RTEMS
6.3
Toggle main menu visibility
bsps
arm
include
cmsis_version.h
1
7
8
* Copyright (c) 2009-2022 ARM Limited. All rights reserved.
9
10
* SPDX-License-Identifier: Apache-2.0
11
12
* Licensed under the Apache License, Version 2.0 (the License); you may
13
* not use this file except in compliance with the License.
14
* You may obtain a copy of the License at
15
16
* www.apache.org/licenses/LICENSE-2.0
17
18
* Unless required by applicable law or agreed to in writing, software
19
* distributed under the License is distributed on an AS IS BASIS, WITHOUT
20
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
21
* See the License for the specific language governing permissions and
22
* limitations under the License.
23
24
25
#if defined ( __ICCARM__ )
26
#pragma system_include
/* treat file as system include file for MISRA check */
27
#elif defined (__clang__)
28
#pragma clang system_header
/* treat file as system include file */
29
#endif
30
31
#ifndef __CMSIS_VERSION_H
32
#define __CMSIS_VERSION_H
33
34
/* CMSIS Version definitions */
35
#define __CM_CMSIS_VERSION_MAIN ( 5U)
36
#define __CM_CMSIS_VERSION_SUB ( 6U)
37
#define __CM_CMSIS_VERSION ((__CM_CMSIS_VERSION_MAIN << 16U) | \
38
__CM_CMSIS_VERSION_SUB )
39
#endif
