RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
beatnik
include
bsp
early_enet_link_status.h
1
#ifndef BSP_EARLY_ENET_LINK_STATUS_H
2
#define BSP_EARLY_ENET_LINK_STATUS_H
3
4
/* Determine link status of ethernet device before network is initialized */
5
6
/* T. Straumann, 2005; see ../../LICENSE */
7
8
rtems.h
9
10
#ifdef __cplusplus
11
extern
"C"
12
#endif
13
14
typedef
struct
15
int (*init)(
int
idx);
/* perform enough initialization to access (default) phy */
16
int (*read_phy)(
int
idx,
unsigned
reg);
17
int (*write_phy)(
int
idx,
unsigned
reg,
unsigned
val);
18
const
char
*name;
/* driver name */
19
unsigned
char
num_slots;
/* max number of supported devices */
20
unsigned
char
initialized;
/* must be initialized to 0; */
21
rtems_bsdnet_early_link_check_ops
22
23
int
24
BSP_early_check_link_status(
int
unit,
*ops);
25
26
#ifdef __cplusplus
27
28
#endif
29
30
#endif
rtems.h
Definition
early_enet_link_status.h:14
