RTEMS 6.3
cfg_read.h
2
10
11/*
12 * COPYRIGHT (c) 2010 Cobham Gaisler AB.
13 *
16 * are met:
22 *
34 */
35
36
37#ifndef __PCI_CFG_READ_H__
38#define __PCI_CFG_READ_H__
39
40/* Build PCI device tree in "struct pci_bus pci_hb" according to current setup
41 * in hardware. Devices/buses are created by reading the resource assignments
42 * that the BIOS/bootloader has already setup for us.
43 */
44extern int pci_config_read(void);
45
46#endif
