RTEMS
6.3
Toggle main menu visibility
bsps
bfin
include
libcpu
ethernet.h
1
2
* RTEMS network driver for Blackfin embedded ethernet controller
3
4
* COPYRIGHT (c) 2008 Kallisti Labs, Los Gatos, CA, USA
5
* written by Allan Hessenflow <allanh@kallisti.com>
6
7
* The license and distribution terms for this file may be
8
* found in the file LICENSE in this distribution or at
9
* http://www.rtems.org/license/LICENSE.
10
11
12
#ifndef _ethernet_h_
13
#define _ethernet_h_
14
15
16
#define BFIN_ETHERNET_DEBUG_NONE 0x0000
17
#define BFIN_ETHERNET_DEBUG_ALL 0xFFFF
18
19
#define BFIN_ETHERNET_DEBUG (BFIN_ETHERNET_DEBUG_NONE)
20
21
22
#ifdef __cplusplus
23
extern
"C"
24
#endif
25
26
27
typedef
struct
28
uint32_t sclk;
29
void
*ethBaseAddress;
30
void
*rxdmaBaseAddress;
31
void
*txdmaBaseAddress;
32
int
rxDescCount;
33
int
txDescCount;
34
enum
{rmii, mii} phyType;
35
int
phyAddr;
36
bfin_ethernet_configuration_t
37
38
39
void
bfin_ethernet_rxdma_isr(
int
vector);
40
void
bfin_ethernet_txdma_isr(
int
vector);
41
void
bfin_ethernet_mac_isr(
int
vector);
42
43
int
bfin_ethernet_driver_attach(
struct
rtems_bsdnet_ifconfig *config,
44
int
attaching,
45
*chip);
46
47
48
#ifdef __cplusplus
49
50
#endif
51
52
53
#endif
/* _ethernet_h_ */
54
Definition
ethernet.h:27
