.
Definition fsl_lcdifv2.h:141
uint16_t panelWidth
Definition fsl_lcdifv2.h:127
LCDIF v2 DMA error interrupt.
Definition fsl_lcdifv2.h:52
enum _lcdifv2_pd_global_alpha_mode lcdifv2_pd_global_alpha_mode_t
LCDIF v2 PoterDuff global alpha mode.
status_t LCDIFV2_GetPorterDuffConfig(lcdifv2_pd_blend_mode_t mode, lcdifv2_pd_layer_t layer, lcdifv2_blend_config_t *config)
Get the blend configuration for Porter Duff blend.
Definition fsl_lcdifv2.c:379
LCDIF v2 DMA done interrupt.
Definition fsl_lcdifv2.h:50
enum _lcdifv2_pd_factor_mode lcdifv2_pd_factor_mode_t
LCDIF v2 PoterDuff factor mode.
enum _lcdifv2_csc_mode lcdifv2_csc_mode_t
Definition fsl_lcdifv2.h:210
void LCDIFV2_DisplayGetDefaultConfig(lcdifv2_display_config_t *config)
Gets the LCDIF display default configuration structure.
Definition fsl_lcdifv2.c:163
Definition fsl_lcdifv2.h:220
uint8_t hfp
Definition fsl_lcdifv2.h:130
void LCDIFV2_SetDisplayConfig(LCDIFV2_Type *base, const lcdifv2_display_config_t *config)
Set the LCDIF v2 display configurations.
Definition fsl_lcdifv2.c:187
uint8_t vbp
Definition fsl_lcdifv2.h:134
Set the layer alpha blend mode.
Definition fsl_lcdifv2.c:341
enum _lcdifv2_pd_color_mode lcdifv2_pd_color_mode_t
uint8_t globalAlpha
Definition fsl_lcdifv2.h:232
enum _lcdifv2_pd_alpha_mode lcdifv2_pd_alpha_mode_t
lcdifv2_pd_color_mode_t pdColorMode
Definition fsl_lcdifv2.h:238
struct _lcdifv2_blend_config lcdifv2_blend_config_t
LCDIF v2 layer alpha blending configuration.
Definition fsl_lcdifv2.h:248
uint8_t vsw
Definition fsl_lcdifv2.h:132
Get the global alpha values for multiple layer blend.
Definition fsl_lcdifv2.c:477
@ kLCDIFV2_Layer7DmaDoneInterrupt
Definition fsl_lcdifv2.h:97
@ kLCDIFV2_Layer3DmaDoneInterrupt
Definition fsl_lcdifv2.h:93
@ kLCDIFV2_Layer3DmaErrorInterrupt
Definition fsl_lcdifv2.h:101
@ kLCDIFV2_Layer5DmaErrorInterrupt
Definition fsl_lcdifv2.h:103
@ kLCDIFV2_Layer2DmaDoneInterrupt
Definition fsl_lcdifv2.h:92
@ kLCDIFV2_Layer0FifoEmptyInterrupt
Definition fsl_lcdifv2.h:82
@ kLCDIFV2_Layer6DmaErrorInterrupt
Definition fsl_lcdifv2.h:104
@ kLCDIFV2_Layer2DmaErrorInterrupt
Definition fsl_lcdifv2.h:100
@ kLCDIFV2_Layer0DmaDoneInterrupt
Definition fsl_lcdifv2.h:90
@ kLCDIFV2_Layer0DmaErrorInterrupt
Definition fsl_lcdifv2.h:98
@ kLCDIFV2_Layer3FifoEmptyInterrupt
Definition fsl_lcdifv2.h:85
@ kLCDIFV2_VerticalBlankingInterrupt
Definition fsl_lcdifv2.h:106
@ kLCDIFV2_Layer1DmaErrorInterrupt
Definition fsl_lcdifv2.h:99
@ kLCDIFV2_VsyncEdgeInterrupt
Definition fsl_lcdifv2.h:108
@ kLCDIFV2_Layer7FifoEmptyInterrupt
Definition fsl_lcdifv2.h:89
@ kLCDIFV2_Layer4DmaErrorInterrupt
Definition fsl_lcdifv2.h:102
@ kLCDIFV2_Layer4DmaDoneInterrupt
Definition fsl_lcdifv2.h:94
@ kLCDIFV2_Layer6FifoEmptyInterrupt
Definition fsl_lcdifv2.h:88
@ kLCDIFV2_Layer2FifoEmptyInterrupt
Definition fsl_lcdifv2.h:84
@ kLCDIFV2_Layer1FifoEmptyInterrupt
Definition fsl_lcdifv2.h:83
@ kLCDIFV2_Layer6DmaDoneInterrupt
Definition fsl_lcdifv2.h:96
@ kLCDIFV2_Layer7DmaErrorInterrupt
Definition fsl_lcdifv2.h:105
@ kLCDIFV2_Layer5FifoEmptyInterrupt
Definition fsl_lcdifv2.h:87
@ kLCDIFV2_Layer1DmaDoneInterrupt
Definition fsl_lcdifv2.h:91
@ kLCDIFV2_Layer5DmaDoneInterrupt
Definition fsl_lcdifv2.h:95
@ kLCDIFV2_OutputUnderrunInterrupt
Definition fsl_lcdifv2.h:107
@ kLCDIFV2_Layer4FifoEmptyInterrupt
Definition fsl_lcdifv2.h:86
@ kLCDIFV2_AlphaEmbedded
Definition fsl_lcdifv2.h:184
@ kLCDIFV2_AlphaDisable
Definition fsl_lcdifv2.h:182
@ kLCDIFV2_AlphaOverride
Definition fsl_lcdifv2.h:183
@ kLCDIFV2_AlphaPoterDuff
Definition fsl_lcdifv2.h:185
@ kLCDIFV2_LineOrderGBR
Definition fsl_lcdifv2.h:116
@ kLCDIFV2_LineOrderBGR
Definition fsl_lcdifv2.h:119
@ kLCDIFV2_LineOrderGRB
Definition fsl_lcdifv2.h:117
@ kLCDIFV2_LineOrderRBG
Definition fsl_lcdifv2.h:115
@ kLCDIFV2_LineOrderBRG
Definition fsl_lcdifv2.h:118
@ kLCDIFV2_LineOrderRGB
Definition fsl_lcdifv2.h:114
@ kLCDIFV2_PD_AlphaStraight
Definition fsl_lcdifv2.h:193
@ kLCDIFV2_PD_AlphaInversed
Definition fsl_lcdifv2.h:194
@ kLCDIFV2_PD_LayerMax
Definition fsl_lcdifv2.h:269
@ kLCDIFV2_PD_DestLayer
Definition fsl_lcdifv2.h:268
@ kLCDIFV2_PD_SrcLayer
Definition fsl_lcdifv2.h:267
@ kLCDIFV2_PixelFormatYUYV
Definition fsl_lcdifv2.h:161
@ kLCDIFV2_PixelFormatARGB4444
Definition fsl_lcdifv2.h:156
@ kLCDIFV2_PixelFormatRGB888
Definition fsl_lcdifv2.h:165
@ kLCDIFV2_PixelFormatABGR8888
Definition fsl_lcdifv2.h:167
@ kLCDIFV2_PixelFormatARGB8888
Definition fsl_lcdifv2.h:166
@ kLCDIFV2_PixelFormatVYUY
Definition fsl_lcdifv2.h:159
@ kLCDIFV2_PixelFormatUYVY
Definition fsl_lcdifv2.h:157
@ kLCDIFV2_PixelFormatIndex8BPP
Definition fsl_lcdifv2.h:153
@ kLCDIFV2_PixelFormatYVYU
Definition fsl_lcdifv2.h:163
@ kLCDIFV2_PixelFormatIndex2BPP
Definition fsl_lcdifv2.h:151
@ kLCDIFV2_PixelFormatRGB565
Definition fsl_lcdifv2.h:154
@ kLCDIFV2_PixelFormatIndex4BPP
Definition fsl_lcdifv2.h:152
@ kLCDIFV2_PixelFormatARGB1555
Definition fsl_lcdifv2.h:155
@ kLCDIFV2_PixelFormatIndex1BPP
Definition fsl_lcdifv2.h:150
@ kLCDIFV2_HsyncActiveLow
Definition fsl_lcdifv2.h:70
@ kLCDIFV2_DriveDataOnFallingClkEdge
Definition fsl_lcdifv2.h:72
@ kLCDIFV2_DataActiveHigh
Definition fsl_lcdifv2.h:67
@ kLCDIFV2_DataActiveLow
Definition fsl_lcdifv2.h:74
@ kLCDIFV2_HsyncActiveHigh
Definition fsl_lcdifv2.h:63
@ kLCDIFV2_VsyncActiveLow
Definition fsl_lcdifv2.h:69
@ kLCDIFV2_DriveDataOnRisingClkEdge
Definition fsl_lcdifv2.h:65
@ kLCDIFV2_DataEnableActiveLow
Definition fsl_lcdifv2.h:71
@ kLCDIFV2_DataEnableActiveHigh
Definition fsl_lcdifv2.h:64
@ kLCDIFV2_VsyncActiveHigh
Definition fsl_lcdifv2.h:62
@ kLCDIFV2_PD_ColorNoAlpha
Definition fsl_lcdifv2.h:202
@ kLCDIFV2_PD_ColorWithAlpha
Definition fsl_lcdifv2.h:203
@ kLCDIFV2_CscDisable
Definition fsl_lcdifv2.h:142
@ kLCDIFV2_CscYCbCr2RGB
Definition fsl_lcdifv2.h:144
@ kLCDIFV2_CscYUV2RGB
Definition fsl_lcdifv2.h:143
@ kLCDIFV2_PD_LocalAlpha
Definition fsl_lcdifv2.h:212
@ kLCDIFV2_PD_GlobalAlpha
Definition fsl_lcdifv2.h:211
@ kLCDIFV2_PD_ScaledAlpha
Definition fsl_lcdifv2.h:213
@ kLCDIFV2_PD_FactorInversedAlpha
Definition fsl_lcdifv2.h:224
@ kLCDIFV2_PD_FactorZero
Definition fsl_lcdifv2.h:222
@ kLCDIFV2_PD_FactorStraightAlpha
Definition fsl_lcdifv2.h:223
@ kLCDIFV2_PD_FactorOne
Definition fsl_lcdifv2.h:221
@ kLCDIFV2_PD_Clear
Definition fsl_lcdifv2.h:260
@ kLCDIFV2_PD_Out
Definition fsl_lcdifv2.h:253
@ kLCDIFV2_PD_Max
Definition fsl_lcdifv2.h:261
@ kLCDIFV2_PD_Xor
Definition fsl_lcdifv2.h:259
@ kLCDIFV2_PD_DstOver
Definition fsl_lcdifv2.h:256
@ kLCDIFV2_PD_DstIn
Definition fsl_lcdifv2.h:257
@ kLCDIFV2_PD_Src
Definition fsl_lcdifv2.h:249
@ kLCDIFV2_PD_Atop
Definition fsl_lcdifv2.h:250
@ kLCDIFV2_PD_DstOut
Definition fsl_lcdifv2.h:258
@ kLCDIFV2_PD_In
Definition fsl_lcdifv2.h:252
@ kLCDIFV2_PD_Over
Definition fsl_lcdifv2.h:251
@ kLCDIFV2_PD_DstAtop
Definition fsl_lcdifv2.h:255
@ kLCDIFV2_PD_Dst
Definition fsl_lcdifv2.h:254
Definition MIMXRT1166_cm4.h:57742
Definition fsl_lcdifv2.h:231
Definition fsl_lcdifv2.h:172
Definition fsl_lcdifv2.h:126
