RTEMS 6.3
fsl_asrc_edma.h
1/*
2 * Copyright 2019-2020 NXP
3 * All rights reserved.
4 *
5 * SPDX-License-Identifier: BSD-3-Clause
6 */
7#ifndef _FSL_ASRC_P2P_EDMA_H_
8#define _FSL_ASRC_P2P_EDMA_H_
9
10#include "fsl_edma.h"
11#include "fsl_asrc.h"
12
17
18/*******************************************************************************
19 * Definitions
20 ******************************************************************************/
21
24#define FSL_ASRC_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 1, 0))
27#define ASRC_XFER_IN_QUEUE_SIZE 4U
28#define ASRC_XFER_OUT_QUEUE_SIZE (ASRC_XFER_QUEUE_SIZE * 2U)
29
30typedef struct _asrc_edma_handle asrc_edma_handle_t;
31
33typedef void (*asrc_edma_callback_t)(ASRC_Type *base, asrc_edma_handle_t *handle, status_t status, void *userData);
34
36typedef void (*asrc_start_peripheral_t)(bool start);
44
62
65{
67
68 uint8_t tcd[(ASRC_XFER_OUT_QUEUE_SIZE + 1U) * sizeof(edma_tcd_t)];
69
70 uint32_t sampleWidth;
71 uint32_t fifoThreshold;
72 uint32_t *asrcQueue[ASRC_XFER_OUT_QUEUE_SIZE];
73 size_t transferSize[ASRC_XFER_OUT_QUEUE_SIZE];
74 volatile uint8_t queueUser;
75 volatile uint8_t queueDriver;
76 uint32_t state;
79
89
90/*******************************************************************************
91 * APIs
92 ******************************************************************************/
93#if defined(__cplusplus)
94extern "C" {
95#endif
96
101
117 asrc_edma_handle_t *handle,
118 asrc_channel_pair_t channelPair,
119 asrc_edma_callback_t callback,
120 edma_handle_t *inDmaHandle,
121 const asrc_p2p_edma_config_t *periphConfig,
122 void *userData);
123
139 asrc_edma_handle_t *handle,
140 asrc_channel_pair_t channelPair,
141 asrc_edma_callback_t callback,
142 edma_handle_t *outDmaHandle,
143 const asrc_p2p_edma_config_t *periphConfig,
144 void *userData);
145
157 asrc_edma_handle_t *handle,
158 asrc_channel_pair_config_t *asrcConfig,
159 uint32_t inSampleRate,
160 uint32_t outSampleRate);
161
176 ASRC_Type *base, asrc_edma_handle_t *handle, uint32_t inSampleRate, uint32_t outSampleRate, uint32_t inSamplesize);
177
190status_t ASRC_TransferEDMA(ASRC_Type *base, asrc_edma_handle_t *handle, asrc_transfer_t *xfer);
191
201void ASRC_TransferInAbortEDMA(ASRC_Type *base, asrc_edma_handle_t *handle);
202
212void ASRC_TransferOutAbortEDMA(ASRC_Type *base, asrc_edma_handle_t *handle);
213
223void ASRC_TransferInTerminalEDMA(ASRC_Type *base, asrc_edma_handle_t *handle);
224
234void ASRC_TransferOutTerminalEDMA(ASRC_Type *base, asrc_edma_handle_t *handle);
235
237
238#if defined(__cplusplus)
239}
240#endif
241
245#endif
struct _asrc_transfer asrc_transfer_t
SAI transfer structure.
struct _asrc_channel_pair_config asrc_channel_pair_config_t
asrc channel pair configuation
enum _asrc_channel_pair asrc_channel_pair_t
ASRC channel pair mask.
struct _asrc_in_edma_handle asrc_in_edma_handle_t
void(*) asrc_start_peripheral_t(bool start)
ASRC trigger peripheral function pointer.
Definition fsl_asrc_edma.h:36
void ASRC_TransferOutCreateHandleEDMA(ASRC_Type *base, asrc_edma_handle_t *handle, asrc_channel_pair_t channelPair, asrc_edma_callback_t callback, edma_handle_t *outDmaHandle, const asrc_p2p_edma_config_t *periphConfig, void *userData)
Initializes the ASRC OUT eDMA handle.
Definition fsl_asrc_edma.c:164
Terminate In ASRC Convert.
Definition fsl_asrc_edma.c:424
struct _asrc_out_edma_handle asrc_out_edma_handle_t
void ASRC_TransferInCreateHandleEDMA(ASRC_Type *base, asrc_edma_handle_t *handle, asrc_channel_pair_t channelPair, asrc_edma_callback_t callback, edma_handle_t *inDmaHandle, const asrc_p2p_edma_config_t *periphConfig, void *userData)
Initializes the ASRC IN eDMA handle.
Definition fsl_asrc_edma.c:117
Aborts a ASRC OUT transfer using eDMA.
Definition fsl_asrc_edma.c:400
Aborts a ASRC IN transfer using eDMA.
Definition fsl_asrc_edma.c:376
status_t ASRC_TransferSetChannelPairConfigEDMA(ASRC_Type *base, asrc_edma_handle_t *handle, asrc_channel_pair_config_t *asrcConfig, uint32_t inSampleRate, uint32_t outSampleRate)
Configures the ASRC P2P channel pair.
Definition fsl_asrc_edma.c:207
void(*) asrc_edma_callback_t(ASRC_Type *base, asrc_edma_handle_t *handle, status_t status, void *userData)
ASRC eDMA transfer callback function for finish and error.
Definition fsl_asrc_edma.h:33
ASRC IN edma QUEUE size.
Definition fsl_asrc_edma.h:27
Terminate Out ASRC Convert.
Definition fsl_asrc_edma.c:453
struct _asrc_p2p_edma_config asrc_p2p_edma_config_t
destination peripheral configuration
Performs a non-blocking ASRC m2m convert using EDMA.
Definition fsl_asrc_edma.c:350
uint32_t ASRC_GetOutSamplesSizeEDMA(ASRC_Type *base, asrc_edma_handle_t *handle, uint32_t inSampleRate, uint32_t outSampleRate, uint32_t inSamplesize)
Get output sample buffer size can be transferred by edma.
Definition fsl_asrc_edma.c:241
struct _edma_tcd edma_tcd_t
eDMA TCD.
struct _edma_handle edma_handle_t
eDMA transfer handle structure
int32_t status_t
Type used for all status and error return values.
Definition fsl_common.h:225
Definition MIMXRT1166_cm4.h:9338
ASRC DMA transfer handle.
Definition fsl_asrc_edma.h:82
Definition fsl_asrc_edma.h:85
void * userData
Definition fsl_asrc_edma.h:86
asrc_in_edma_handle_t in
Definition fsl_asrc_edma.h:83
Definition fsl_asrc_edma.h:87
asrc_out_edma_handle_t out
Definition fsl_asrc_edma.h:84
Definition fsl_asrc_edma.h:47
Definition fsl_asrc_edma.h:52
const asrc_p2p_edma_config_t * peripheralConfig
Definition fsl_asrc_edma.h:60
Definition fsl_asrc_edma.h:57
uint32_t * asrcQueue[ASRC_XFER_IN_QUEUE_SIZE]
Definition fsl_asrc_edma.h:54
uint32_t state
Definition fsl_asrc_edma.h:58
edma_handle_t * inDmaHandle
Definition fsl_asrc_edma.h:48
size_t transferSize[ASRC_XFER_IN_QUEUE_SIZE]
Definition fsl_asrc_edma.h:55
Definition fsl_asrc_edma.h:53
Definition fsl_asrc_edma.h:56
uint8_t tcd[(ASRC_XFER_IN_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)]
Definition fsl_asrc_edma.h:50
Definition fsl_asrc_edma.h:65
uint32_t * asrcQueue[ASRC_XFER_OUT_QUEUE_SIZE]
Definition fsl_asrc_edma.h:72
edma_handle_t * outDmaHandle
Definition fsl_asrc_edma.h:66
uint32_t state
Definition fsl_asrc_edma.h:76
Definition fsl_asrc_edma.h:74
Definition fsl_asrc_edma.h:71
Definition fsl_asrc_edma.h:75
uint8_t tcd[(ASRC_XFER_OUT_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)]
Definition fsl_asrc_edma.h:68
Definition fsl_asrc_edma.h:73
Definition fsl_asrc_edma.h:77
Definition fsl_asrc_edma.h:70
Definition fsl_asrc_edma.h:39
uint8_t channel
Definition fsl_asrc_edma.h:41
uint8_t watermark
Definition fsl_asrc_edma.h:40
asrc_start_peripheral_t startPeripheral
Definition fsl_asrc_edma.h:42
