RTEMS
6.3
Toggle main menu visibility
bsps
i386
pc386
include
bsp
exar17d15x.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* COPYRIGHT (c) 1989-2012.
13
* On-Line Applications Research Corporation (OAR).
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _BSP_EXAR17D15X__h
38
#define _BSP_EXAR17D15X__h
39
40
#ifdef __cplusplus
41
extern
"C"
42
#endif
43
48
#define EXAR17D15X_DRIVER_TABLE_ENTRY \
49
{ exar17d15x_initialize, NULL, NULL, NULL, NULL, NULL }
50
63
rtems_device_driver
64
rtems_device_major_number
major,
65
rtems_device_minor_number
minor,
66
void
*arg
67
68
69
#ifdef __cplusplus
70
71
#endif
72
73
#endif
74
/* end of include file */
rtems_device_driver exar17d15x_initialize(rtems_device_major_number major, rtems_device_minor_number minor_arg, void *arg)
Exar 17D15x Initialization Entry Point.
Definition
exar17d15x.c:115
rtems_device_driver
rtems_status_code rtems_device_driver
This type shall be used in device driver entry declarations and definitions.
Definition
io.h:90
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition
io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition
io.h:115
