RTEMS
6.3
Toggle main menu visibility
libdrvmgr
drvmgr_internal.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* Private driver manager declarations
4
5
* COPYRIGHT (c) 2009 Cobham Gaisler AB.
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
16
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
17
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
20
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
21
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
22
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
23
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
24
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
25
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
26
* POSSIBILITY OF SUCH DAMAGE.
27
28
29
rtems/score/apimutex.h
30
31
/* Structure hold all information the driver manager needs to know of. Used
32
* internally by Driver Manager routines.
33
34
struct
drvmgr
35
int
level;
36
int
initializing_objs;
37
38
/* Device tree Lock */
39
API_Mutex_Control
lock;
40
41
/* The first device - The root device and it's driver */
42
struct
drvmgr_drv
*root_drv;
43
struct
drvmgr_dev
root_dev
44
46
struct
drvmgr_list
drivers;
47
48
/* Buses that reached a certain initialization level.
49
* Lists by Level:
50
* N=0 - Not intialized, just registered
51
* N=1..MAX-1 - Reached init level N
52
* N=MAX - Successfully initialized bus
53
54
struct
drvmgr_list
buses[DRVMGR_LEVEL_MAX+1];
55
/* Buses failed to initialize or has been removed by not freed */
56
struct
drvmgr_list
buses_inactive;
57
58
/* Devices that reached a certain initialization level.
59
* Lists by Level:
60
61
62
* N=MAX - Successfully initialized device
63
64
struct
drvmgr_list
devices
66
struct
drvmgr_list
devices_inactive;
67
68
69
extern
struct
drvmgr
drvmgr
70
71
extern
void
_DRV_Manager_Lock(
void
72
extern
void
_DRV_Manager_Unlock(
void
73
74
/* The best solution is to implement the locking with a RW lock, however there
75
* is no such API available. Care must be taken so that dead-lock isn't created
76
* for example in recursive functions.
77
78
#if defined(DRVMGR_USE_LOCKS) && (DRVMGR_USE_LOCKS == 1)
79
#define DRVMGR_LOCK_WRITE() _DRV_Manager_Lock()
80
#define DRVMGR_LOCK_READ() _DRV_Manager_Lock()
81
#define DRVMGR_UNLOCK() _DRV_Manager_Unlock()
82
#else
83
/* no locking */
84
85
86
87
#endif
apimutex.h
This header file provides the interfaces of the API Mutex Handler.
API_Mutex_Control
Control block used to manage each API mutex.
Definition
apimutex.h:65
drvmgr_dev
Definition
drvmgr.h:299
drvmgr_drv
Definition
drvmgr.h:329
drvmgr_list
Definition
drvmgr_list.h:48
drvmgr
Definition
drvmgr_internal.h:34
drvmgr::devices
struct drvmgr_list devices[DRVMGR_LEVEL_MAX+1]
Definition
drvmgr_internal.h:64
drvmgr::root_dev
struct drvmgr_dev root_dev
Definition
drvmgr_internal.h:43
