RTEMS
6.3
Toggle main menu visibility
bsps
bfin
include
libcpu
dmaRegs.h
1
/* Blackfin DMA Registers
2
3
* Copyright (c) 2008 Kallisti Labs, Los Gatos, CA, USA
4
* written by Allan Hessenflow <allanh@kallisti.com>
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef _dmaRegs_h_
12
#define _dmaRegs_h_
13
14
15
/* register addresses */
16
17
#define DMA_NEXT_DESC_PTR_OFFSET 0x0000
18
#define DMA_START_ADDR_OFFSET 0x0004
19
#define DMA_CONFIG_OFFSET 0x0008
20
#define DMA_X_COUNT_OFFSET 0x0010
21
#define DMA_X_MODIFY_OFFSET 0x0014
22
#define DMA_Y_COUNT_OFFSET 0x0018
23
#define DMA_Y_MODIFY_OFFSET 0x001c
24
#define DMA_CURR_DESC_PTR_OFFSET 0x0020
25
#define DMA_CURR_ADDR_OFFSET 0x0024
26
#define DMA_IRQ_STATUS_OFFSET 0x0028
27
#define DMA_PERIPHERAL_MAP_OFFSET 0x002c
28
#define DMA_CURR_X_COUNT_OFFSET 0x0030
29
#define DMA_CURR_Y_COUNT_OFFSET 0x0038
30
31
#define HMDMA_CONTROL_OFFSET 0x0000
32
#define HMDMA_ECINIT_OFFSET 0x0004
33
#define HMDMA_BCINIT_OFFSET 0x0008
34
#define HMDMA_ECURGENT_OFFSET 0x000c
35
#define HMDMA_ECOVERFLOW_OFFSET 0x0010
36
#define HMDMA_ECOUNT_OFFSET 0x0014
37
#define HMDMA_BCOUNT_OFFSET 0x0018
38
39
40
/* register fields */
41
42
#define DMA_CONFIG_FLOW_MASK 0x7000
43
#define DMA_CONFIG_FLOW_STOP 0x0000
44
#define DMA_CONFIG_FLOW_AUTOBUFFER 0x1000
45
#define DMA_CONFIG_FLOW_DESC_ARRAY 0x4000
46
#define DMA_CONFIG_FLOW_DESC_SMALL 0x6000
47
#define DMA_CONFIG_FLOW_DESC_LARGE 0x7000
48
#define DMA_CONFIG_NDSIZE_MASK 0x0f00
49
#define DMA_CONFIG_NDSIZE_SHIFT 8
50
#define DMA_CONFIG_DI_EN 0x0080
51
#define DMA_CONFIG_DI_SEL 0x0040
52
#define DMA_CONFIG_SYNC 0x0020
53
#define DMA_CONFIG_DMA2D 0x0010
54
#define DMA_CONFIG_WDSIZE_MASK 0x000c
55
#define DMA_CONFIG_WDSIZE_8 0x0000
56
#define DMA_CONFIG_WDSIZE_16 0x0004
57
#define DMA_CONFIG_WDSIZE_32 0x0008
58
#define DMA_CONFIG_WNR 0x0002
59
#define DMA_CONFIG_DMAEN 0x0001
60
61
#define DMA_IRQ_STATUS_DMA_RUN 0x0008
62
#define DMA_IRQ_STATUS_DFETCH 0x0004
63
#define DMA_IRQ_STATUS_DMA_ERR 0x0002
64
#define DMA_IRQ_STATUS_DMA_DONE 0x0001
65
66
#define DMA_PERIPHERAL_MAP_PMAP_MASK 0xf000
67
#define DMA_PERIPHERAL_MAP_PMAP_PPI 0x0000
68
#define DMA_PERIPHERAL_MAP_PMAP_ETHRX 0x1000
69
#define DMA_PERIPHERAL_MAP_PMAP_ETHTX 0x2000
70
#define DMA_PERIPHERAL_MAP_PMAP_SPORT0RX 0x3000
71
#define DMA_PERIPHERAL_MAP_PMAP_SPORT0TX 0x4000
72
#define DMA_PERIPHERAL_MAP_PMAP_SPORT1RX 0x5000
73
#define DMA_PERIPHERAL_MAP_PMAP_SPORT1TX 0x6000
74
#define DMA_PERIPHERAL_MAP_PMAP_SPI 0x7000
75
#define DMA_PERIPHERAL_MAP_PMAP_UART0RX 0x8000
76
#define DMA_PERIPHERAL_MAP_PMAP_UART0TX 0x9000
77
#define DMA_PERIPHERAL_MAP_PMAP_UART1RX 0xa000
78
#define DMA_PERIPHERAL_MAP_PMAP_UART1TX 0xb000
79
#define DMA_PERIPHERAL_MAP_CTYPE 0x0040
80
81
#define HMDMA_CONTROL_BDI 0x8000
82
#define HMDMA_CONTROL_OI 0x4000
83
#define HMDMA_CONTROL_PS 0x2000
84
#define HMDMA_CONTROL_RBC 0x1000
85
#define HMDMA_CONTROL_DRQ_MASK 0x0300
86
#define HMDMA_CONTROL_DRQ_NONE 0x0000
87
#define HMDMA_CONTROL_DRQ_SINGLE 0x0100
88
#define HMDMA_CONTROL_DRQ_MULTIPLE 0x0200
89
#define HMDMA_CONTROL_DRQ_URGENT_MULTIPLE 0x0300
90
#define HMDMA_CONTROL_MBDI 0x0040
91
#define HMDMA_CONTROL_BDIE 0x0020
92
#define HMDMA_CONTROL_OIE 0x0010
93
#define HMDMA_CONTROL_UTE 0x0008
94
#define HMDMA_CONTROL_REP 0x0002
95
#define HMDMA_CONTROL_HMDMAEN 0x0001
96
97
#endif
/* _dmaRegs_h_ */
