RTEMS
6.3
Toggle main menu visibility
bsps
arm
imxrt
mcux-sdk
drivers
common
fsl_common_dsp.h
1
2
* Copyright (c) 2015-2016, Freescale Semiconductor, Inc.
3
* Copyright 2016-2020 NXP
4
* All rights reserved.
5
6
* SPDX-License-Identifier: BSD-3-Clause
7
8
9
#ifndef _FSL_COMMON_DSP_H_
10
#define _FSL_COMMON_DSP_H_
11
16
17
18
* Definitions
19
20
22
24
#define USEC_TO_COUNT(us, clockFreqInHz) (uint64_t)(((uint64_t)(us) * (clockFreqInHz)) / 1000000U)
26
#define COUNT_TO_USEC(count, clockFreqInHz) (uint64_t)((uint64_t)(count) * 1000000U / (clockFreqInHz))
27
29
#define MSEC_TO_COUNT(ms, clockFreqInHz) (uint64_t)((uint64_t)(ms) * (clockFreqInHz) / 1000U)
31
#define COUNT_TO_MSEC(count, clockFreqInHz) (uint64_t)((uint64_t)(count) * 1000U / (clockFreqInHz))
32
33
34
#define SDK_ISR_EXIT_BARRIER
35
37
39
#define SDK_ALIGN(var, alignbytes) var __attribute__((aligned(alignbytes)))
40
42
#if defined(FSL_FEATURE_L1DCACHE_LINESIZE_BYTE)
43
#define SDK_L1DCACHE_ALIGN(var) SDK_ALIGN(var, FSL_FEATURE_L1DCACHE_LINESIZE_BYTE)
44
#endif
45
47
#if defined(FSL_FEATURE_L2CACHE_LINESIZE_BYTE)
48
#define SDK_L2CACHE_ALIGN(var) SDK_ALIGN(var, FSL_FEATURE_L2CACHE_LINESIZE_BYTE)
49
#endif
50
52
#define SDK_SIZEALIGN(var, alignbytes) \
53
((unsigned int)((var) + ((alignbytes)-1U)) & (unsigned int)(~(unsigned int)((alignbytes)-1U)))
54
55
57
/* For initialized non-zero non-cacheable variables, please using "AT_NONCACHEABLE_SECTION_INIT(var) ={xx};" or
58
* "AT_NONCACHEABLE_SECTION_ALIGN_INIT(var) ={xx};" in your projects to define them, for zero-inited non-cacheable variables,
59
* please using "AT_NONCACHEABLE_SECTION(var);" or "AT_NONCACHEABLE_SECTION_ALIGN(var);" to define them, these zero-inited variables
60
* will be initialized to zero in system startup.
61
62
63
64
#define AT_NONCACHEABLE_SECTION_INIT(var) __attribute__((section("NonCacheable.init"))) var
65
#define AT_NONCACHEABLE_SECTION(var) __attribute__((section("NonCacheable"))) var
66
#define AT_NONCACHEABLE_SECTION_ALIGN_INIT(var, alignbytes) \
67
__attribute__((section("NonCacheable.init"))) var __attribute__((aligned(alignbytes)))
68
#define AT_NONCACHEABLE_SECTION_ALIGN(var, alignbytes) \
69
__attribute__((section("NonCacheable"))) var __attribute__((aligned(alignbytes)))
70
71
72
77
#if (defined(FSL_SDK_DRIVER_QUICK_ACCESS_ENABLE) && FSL_SDK_DRIVER_QUICK_ACCESS_ENABLE)
78
79
#define AT_QUICKACCESS_SECTION_CODE(func) __attribute__((section("CodeQuickAccess"), __noinline__)) func
80
#define AT_QUICKACCESS_SECTION_DATA(func) __attribute__((section("DataQuickAccess"))) func
81
82
#else
/* __FSL_SDK_DRIVER_QUICK_ACCESS_ENABLE */
83
84
#define AT_QUICKACCESS_SECTION_CODE(func) func
85
#define AT_QUICKACCESS_SECTION_DATA(func) func
86
87
#endif
88
89
90
/* Macros for compatibility. */
91
#define NVIC_SetPriorityGrouping(value) do {} while(0)
92
#define NVIC_GetPriorityGrouping() do {} while(0)
93
#define NVIC_EnableIRQ(value) do {} while(0)
94
#define NVIC_GetEnableIRQ(value) do {} while(0)
95
#define NVIC_DisableIRQ(value) do {} while(0)
96
#define NVIC_GetPendingIRQ(value) do {} while(0)
97
#define NVIC_SetPendingIRQ(value) do {} while(0)
98
#define NVIC_ClearPendingIRQ(value) do {} while(0)
99
#define NVIC_GetActive(value) do {} while(0)
100
101
102
* The fsl_clock.h is included here because it needs MAKE_VERSION/MAKE_STATUS/status_t
103
* defined in previous of this file.
104
105
#include "fsl_clock.h"
106
107
108
* API
109
110
111
#if defined(__cplusplus)
112
extern
"C"
113
#endif
114
123
static
inline
status_t
EnableIRQ(
IRQn_Type
interrupt)
124
125
return
kStatus_Success
126
127
136
static
inline
status_t
DisableIRQ(
IRQn_Type
interrupt)
137
138
return
kStatus_Success
139
140
148
static
inline
uint32_t DisableGlobalIRQ(
void
149
150
return
0;
151
152
160
static
inline
void
EnableGlobalIRQ(uint32_t primask)
161
162
163
164
165
166
#endif
167
169
170
#endif
/* _FSL_COMMON_DSP_H_ */
IRQn_Type
IRQn_Type
STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_sect...
Definition
stm32h723xx.h:49
status_t
int32_t status_t
Type used for all status and error return values.
Definition
fsl_common.h:225
kStatus_Success
@ kStatus_Success
Definition
fsl_common.h:211
