48 VBE_vbe_info_block *info_block,
49 uint16_t queried_VBE_Version
63 VBE_mode_info_block *info_block,
78 VBE_CRTC_info_block *info_block
105 uint16_t controller_unit_number,
106 uint8_t *seconds_to_transfer_EDID_block,
107 uint8_t *DDC_level_supported
121 uint16_t controller_unit_number,
122 uint16_t EDID_block_number,
uint32_t VBE_read_EDID(uint16_t controller_unit_number, uint16_t EDID_block_number, EDID_edid1 *buffer)
Reads selected EDID block from display attached to controller's interface.
Definition fb_vesa_rm.c:214
uint32_t VBE_set_mode(uint16_t mode_number, VBE_CRTC_info_block *info_block)
Sets graphics mode selected. If mode has refreshRateCtrl bit set, than the info_block must be filled ...
Definition fb_vesa_rm.c:167
uint32_t VBE_report_DDC_capabilities(uint16_t controller_unit_number, uint8_t *seconds_to_transfer_EDID_block, uint8_t *DDC_level_supported)
Gets information about display data channel implemented in the graphic's controller.
Definition fb_vesa_rm.c:197
uint32_t VBE_current_mode(uint16_t *mode_number)
Get currently set mode number.
Definition fb_vesa_rm.c:187
uint32_t VBE_mode_information(VBE_mode_info_block *info_block, uint16_t mode_number)
Fills structure info_block with informations about selected mode in mode_number variable.
Definition fb_vesa_rm.c:144
uint32_t VBE_controller_information(VBE_vbe_info_block *info_block, uint16_t queried_VBE_Version)
Returns information about graphic's controller in the info_block structure.
Definition fb_vesa_rm.c:113
VESA Bios Extension definitions.
