RTEMS 6.3
cmsis_gcc.h File Reference
CMSIS compiler GCC header file. More...
#define __has_builtin(x)
#define __ASM   __asm
#define __INLINE   inline
#define __STATIC_INLINE   static inline
#define __STATIC_FORCEINLINE   __attribute__((always_inline)) static inline
#define __NO_RETURN   __attribute__((__noreturn__))
#define __USED   __attribute__((used))
#define __WEAK   __attribute__((weak))
#define __PACKED   __attribute__((packed, aligned(1)))
#define __PACKED_STRUCT   struct __attribute__((packed, aligned(1)))
#define __PACKED_UNION   union __attribute__((packed, aligned(1)))
#define __UNALIGNED_UINT32(x)
#define __UNALIGNED_UINT16_WRITE(addr, val)
#define __UNALIGNED_UINT16_READ(addr)
#define __UNALIGNED_UINT32_WRITE(addr, val)
#define __UNALIGNED_UINT32_READ(addr)
#define __ALIGNED(x)
#define __RESTRICT   __restrict
#define __COMPILER_BARRIER()
#define __NO_INIT   __attribute__ ((section (".bss.noinit")))
#define __ALIAS(x)
#define __PROGRAM_START   __cmsis_start
#define __INITIAL_SP   __StackTop
#define __STACK_LIMIT   __StackLimit
#define __VECTOR_TABLE   __Vectors
#define __VECTOR_TABLE_ATTRIBUTE   __attribute__((used, section(".vectors")))
#define __CMSIS_GCC_OUT_REG(r)
#define __CMSIS_GCC_RW_REG(r)
#define __CMSIS_GCC_USE_REG(r)
#define __NOP()
 No Operation.
#define __WFI()
 Wait For Interrupt.
#define __WFE()
 Wait For Event.
#define __SEV()
 Send Event.
#define __BKPT(value)
 Breakpoint.
struct __attribute__ ((packed)) T_UINT32
__STATIC_FORCEINLINE __NO_RETURN void __cmsis_start (void)
 Initializes data and bss sections.
__STATIC_FORCEINLINE void __ISB (void)
 Instruction Synchronization Barrier.
__STATIC_FORCEINLINE void __DSB (void)
 Data Synchronization Barrier.
__STATIC_FORCEINLINE void __DMB (void)
 Data Memory Barrier.
__STATIC_FORCEINLINE uint32_t __REV (uint32_t value)
 Reverse byte order (32 bit).
__STATIC_FORCEINLINE uint32_t __REV16 (uint32_t value)
 Reverse byte order (16 bit).
__STATIC_FORCEINLINE int16_t __REVSH (int16_t value)
__STATIC_FORCEINLINE uint32_t __ROR (uint32_t op1, uint32_t op2)
 Rotate Right in unsigned value (32 bit).
__STATIC_FORCEINLINE uint32_t __RBIT (uint32_t value)
 Reverse bit order of value.
__STATIC_FORCEINLINE uint8_t __CLZ (uint32_t value)
 Count leading zeros.
__STATIC_FORCEINLINE int32_t __SSAT (int32_t val, uint32_t sat)
 Signed Saturate.
__STATIC_FORCEINLINE uint32_t __USAT (int32_t val, uint32_t sat)
 Unsigned Saturate.
__STATIC_FORCEINLINE void __enable_irq (void)
 Enable IRQ Interrupts.
__STATIC_FORCEINLINE void __disable_irq (void)
 Disable IRQ Interrupts.
__STATIC_FORCEINLINE uint32_t __get_CONTROL (void)
 Get Control Register.
__STATIC_FORCEINLINE void __set_CONTROL (uint32_t control)
 Set Control Register.
__STATIC_FORCEINLINE uint32_t __get_IPSR (void)
 Get IPSR Register.
__STATIC_FORCEINLINE uint32_t __get_APSR (void)
 Get APSR Register.
__STATIC_FORCEINLINE uint32_t __get_xPSR (void)
 Get xPSR Register.
__STATIC_FORCEINLINE uint32_t __get_PSP (void)
 Get Process Stack Pointer.
__STATIC_FORCEINLINE void __set_PSP (uint32_t topOfProcStack)
 Set Process Stack Pointer.
__STATIC_FORCEINLINE uint32_t __get_MSP (void)
 Get Main Stack Pointer.
__STATIC_FORCEINLINE void __set_MSP (uint32_t topOfMainStack)
 Set Main Stack Pointer.
__STATIC_FORCEINLINE uint32_t __get_PRIMASK (void)
 Get Priority Mask.
__STATIC_FORCEINLINE void __set_PRIMASK (uint32_t priMask)
 Set Priority Mask.
__STATIC_FORCEINLINE uint32_t __get_FPSCR (void)
 Get FPSCR.
__STATIC_FORCEINLINE void __set_FPSCR (uint32_t fpscr)
 Set FPSCR.
__PACKED_STRUCT T_UINT16_WRITE { uint16_t v
__PACKED_STRUCT T_UINT16_READ { uint16_t v
__PACKED_STRUCT T_UINT32_WRITE { uint32_t v
__PACKED_STRUCT T_UINT32_READ { uint32_t v
This header file provides CMSIS interfaces.
Version
V5.4.2
Date
17. December 2022
◆ __ALIAS
#define __ALIAS ( x)
Value:
__attribute__ ((alias(x)))
Definition xnandpsu_onfi.h:185
◆ __ALIGNED
#define __ALIGNED ( x)
Value:
__attribute__((aligned(x)))
◆ __COMPILER_BARRIER
#define __COMPILER_BARRIER ( )
Value:
__ASM volatile("":::"memory")
◆ __has_builtin
#define __has_builtin ( x)
Value:
(0)
◆ __UNALIGNED_UINT16_READ
#define __UNALIGNED_UINT16_READ ( addr)
Value:
(((const struct T_UINT16_READ *)(const void *)(addr))->v)
◆ __UNALIGNED_UINT16_WRITE
#define __UNALIGNED_UINT16_WRITE ( addr,
val )
Value:
(void)((((struct T_UINT16_WRITE *)(void *)(addr))->v) = (val))
◆ __UNALIGNED_UINT32
#define __UNALIGNED_UINT32 ( x)
Value:
(((struct T_UINT32 *)(x))->v)
◆ __UNALIGNED_UINT32_READ
#define __UNALIGNED_UINT32_READ ( addr)
Value:
(((const struct T_UINT32_READ *)(const void *)(addr))->v)
◆ __UNALIGNED_UINT32_WRITE
#define __UNALIGNED_UINT32_WRITE ( addr,
val )
Value:
(void)((((struct T_UINT32_WRITE *)(void *)(addr))->v) = (val))
◆ __cmsis_start()
__STATIC_FORCEINLINE __NO_RETURN void __cmsis_start ( void )
This default implementations initialized all data and additional bss sections relying on .copy.table and .zero.table specified properly in the used linker script.
