RTEMS 6.3
Milkymist USB input devices driver. More...
#define COMLOCV(x)
#define COMLOC_DEBUG_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1000)
#define COMLOC_DEBUG(offset)
#define COMLOC_MEVT_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1101)
#define COMLOC_MEVT(offset)
#define COMLOC_KEVT_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1142)
#define COMLOC_KEVT(offset)
#define COMLOC_MIDI_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1183)
#define COMLOC_MIDI(offset)
◆ COMLOC_DEBUG
#define COMLOC_DEBUG ( offset)
Value:
COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1001+offset)
◆ COMLOC_KEVT
#define COMLOC_KEVT ( offset)
Value:
COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1143+offset)
◆ COMLOC_MEVT
#define COMLOC_MEVT ( offset)
Value:
COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1102+offset)
◆ COMLOC_MIDI
#define COMLOC_MIDI ( offset)
Value:
COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1184+offset)
◆ COMLOCV
#define COMLOCV ( x)
Value:
(*(volatile unsigned char *)(x))
