RTEMS
6.3
Toggle main menu visibility
bsps
mips
rbtx4938
console
yamon_api.h
1
2
3
* yamon_api.h
4
5
* YAMON interface definitions
6
7
8
9
* mips_start_of_legal_notice
10
11
* Copyright (c) 2003 MIPS Technologies, Inc. All rights reserved.
12
13
14
* Unpublished rights (if any) reserved under the copyright laws of the
15
* United States of America and other countries.
16
17
* This code is proprietary to MIPS Technologies, Inc. ("MIPS
18
* Technologies"). Any copying, reproducing, modifying or use of this code
19
* (in whole or in part) that is not expressly permitted in writing by MIPS
20
* Technologies or an authorized third party is strictly prohibited. At a
21
* minimum, this code is protected under unfair competition and copyright
22
* laws. Violations thereof may result in criminal penalties and fines.
23
24
* MIPS Technologies reserves the right to change this code to improve
25
* function, design or otherwise. MIPS Technologies does not assume any
26
* liability arising out of the application or use of this code, or of any
27
* error or omission in such code. Any warranties, whether express,
28
* statutory, implied or otherwise, including but not limited to the implied
29
* warranties of merchantability or fitness for a particular purpose, are
30
* excluded. Except as expressly provided in any written license agreement
31
* from MIPS Technologies or an authorized third party, the furnishing of
32
* this code does not give recipient any license to any intellectual
33
* property rights, including any patent rights, that cover this code.
34
35
* This code shall not be exported or transferred for the purpose of
36
* reexporting in violation of any U.S. or non-U.S. regulation, treaty,
37
* Executive Order, law, statute, amendment or supplement thereto.
38
39
* This code constitutes one or more of the following: commercial computer
40
* software, commercial computer software documentation or other commercial
41
* items. If the user of this code, or any related documentation of any
42
* kind, including related technical data or manuals, is an agency,
43
* department, or other entity of the United States government
44
* ("Government"), the use, duplication, reproduction, release,
45
* modification, disclosure, or transfer of this code, or any related
46
* documentation of any kind, is restricted in accordance with Federal
47
* Acquisition Regulation 12.212 for civilian agencies and Defense Federal
48
* Acquisition Regulation Supplement 227.7202 for military agencies. The use
49
* of this code by the Government is further restricted in accordance with
50
* the terms of the license agreement(s) and/or applicable contract terms
51
* and conditions covering this code from MIPS Technologies or an authorized
52
* third party.
53
54
55
* mips_end_of_legal_notice
56
57
58
59
60
#ifndef YAMON_API_H
61
#define YAMON_API_H
62
63
64
* Include files
65
66
67
68
69
* Definitions
70
71
72
/* Basic types */
73
74
typedef
unsigned
int
t_yamon_uint32;
75
typedef
unsigned
short
t_yamon_uint16;
76
typedef
unsigned
char
t_yamon_uint8;
77
typedef
signed
int
t_yamon_int32;
78
typedef
signed
short
t_yamon_int16;
79
typedef
signed
char
t_yamon_int8;
80
81
typedef
unsigned
char
t_yamon_bool;
82
83
#define YAMON_FALSE 0
84
#define YAMON_TRUE (!YAMON_FALSE)
85
86
/* YAMON Environment variable */
87
typedef
struct
88
89
char
*name;
90
char
*val;
91
92
t_yamon_env_var
93
94
/* Format of application function */
95
typedef
t_yamon_uint32
96
(*t_yamon_appl_main)(
97
t_yamon_uint32 argc,
/* Number of tokens in argv array */
98
char
**argv,
/* Array of tokens (first is "go") */
99
t_yamon_env_var
env
/* Array of env. variables */
100
t_yamon_uint32 memsize );
/* Size of memory (byte count) */
101
102
103
/* ID of YAMON configuration object */
104
typedef
t_yamon_uint32 t_yamon_syscon_id;
105
106
107
/* Number used by the exception registration functions in order to register
108
* a default ISR/ESR.
109
110
#define YAMON_DEFAULT_HANDLER 0xfffffff0
111
112
113
* an EJTAG debug exception ESR.
114
115
#define YAMON_DEFAULT_EJTAG_ESR 0xfffffff1
116
117
/* Registered Interrupt Service Routine (ISR) */
118
typedef
void (*t_yamon_isr)(
void
*data);
119
120
/* Registered Exception Service Routine (ESR) */
121
typedef
void (*t_yamon_esr)(void);
122
123
/* Entry point called by ESRs wishing to pass control back to YAMON */
124
typedef
void (*t_yamon_retfunc)(void);
125
126
/* Handle used for deregistration of ISR/ESR */
127
typedef
void
*t_yamon_ref;
128
129
130
/* YAMONE Vector table address */
131
#define YAMON_FUNCTION_BASE 0x9fc00500
132
133
/* YAMON Vector table offsets */
134
#define YAMON_FUNC_PRINT_COUNT_OFS 0x04
135
#define YAMON_FUNC_EXIT_OFS 0x20
136
#define YAMON_FUNC_FLUSH_CACHE_OFS 0x2C
137
#define YAMON_FUNC_PRINT_OFS 0x34
138
#define YAMON_FUNC_REGISTER_CPU_ISR_OFS 0x38
139
#define YAMON_FUNC_DEREGISTER_CPU_ISR_OFS 0x3c
140
#define YAMON_FUNC_REGISTER_IC_ISR_OFS 0x40
141
#define YAMON_FUNC_DEREGISTER_IC_ISR_OFS 0x44
142
#define YAMON_FUNC_REGISTER_ESR_OFS 0x48
143
#define YAMON_FUNC_DEREGISTER_ESR_OFS 0x4c
144
#define YAMON_FUNC_GETCHAR_OFS 0x50
145
#define YAMON_FUNC_SYSCON_READ_OFS 0x54
146
147
/* Macro for accessing YAMON function */
148
#define YAMON_FUNC(ofs)\
149
(*(t_yamon_uint32 *)(YAMON_FUNCTION_BASE + (ofs)))
150
151
152
153
* Public variables
154
155
156
157
* Public functions
158
159
160
161
162
163
* t_yamon_exit
164
* Description :
165
166
167
* Exit application and return to YAMON.
168
169
* Parameters :
170
171
172
* 'rc' (OUT) : Return code
173
174
* Return values :
175
176
177
* None (never returns)
178
179
180
typedef
void
181
(*t_yamon_exit)(
182
t_yamon_uint32 rc );
/* Return code */
183
184
#define YAMON_FUNC_EXIT( rc )\
185
((t_yamon_exit)( YAMON_FUNC(YAMON_FUNC_EXIT_OFS) ))\
186
( rc )
187
188
189
190
191
* t_yamon_print
192
* Description :
193
194
195
* Print null-terminated string to tty0.
196
197
* Parameters :
198
199
200
* 'port' (OUT) : Ignored, always prints to tty0. Not included in macro.
201
* 's' (OUT) : String to print.
202
203
* Return values :
204
205
206
* None
207
208
209
typedef
void
210
(*t_yamon_print)(
211
t_yamon_uint32 port,
/* Output port (not used, always tty0) */
212
const
char
*s );
/* String to output */
213
214
#define YAMON_FUNC_PRINT( s )\
215
((t_yamon_print)( YAMON_FUNC(YAMON_FUNC_PRINT_OFS) ))\
216
( 0, s )
217
218
219
220
221
* t_yamon_print_count
222
* Description :
223
224
225
* Print specified number of characters to tty0.
226
227
* Parameters :
228
229
230
231
* 's' (OUT) : Array of characters to print.
232
* 'count' (OUT) : Number of characters to print.
233
234
* Return values :
235
236
237
* None
238
239
240
typedef
void
241
(*t_yamon_print_count)(
242
/* Output port (not used, always tty0 */
243
char
*s,
244
t_yamon_uint32 count );
/* Number of characters to output */
245
246
#define YAMON_FUNC_PRINT_COUNT( s, count )\
247
((t_yamon_print_count)( YAMON_FUNC(YAMON_FUNC_PRINT_COUNT_OFS) ))\
248
( 0, s, count )
249
250
251
252
253
* t_yamon_getchar
254
* Description :
255
256
257
* Get character from tty0 if character is available. Function
258
* returns immediately if no character is available.
259
260
* Parameters :
261
262
263
* 'port' (OUT) : Ignored, always uses tty0. Not included in macro.
264
* 'ch' (OUT) : Character read (if available).
265
266
* Return values :
267
268
269
* YAMON_TRUE if character was available, else YAMON_FALSE.
270
271
272
typedef
t_yamon_bool
273
(*t_yamon_getchar)(
274
275
char
*ch );
/* Character to output */
276
277
#define YAMON_FUNC_GETCHAR( ch )\
278
((t_yamon_getchar)( YAMON_FUNC(YAMON_FUNC_GETCHAR_OFS) ))\
279
( 0, ch )
280
281
282
283
284
* t_yamon_syscon_read
285
* Description :
286
287
288
* Read the value of system configuration object given by 'id'.
289
290
* See syscon_api.h in YAMON source distribution for further details
291
* on object IDs and error codes.
292
293
* Parameters :
294
295
296
* 'id' (IN) : Object id.
297
* 'param' (INOUT) : Buffer for object value.
298
* 'size' (IN) : Size of buffer (must match size of object).
299
300
* Return values :
301
302
303
* 0 : Returned parameter is valid.
304
* Other values indicate error.
305
306
307
typedef
t_yamon_int32
308
(*t_yamon_syscon_read)(
309
t_yamon_syscon_id id,
/* Object ID */
310
void
*param,
/* Buffer for object value */
311
t_yamon_uint32 size);
/* Buffer size (bytes) */
312
313
#define YAMON_FUNC_SYSCON_READ( id, param, size )\
314
((t_yamon_syscon_read)( YAMON_FUNC(YAMON_FUNC_SYSCON_READ_OFS) ))\
315
( id, param, size )
316
317
318
319
320
* t_yamon_flush_cache
321
* Description :
322
323
324
* Flush I-or D-cache
325
326
* Function performs "writeback and invalidate" operations on D-cache
327
* lines and "invalidate" operations on I-cache lines.
328
329
* Parameters :
330
331
332
* 'type' (IN) : Cache to be flushed.
333
334
* Return values :
335
336
337
* None
338
339
340
typedef
void
341
(*t_yamon_flush_cache)(
342
#define YAMON_FLUSH_ICACHE 0
343
#define YAMON_FLUSH_DCACHE 1
344
t_yamon_uint32 type );
/* I- or D-cache indication */
345
346
#define YAMON_FUNC_FLUSH_CACHE( type )\
347
((t_yamon_flush_cache)( YAMON_FUNC(YAMON_FUNC_FLUSH_CACHE_OFS) ))\
348
( type )
349
350
351
352
353
* t_yamon_register_esr
354
* Description :
355
356
357
* Registers an exception handler, also known as an "Exception Service
358
* Routine" (ESR) for the specified exception.
359
360
* Two special exception IDs are defined :
361
* YAMON_DEFAULT_HANDLER used for a default ESR.
362
* YAMON_DEFAULT_EJTAG_ESR used for EJTAG exceptions.
363
364
* The default ESR is called if no other ESR is registered
365
* for an exception. If no default ESR is registered, a static
366
* (i.e. not registered) "super default" function is invoked.
367
* This function prints out the registers and halts.
368
369
* Deregistration of an ESR may be be done by calling this function
370
* with 'esr' set to NULL.
371
* An ESR can also be deregistered using the 'yamon_deregister_esr'
372
* function.
373
374
* An ESR may be registered even if a previously registered
375
* ESR has not been deregistered. In this case the previously
376
* registered ESR is lost.
377
378
* The ESR will get called with registers in the state they were
379
* when the exception occurred. This includes all CP0 registers and
380
* CPU registers $0..$31, except for k0,k1 ($26,$27).
381
382
* In case an ESR does not want to handle the exception, it may
383
* call the return function passed in the 'retfunc' parameter.
384
385
* Case 1 : 'retfunc' called by ESR registered for the
386
* INTERRUPT exception.
387
388
* We assume an application has registered this ESR and wants
389
* YAMON to process the (remaining) interrupts.
390
391
* Case 2 : 'retfunc' called by an ESR registered for a specific
392
* exception (not INTERRUPT).
393
394
* Default handling will be done.
395
396
* Case 3 : 'retfunc' is called by the ESR registered as default ESR.
397
398
* The exception will be handled as though no ESR is registered
399
* (i.e. the "super default" function is called).
400
401
* Parameters :
402
403
404
* 'exception' (IN) : Exception code
405
* or YAMON_DEFAULT_HANDLER for a default ESR
406
* or YAMON_DEFAULT_EJTAG_ESR for ejtag exceptions.
407
* 'esr' (IN) : Function pointer for ESR.
408
* 'ref' (OUT) : Handle used for deregistration of ESR.
409
* 'retfunc' (OUT) : Pointer to function pointer for the return
410
* function described above.
411
412
* Return values :
413
414
415
* 0 : Registration went well.
416
417
418
419
typedef
t_yamon_int32
420
(*t_yamon_register_esr)(
421
t_yamon_uint32 exception,
/* Exception identification */
422
t_yamon_esr esr,
/* ESR to be registered */
423
t_yamon_ref *ref,
/* Handle for deregistration */
424
t_yamon_retfunc *retfunc );
/* Return function */
425
426
#define YAMON_FUNC_REGISTER_ESR( exc, esr, ref, retfunc )\
427
((t_yamon_register_esr)( YAMON_FUNC(YAMON_FUNC_REGISTER_ESR_OFS) ))\
428
429
430
431
432
433
* t_yamon_deregister_esr
434
* Description :
435
436
437
* Deregisters ESR..
438
439
* Parameters :
440
441
442
* 'ref' (IN) : Handle obtained when calling 'yamon_register_esr'.
443
444
* Return values :
445
446
447
* 0 : Deregistration went well.
448
449
450
451
typedef
t_yamon_int32
452
(*t_yamon_deregister_esr)(
453
t_yamon_ref ref );
454
455
#define YAMON_FUNC_DEREGISTER_ESR( ref )\
456
((t_yamon_deregister_esr)( YAMON_FUNC(YAMON_FUNC_DEREGISTER_ESR_OFS) ))\
457
( ref )
458
459
460
461
462
* t_yamon_register_cpu_isr
463
* Description :
464
465
466
* Registers an Interrupt Service Routine (ISR) for the specified
467
* CPU interrupt.
468
* The highest service priority is attached to HW-INT5, which is
469
* connected to the CPU-built-in CP0-timer. SW_INT0 gets the lowest
470
* service priority. During registration, the interrupt mask field
471
* in the CPU CP0-status register is updated to enable interrupts
472
* from the specified interrupt source.
473
474
* A special ID is defined :
475
* YAMON_DEFAULT_HANDLER used for a default ISR.
476
477
* The default ISR is called if no other ISR is registered
478
* for a CPU interrupt.
479
480
* Deregistration of the default ISR may be done by calling
481
* this function with 'isr' set to NULL.
482
* Also, a new default ISR may be registered even if a
483
* previously registered ISR has not been deregistered.
484
* ISRs for specific CPU interrupts must be deregistered using
485
* 'yamon_deregister_cpu_isr'.
486
487
* Parameters :
488
489
490
* 'cpu_int' (IN) : CPU interrupt (0..7)
491
* or YAMON_DEFAULT_HANDLER for a default ISR.
492
* 'isr' (IN) : Function pointer for ISR.
493
* 'data' (IN) : Data pointer (may be NULL). Will be passed to
494
* ISR when called.
495
* 'ref' (OUT) : Handle used for deregistration of ISR.
496
497
* Return values :
498
499
500
501
502
503
504
typedef
t_yamon_int32
505
(*t_yamon_register_cpu_isr)(
506
t_yamon_uint32 cpu_int,
/* CPU interrupt (0..7) */
507
t_yamon_isr isr,
/* ISR to be registered */
508
void
*data,
/* Data reference to be registered */
509
t_yamon_ref *ref );
510
511
#define YAMON_FUNC_REGISTER_CPU_ISR( cpu_int, isr, data, ref )\
512
((t_yamon_register_cpu_isr)( YAMON_FUNC(YAMON_FUNC_REGISTER_CPU_ISR_OFS) ))\
513
514
515
516
517
518
* t_yamon_deregister_cpu_isr
519
* Description :
520
521
522
* Deregisters ISR for CPU interrupt.
523
524
* Parameters :
525
526
527
* 'ref' (IN) : Handle obtained when calling 'yamon_register_cpu_isr'.
528
529
* Return values :
530
531
532
533
534
535
536
typedef
t_yamon_int32
537
(*t_yamon_deregister_cpu_isr)(
538
t_yamon_ref ref );
539
540
#define YAMON_FUNC_DEREGISTER_CPU_ISR( ref )\
541
((t_yamon_deregister_cpu_isr)( YAMON_FUNC(YAMON_FUNC_DEREGISTER_CPU_ISR_OFS) ))\
542
( ref )
543
544
545
546
547
* t_yamon_register_ic_isr
548
* Description :
549
550
551
552
* source in the interrupt controller.
553
554
555
556
557
558
* for an interrupt.
559
560
561
562
563
564
* ISRs for specific interrupts must be deregistered using
565
* 'yamon_deregister_ic_isr'.
566
567
* Parameters :
568
569
570
* 'ic_line' (IN) : Interrupt source line in Int. Controller
571
572
* 'isr', (IN) : Function pointer for user defined ISR.
573
574
* ISR when called.
575
* 'ref', (OUT) : Handle used for deregistration of ISR.
576
577
* Return values :
578
579
580
581
582
583
584
typedef
t_yamon_int32
585
(*t_yamon_register_ic_isr)(
586
t_yamon_uint32 ic_line,
/* Interrupt controller line */
587
t_yamon_isr isr,
588
void
*data,
589
t_yamon_ref *ref );
590
591
#define YAMON_FUNC_REGISTER_IC_ISR( ic_line, isr, data, ref )\
592
((t_yamon_register_ic_isr)( YAMON_FUNC(YAMON_FUNC_REGISTER_IC_ISR_OFS) ))\
593
594
595
596
597
598
* t_yamon_deregister_ic_isr
599
* Description :
600
601
602
* Deregisters ISR for source in interrupt controller.
603
604
* Parameters :
605
606
607
* 'ref' (IN) : Handle obtained when calling 'yamon_register_ic_isr'.
608
609
* Return values :
610
611
612
613
614
615
616
typedef
t_yamon_int32
617
(*t_yamon_deregister_ic_isr)(
618
t_yamon_ref ref );
619
620
#define YAMON_FUNC_DEREGISTER_IC_ISR( ref )\
621
((t_yamon_deregister_ic_isr)( YAMON_FUNC(YAMON_FUNC_DEREGISTER_IC_ISR_OFS) ))\
622
( ref )
623
624
625
#endif
/* #ifndef YAMON_API_H */
626
627
628
629
630
631
env
Definition
main_edit.c:210
t_yamon_env_var
Definition
yamon_api.h:88
