RTEMS 6.3
erc32.h File Reference
Contains information pertaining to the ERC32. More...
struct  ERC32_Register_Map
#define ERC32_INTERRUPT_MASKED_ERRORS   1
#define ERC32_INTERRUPT_EXTERNAL_1   2
#define ERC32_INTERRUPT_EXTERNAL_2   3
#define ERC32_INTERRUPT_UART_A_RX_TX   4
#define ERC32_INTERRUPT_UART_B_RX_TX   5
#define ERC32_INTERRUPT_CORRECTABLE_MEMORY_ERROR   6
#define ERC32_INTERRUPT_UART_ERROR   7
#define ERC32_INTERRUPT_DMA_ACCESS_ERROR   8
#define ERC32_INTERRUPT_DMA_TIMEOUT   9
#define ERC32_INTERRUPT_EXTERNAL_3   10
#define ERC32_INTERRUPT_EXTERNAL_4   11
#define ERC32_INTERRUPT_GENERAL_PURPOSE_TIMER   12
#define ERC32_INTERRUPT_REAL_TIME_CLOCK   13
#define ERC32_INTERRUPT_EXTERNAL_5   14
#define ERC32_INTERRUPT_WATCHDOG_TIMEOUT   15
#define ERC32_TRAP_TYPE(_source)
#define ERC32_TRAP_SOURCE(_trap)
#define ERC32_Is_MEC_Trap(_trap)
#define ERC32_CONFIGURATION_POWER_DOWN_MASK   0x00000001
#define ERC32_CONFIGURATION_POWER_DOWN_ALLOWED   0x00000001
#define ERC32_CONFIGURATION_POWER_DOWN_DISABLED   0x00000000
#define ERC32_CONFIGURATION_SOFTWARE_RESET_MASK   0x00000002
#define ERC32_CONFIGURATION_SOFTWARE_RESET_ALLOWED   0x00000002
#define ERC32_CONFIGURATION_SOFTWARE_RESET_DISABLED   0x00000000
#define ERC32_CONFIGURATION_BUS_TIMEOUT_MASK   0x00000004
#define ERC32_CONFIGURATION_BUS_TIMEOUT_ENABLED   0x00000004
#define ERC32_CONFIGURATION_BUS_TIMEOUT_DISABLED   0x00000000
#define ERC32_CONFIGURATION_ACCESS_PROTECTION_MASK   0x00000008
#define ERC32_CONFIGURATION_ACCESS_PROTECTION_ENABLED   0x00000008
#define ERC32_CONFIGURATION_ACCESS_PROTECTION_DISABLED   0x00000000
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_MASK   0x00001C00
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_256K   ( 0 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_512K   ( 1 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_1MB   ( 2 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_2MB   ( 3 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_4MB   ( 4 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_8MB   ( 5 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_16MB   ( 6 << 10 )
#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_32MB   ( 7 << 10 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_MASK   0x001C0000
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_128K   ( 0 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_256K   ( 1 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_512K   ( 2 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_1M   ( 3 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_2M   ( 4 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_4M   ( 5 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_8M   ( 6 << 18 )
#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_16M   ( 7 << 18 )
#define ERC32_MEC_TIMER_CONTROL_GCR   0x00000001
#define ERC32_MEC_TIMER_CONTROL_GCL   0x00000002
#define ERC32_MEC_TIMER_CONTROL_GSE   0x00000004
#define ERC32_MEC_TIMER_CONTROL_GSL   0x00000008
#define ERC32_MEC_TIMER_CONTROL_RTCCR   0x00000100
#define ERC32_MEC_TIMER_CONTROL_RTCCL   0x00000200
#define ERC32_MEC_TIMER_CONTROL_RTCSE   0x00000400
#define ERC32_MEC_TIMER_CONTROL_RTCSL   0x00000800
#define ERC32_MEC_UART_CONTROL_RTD   0x000000FF
#define ERC32_MEC_UART_STATUS_DR   0x00000001
#define ERC32_MEC_UART_STATUS_TSE   0x00000002
#define ERC32_MEC_UART_STATUS_THE   0x00000004
#define ERC32_MEC_UART_STATUS_FE   0x00000010
#define ERC32_MEC_UART_STATUS_PE   0x00000020
#define ERC32_MEC_UART_STATUS_OE   0x00000040
#define ERC32_MEC_UART_STATUS_CU   0x00000080
#define ERC32_MEC_UART_STATUS_TXE   0x00000006
#define ERC32_MEC_UART_STATUS_CLRA   0x00000080
#define ERC32_MEC_UART_STATUS_CLRB   0x00800000
#define ERC32_MEC_UART_STATUS_ERRA   0x00000070
#define ERC32_MEC_UART_STATUS_ERRB   0x00700000
#define ERC32_MEC_UART_STATUS_DRA   (ERC32_MEC_UART_STATUS_DR << 0)
#define ERC32_MEC_UART_STATUS_TSEA   (ERC32_MEC_UART_STATUS_TSE << 0)
#define ERC32_MEC_UART_STATUS_THEA   (ERC32_MEC_UART_STATUS_THE << 0)
#define ERC32_MEC_UART_STATUS_FEA   (ERC32_MEC_UART_STATUS_FE << 0)
#define ERC32_MEC_UART_STATUS_PEA   (ERC32_MEC_UART_STATUS_PE << 0)
#define ERC32_MEC_UART_STATUS_OEA   (ERC32_MEC_UART_STATUS_OE << 0)
#define ERC32_MEC_UART_STATUS_CUA   (ERC32_MEC_UART_STATUS_CU << 0)
#define ERC32_MEC_UART_STATUS_TXEA   (ERC32_MEC_UART_STATUS_TXE << 0)
#define ERC32_MEC_UART_STATUS_DRB   (ERC32_MEC_UART_STATUS_DR << 16)
#define ERC32_MEC_UART_STATUS_TSEB   (ERC32_MEC_UART_STATUS_TSE << 16)
#define ERC32_MEC_UART_STATUS_THEB   (ERC32_MEC_UART_STATUS_THE << 16)
#define ERC32_MEC_UART_STATUS_FEB   (ERC32_MEC_UART_STATUS_FE << 16)
#define ERC32_MEC_UART_STATUS_PEB   (ERC32_MEC_UART_STATUS_PE << 16)
#define ERC32_MEC_UART_STATUS_OEB   (ERC32_MEC_UART_STATUS_OE << 16)
#define ERC32_MEC_UART_STATUS_CUB   (ERC32_MEC_UART_STATUS_CU << 16)
#define ERC32_MEC_UART_STATUS_TXEB   (ERC32_MEC_UART_STATUS_TXE << 16)
#define ERC32_Clear_interrupt(_source)
#define ERC32_Force_interrupt(_source)
#define ERC32_Is_interrupt_pending(_source)
#define ERC32_Is_interrupt_masked(_source)
#define ERC32_Mask_interrupt(_source)
#define ERC32_Unmask_interrupt(_source)
#define ERC32_Disable_interrupt(_source, _previous)
#define ERC32_Restore_interrupt(_source, _previous)
#define BSP_Clear_interrupt(_source)
#define BSP_Force_interrupt(_source)
#define BSP_Clear_forced_interrupt(_source)
#define BSP_Is_interrupt_pending(_source)
#define BSP_Is_interrupt_forced(_source)
#define BSP_Is_interrupt_masked(_source)
#define BSP_Unmask_interrupt(_source)
#define BSP_Mask_interrupt(_source)
#define BSP_Disable_interrupt(_source, _previous)
#define BSP_Restore_interrupt(_source, _previous)
#define BSP_Cpu_Is_interrupt_masked(_source, _cpu)
#define BSP_Cpu_Unmask_interrupt(_source, _cpu)
#define BSP_Cpu_Mask_interrupt(_source, _cpu)
#define BSP_Cpu_Disable_interrupt(_source, _previous, _cpu)
#define BSP_Cpu_Restore_interrupt(_source, _previous, _cpu)
#define ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO   0x00000001
#define ERC32_MEC_TIMER_COUNTER_STOP_AT_ZERO   0x00000000
#define ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER   0x00000002
#define ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING   0x00000004
#define ERC32_MEC_TIMER_COUNTER_DISABLE_COUNTING   0x00000000
#define ERC32_MEC_TIMER_COUNTER_LOAD_SCALER   0x00000008
#define ERC32_MEC_TIMER_COUNTER_RELOAD_MASK   0x00000001
#define ERC32_MEC_TIMER_COUNTER_ENABLE_MASK   0x00000004
#define ERC32_MEC_TIMER_COUNTER_DEFINED_MASK   0x0000000F
#define ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK   0x00000005
#define ERC32_MEC_Set_General_Purpose_Timer_Control(_value)
#define ERC32_MEC_Get_General_Purpose_Timer_Control(_value)
#define ERC32_MEC_Set_Real_Time_Clock_Timer_Control(_value)
#define ERC32_MEC_Get_Real_Time_Clock_Timer_Control(_value)
ERC32_Register_Map ERC32_MEC
uint32_t _ERC32_MEC_Timer_Control_Mirror
◆ BSP_Clear_forced_interrupt
#define BSP_Clear_forced_interrupt ( _source)
Value:
do { \
uint32_t _level; \
_level = sparc_disable_interrupts(); \
ERC32_MEC.Interrupt_Force &= ~(1 << (_source)); \
sparc_enable_interrupts( _level ); \
} while (0)
◆ BSP_Clear_interrupt
#define BSP_Clear_interrupt ( _source)
Value:
◆ BSP_Cpu_Disable_interrupt
#define BSP_Cpu_Disable_interrupt ( _source,
_previous,
_cpu )
Value:
BSP_Disable_interrupt(_source, _prev)
◆ BSP_Cpu_Is_interrupt_masked
#define BSP_Cpu_Is_interrupt_masked ( _source,
_cpu )
Value:
◆ BSP_Cpu_Mask_interrupt
#define BSP_Cpu_Mask_interrupt ( _source,
_cpu )
Value:
◆ BSP_Cpu_Restore_interrupt
#define BSP_Cpu_Restore_interrupt ( _source,
_previous,
_cpu )
Value:
BSP_Cpu_Restore_interrupt(_source, _previous)
◆ BSP_Cpu_Unmask_interrupt
#define BSP_Cpu_Unmask_interrupt ( _source,
_cpu )
Value:
◆ BSP_Disable_interrupt
#define BSP_Disable_interrupt ( _source,
_previous )
Value:
ERC32_Disable_interrupt(_source, _prev)
◆ BSP_Force_interrupt
#define BSP_Force_interrupt ( _source)
Value:
◆ BSP_Is_interrupt_forced
#define BSP_Is_interrupt_forced ( _source)
Value:
(ERC32_MEC.Interrupt_Force & (1 << (_source)))
◆ BSP_Is_interrupt_masked
#define BSP_Is_interrupt_masked ( _source)
Value:
◆ BSP_Is_interrupt_pending
#define BSP_Is_interrupt_pending ( _source)
Value:
◆ BSP_Mask_interrupt
#define BSP_Mask_interrupt ( _source)
Value:
◆ BSP_Restore_interrupt
#define BSP_Restore_interrupt ( _source,
_previous )
Value:
◆ BSP_Unmask_interrupt
#define BSP_Unmask_interrupt ( _source)
Value:
◆ ERC32_Clear_interrupt
#define ERC32_Clear_interrupt ( _source)
Value:
do { \
ERC32_MEC.Interrupt_Clear = (1 << (_source)); \
} while (0)
◆ ERC32_Disable_interrupt
#define ERC32_Disable_interrupt ( _source,
_previous )
Value:
do { \
uint32_t _level; \
uint32_t _mask = 1 << (_source); \
(_previous) = ERC32_MEC.Interrupt_Mask; \
ERC32_MEC.Interrupt_Mask = _previous | _mask; \
(_previous) &= _mask; \
} while (0)
◆ ERC32_Force_interrupt
#define ERC32_Force_interrupt ( _source)
Value:
do { \
uint32_t _level; \
ERC32_MEC.Test_Control = ERC32_MEC.Test_Control | 0x80000; \
ERC32_MEC.Interrupt_Force |= (1 << (_source)); \
} while (0)
◆ ERC32_Is_interrupt_masked
#define ERC32_Is_interrupt_masked ( _source)
Value:
(ERC32_MEC.Interrupt_Mask & (1 << (_source)))
◆ ERC32_Is_interrupt_pending
#define ERC32_Is_interrupt_pending ( _source)
Value:
(ERC32_MEC.Interrupt_Pending & (1 << (_source)))
◆ ERC32_Is_MEC_Trap
#define ERC32_Is_MEC_Trap ( _trap)
Value:
#define SPARC_IS_INTERRUPT_TRAP(_trap)
Checks if the real hardware vector number, synchronous trap number, or asynchronous trap number is an...
Definition sparc.h:243
◆ ERC32_Mask_interrupt
#define ERC32_Mask_interrupt ( _source)
Value:
do { \
uint32_t _level; \
ERC32_MEC.Interrupt_Mask |= (1 << (_source)); \
} while (0)
◆ ERC32_MEC_Get_General_Purpose_Timer_Control
#define ERC32_MEC_Get_General_Purpose_Timer_Control ( _value)
Value:
do { \
(_value) = _ERC32_MEC_Timer_Control_Mirror & 0xf; \
} while ( 0 )
◆ ERC32_MEC_Get_Real_Time_Clock_Timer_Control
#define ERC32_MEC_Get_Real_Time_Clock_Timer_Control ( _value)
Value:
do { \
(_value) = (_ERC32_MEC_Timer_Control_Mirror >> 8) & 0xf; \
} while ( 0 )
◆ ERC32_MEC_Set_General_Purpose_Timer_Control
#define ERC32_MEC_Set_General_Purpose_Timer_Control ( _value)
Value:
do { \
uint32_t _level; \
uint32_t _control; \
uint32_t __value; \
__value = ((_value) & 0x0f); \
_control = _ERC32_MEC_Timer_Control_Mirror; \
_control &= ERC32_MEC_TIMER_COUNTER_DEFINED_MASK << 8; \
_ERC32_MEC_Timer_Control_Mirror = _control | _value; \
_control &= (ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK << 8); \
_control |= __value; \
ERC32_MEC.Timer_Control = _control; \
} while ( 0 )
◆ ERC32_MEC_Set_Real_Time_Clock_Timer_Control
#define ERC32_MEC_Set_Real_Time_Clock_Timer_Control ( _value)
Value:
do { \
uint32_t _level; \
uint32_t __value; \
__value = ((_value) & 0x0f) << 8; \
_control &= ERC32_MEC_TIMER_COUNTER_DEFINED_MASK; \
_ERC32_MEC_Timer_Control_Mirror = _control | __value; \
_control &= ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK; \
} while ( 0 )
◆ ERC32_Restore_interrupt
#define ERC32_Restore_interrupt ( _source,
_previous )
Value:
do { \
uint32_t _level; \
ERC32_MEC.Interrupt_Mask = \
(ERC32_MEC.Interrupt_Mask & ~_mask) | (_previous); \
} while (0)
◆ ERC32_TRAP_SOURCE
#define ERC32_TRAP_SOURCE ( _trap)
Value:
#define SPARC_INTERRUPT_TRAP_TO_SOURCE(_trap)
Maps the interrupt trap number to the associated interrupt source number.
Definition sparc.h:261
◆ ERC32_TRAP_TYPE
#define ERC32_TRAP_TYPE ( _source)
Value:
#define SPARC_INTERRUPT_SOURCE_TO_TRAP(_source)
Maps the interrupt source number to the associated asynchronous trap number.
Definition sparc.h:273
◆ ERC32_Unmask_interrupt
#define ERC32_Unmask_interrupt ( _source)
Value:
do { \
uint32_t _level; \
ERC32_MEC.Interrupt_Mask &= ~(1 << (_source)); \
} while (0)
