RTEMS 6.3
dac_dma.h File Reference
#include "chip.h"
#include <stdint.h>
#include <assert.h>
struct  DacCmd
 Dac Transfer Request prepared by the application upper layer. More...
struct  DacDma
#define DAC_OK   0
#define DAC_ERROR   1
#define DAC_ERROR_LOCK   2
#define DACC_CHANNEL_0   0
#define DACC_CHANNEL_1   1
#define DACC_SoftReset(pDACC)
#define DACC_CfgModeReg(pDACC, mode)
#define DACC_GetModeReg(pDACC)
#define DACC_CfgTrigger(pDACC, mode)
#define DACC_EnableChannel(pDACC, channel)
#define DACC_DisableChannel(pDACC, channel)
#define DACC_EnableIt(pDACC, mode)
#define DACC_DisableIt(pDACC, mode)
#define DACC_GetStatus(pDACC)
#define DACC_GetChannelStatus(pDACC)
#define DACC_GetInterruptMaskStatus(pDACC)
typedef void(*) DacCallback(uint8_t, void *)
uint32_t Dac_ConfigureDma (DacDma *pDacd, Dacc *pDacHw, uint8_t DacId, sXdmad *pXdmad)
 Initializes the DacDma structure and the corresponding DAC & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing.
uint32_t Dac_SendData (DacDma *pDacd, DacCmd *pCommand)
 Starts a DAC transfer. This is a non blocking function. It will return as soon as the transfer is started.
Purpose
Interface for configuration the Analog-to-Digital Converter (DACC) peripheral.
Usage
  1. Configurate the pins for DACC
  2. Initialize the DACC with DACC_Initialize().
  3. Select the active channel using DACC_EnableChannel()
  4. Start the conversion with DACC_StartConversion()
  5. Wait the end of the conversion by polling status with DACC_GetStatus()
  6. Finally, get the converted data using DACC_GetConvertedData()
◆ DACC_CfgModeReg
#define DACC_CfgModeReg ( pDACC,
mode )
Value:
{ (pDACC)->DACC_MR = (mode); }
◆ DACC_CfgTrigger
#define DACC_CfgTrigger ( pDACC,
mode )
Value:
{ (pDACC)->DACC_TRIGR = (mode); }
◆ DACC_DisableChannel
#define DACC_DisableChannel ( pDACC,
channel )
Value:
{(pDACC)->DACC_CHDR = (1 << (channel));}
◆ DACC_DisableIt
#define DACC_DisableIt ( pDACC,
mode )
Value:
{(pDACC)->DACC_IDR = (mode);}
◆ DACC_EnableChannel
#define DACC_EnableChannel ( pDACC,
channel )
Value:
{(pDACC)->DACC_CHER = (1 << (channel));}
◆ DACC_EnableIt
#define DACC_EnableIt ( pDACC,
mode )
Value:
{(pDACC)->DACC_IER = (mode);}
◆ DACC_GetChannelStatus
#define DACC_GetChannelStatus ( pDACC)
Value:
((pDACC)->DACC_CHSR)
◆ DACC_GetInterruptMaskStatus
#define DACC_GetInterruptMaskStatus ( pDACC)
Value:
((pDACC)->DACC_IMR)
◆ DACC_GetModeReg
#define DACC_GetModeReg ( pDACC)
Value:
((pDACC)->DACC_MR)
◆ DACC_GetStatus
#define DACC_GetStatus ( pDACC)
Value:
((pDACC)->DACC_ISR)
◆ DACC_SoftReset
#define DACC_SoftReset ( pDACC)
Value:
((pDACC)->DACC_CR = DACC_CR_SWRST)
Typedef Documentation
◆ DacCallback
DAC transfer complete callback.
◆ Dac_ConfigureDma()
uint32_t Dac_ConfigureDma ( DacDma * pDacd,
Dacc * pDacHw,
uint8_t DacId,
sXdmad * pXdmad )
extern
Parameters
pDacdPointer to a DacDma instance.
pDacHwAssociated Dac peripheral.
DacIdDac peripheral identifier.
pDmadPointer to a Dmad instance.
◆ Dac_SendData()
uint32_t Dac_SendData ( DacDma * pDacd,
DacCmd * pCommand )
extern
Parameters
pCommandPointer to the Dac command to execute.
Returns
0 if the transfer has been started successfully; otherwise returns DAC_ERROR_LOCK is the driver is in use, or DAC_ERROR if the command is not valid.
