RTEMS
6.3
Toggle main menu visibility
bsps
shared
dev
display
disp_fonts.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Display driver for HCMS29xx.
5
6
* This file declares general data structures for font management.
7
8
9
10
* Copyright (c) 2008 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef DISP_FONTS_H
35
#define DISP_FONTS_H
36
37
rtems.h
38
39
typedef
int8_t disp_font_dimen;
40
41
struct
disp_font_bounding_box
42
43
disp_font_dimen w, h, x, y;
44
45
46
struct
disp_font_glyph
47
48
struct
bb;
49
disp_font_dimen wx, wy;
50
const
unsigned
char
*bitmap;
51
52
53
struct
disp_font_base
54
55
int8_t trans;
56
struct
fbb;
57
disp_font_dimen ascent, descent;
58
uint8_t default_char;
59
struct
disp_font_glyph
*latin1[256];
60
61
62
typedef
struct
disp_font_base
*disp_font_t;
63
64
/* Prototypes ------------------------------------------------- */
65
66
/* End -------------------------------------------------------- */
67
68
#endif
/* not defined DISP_FONTS_H */
rtems.h
disp_font_base
Definition
disp_fonts.h:54
Definition
disp_fonts.h:42
disp_font_glyph
Definition
disp_fonts.h:47
