RTEMS
6.3
Toggle main menu visibility
include
pci
irq.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
/* IRQ handling does not have so much with PCI to do, this library depends
35
* on the BSP to implement shared interrupts.
36
37
38
#ifndef __PCI_IRQ_H__
39
#define __PCI_IRQ_H__
40
41
rtems/rtems/intr.h
42
rtems/score/basedefs.h
43
44
/* PCI Handler (ISR) called when IRQ is generated by any of the PCI devices
45
* connected to the same PCI IRQ Pin. This has been defined the same way as
46
* rtems_interrupt_handler in order for BSPs to "direct-map" the register
47
* and unregister functions rtems_interrupt_handler_install/remove
48
49
typedef
void (*pci_isr)(
void
*arg);
50
51
/* Get assigned system IRQ to a PCI Device. If no IRQ 0 is returned */
52
extern
int
pci_dev_irq(pci_dev_t dev);
53
54
/* Register shared PCI IRQ handler, but does not enable it. The system interrupt
55
* number is read from the PCI board's PCI configuration space header iline
56
* field. The iline field is initialized by the PCI subsystem during start up,
57
* the ipin field is translated into a system IRQ and written to iline. The
58
* board's driver should use the iline field as the irq argument to this
59
* function.
60
61
* Arguments
62
* irq System IRQ number, normally taken from the PCI configuration area
63
* isr Function pointer to the ISR
64
* arg Second argument to function isr
65
66
static
inline
int
pci_interrupt_register(
int
irq,
const
char
*info,
67
pci_isr isr,
void
*arg)
68
69
return
(irq, info,
70
RTEMS_INTERRUPT_SHARED
, isr,
71
arg);
72
73
74
/* Unregister previously registered shared PCI IRQ handler
75
76
* Arguments
77
78
79
80
81
static
inline
int
pci_interrupt_unregister(
int
irq, pci_isr isr,
82
void
*arg)
83
84
return
rtems_interrupt_handler_remove
(irq, isr, arg);
85
86
87
/* Enable shared PCI IRQ handler. This function will unmask the interrupt
88
* controller and mark this interrupt handler ready to handle interrupts. Note
89
* that since it is a shared interrupt handler service the interrupt may
90
* already be enabled, however no calls to this specific handler is made
91
* until it is enabled.
92
93
* Arguments
94
95
96
97
98
static
inline
void
pci_interrupt_unmask(
int
irq)
99
100
(void)
rtems_interrupt_vector_enable
rtems_vector_number
)irq);
101
102
103
/* Disable shared PCI IRQ handler. This function will mask the interrupt
104
* controller and mark this interrupt handler not ready to receive interrupts.
105
* Note that since it is a shared interrupt handler service the interrupt may
106
* still be enabled, however no calls to this specific handler is made
107
* while it is disabled.
108
109
* Arguments
110
111
112
113
114
static
inline
void
pci_interrupt_mask(
int
irq)
115
116
(void)
rtems_interrupt_vector_disable
rtems_vector_number
)irq);
117
118
119
/* Acknowledge the interrupt controller by writing to the interrupt controller.
120
* Note that since it is a shared interrupt handler service, clearing the
121
* interrupt source may affect other ISRs registered to this IRQ.
122
123
* Arguments
124
125
126
127
128
static
inline
void
pci_interrupt_clear(
int
irq)
129
130
(void)
rtems_interrupt_clear
rtems_vector_number
)irq);
131
132
133
#endif
/* !__PCI_IRQ_H__ */
basedefs.h
This header file provides basic definitions used by the API and the implementation.
rtems_status_code rtems_interrupt_vector_disable(rtems_vector_number vector)
Disables the interrupt vector.
Definition
irq-enable-disable.c:94
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler routine, void *arg)
Installs the interrupt handler routine and argument at the interrupt vector.
Definition
irq-handler-install.c:85
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition
intr.h:102
#define RTEMS_INTERRUPT_SHARED
This interrupt handler install option allows that the interrupt handler may share the interrupt vecto...
Definition
intr.h:960
rtems_status_code rtems_interrupt_handler_remove(rtems_vector_number vector, rtems_interrupt_handler routine, void *arg)
Removes the interrupt handler routine and argument from the interrupt vector.
Definition
irq-handler-remove.c:62
rtems_status_code rtems_interrupt_vector_enable(rtems_vector_number vector)
Enables the interrupt vector.
Definition
irq-enable-disable.c:85
rtems_status_code rtems_interrupt_clear(rtems_vector_number vector)
Clears the interrupt vector.
Definition
irq-raise-clear.c:92
intr.h
This header file defines the Interrupt Manager API.
