RTEMS
6.3
Toggle main menu visibility
libmisc
shell
extern-dd.h
1
2
* Copyright (c) 1991, 1993, 1994
3
* The Regents of the University of California. All rights reserved.
4
5
* This code is derived from software contributed to Berkeley by
6
* Keith Muller of the University of California, San Diego and Lance
7
* Visser of Convex Computer Corporation.
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
* 4. Neither the name of the University nor the names of its contributors
18
* may be used to endorse or promote products derived from this software
19
* without specific prior written permission.
20
21
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31
* SUCH DAMAGE.
32
33
* @(#)extern.h 8.3 (Berkeley) 4/2/94
34
* $FreeBSD: src/bin/dd/extern.h,v 1.15 2004/08/15 19:10:05 rwatson Exp $
35
36
37
#ifndef _EXTERN_DD_H_
38
#define _EXTERN_DD_H_
39
40
#include <setjmp.h>
41
42
typedef
struct
rtems_shell_dd_globals_t
43
rtems_shell_dd_IO
in, out;
/* input/output state */
44
rtems_shell_dd_STAT
st;
/* statistics */
45
void (*cfunc)(
struct
* globals);
/* conversion function */
46
uintmax_t cpy_cnt;
/* # of blocks to copy */
47
u_int ddflags;
/* conversion options */
48
size_t
cbsz;
/* conversion block size */
49
uintmax_t files_cnt;
/* # of files to copy */
50
const
u_char *ctab;
/* conversion table */
51
char
fill_char;
/* Character to fill with if defined */
52
u_char casetab[256];
53
int
exit_code;
54
jmp_buf exit_jmp;
55
} rtems_shell_dd_globals;
56
57
#define in globals->in
58
#define out globals->out
59
#define st globals->st
60
#define cfunc globals->cfunc
61
#define cpy_cnt globals->cpy_cnt
62
#define ddflags globals->ddflags
63
#define cbsz globals->cbsz
64
#define files_cnt globals->files_cnt
65
#define casetab globals->casetab
66
#define ctab globals->ctab
67
#define fill_char globals->fill_char
68
#define exit_jump &(globals->exit_jmp)
69
70
#define block rtems_shell_dd_block
71
#define block_close rtems_shell_dd_block_close
72
#define dd_out rtems_shell_dd_dd_out
73
#define def rtems_shell_dd_def
74
#define def_close rtems_shell_dd_def_close
75
#define jcl rtems_shell_dd_jcl
76
#define pos_in rtems_shell_dd_pos_in
77
#define pos_out rtems_shell_dd_pos_out
78
#define summary rtems_shell_dd_summary
79
#define summaryx rtems_shell_dd_summaryx
80
#define terminate rtems_shell_dd_terminate
81
#define unblock rtems_shell_dd_unblock
82
#define unblock_close rtems_shell_dd_unblock_close
83
84
void
block(rtems_shell_dd_globals* );
85
void
block_close(rtems_shell_dd_globals* );
86
void
dd_out(rtems_shell_dd_globals* ,
int
87
void
def(rtems_shell_dd_globals* globals);
88
void
def_close(rtems_shell_dd_globals* );
89
void
jcl(rtems_shell_dd_globals* ,
char
90
void
pos_in(rtems_shell_dd_globals* );
91
void
pos_out(rtems_shell_dd_globals* );
92
void
summary(rtems_shell_dd_globals* );
93
void
summaryx(rtems_shell_dd_globals* ,
int
94
void
terminate(
int
95
void
unblock(rtems_shell_dd_globals* globals);
96
void
unblock_close(rtems_shell_dd_globals* globals);
97
98
extern
const
u_char a2e_32V[256], a2e_POSIX[256];
99
extern
const
u_char e2a_32V[256], e2a_POSIX[256];
100
extern
const
u_char a2ibm_32V[256], a2ibm_POSIX[256];
101
102
void
rtems_shell_dd_exit(rtems_shell_dd_globals* globals,
int
code
103
104
#define exit(ec) rtems_shell_dd_exit(globals, ec)
105
106
#endif
/* !_EXTERN_H_ */
code
Definition
inftrees.h:24
rtems_shell_dd_IO
Definition
dd.h:45
rtems_shell_dd_STAT
Definition
dd.h:66
Definition
extern-dd.h:42
