RTEMS
6.3
Toggle main menu visibility
include
pci
cfg_auto.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef __PCI_CFG_AUTO_H__
35
#define __PCI_CFG_AUTO_H__
36
37
#define CFGOPT_NOSETUP_IRQ 0x1
/* Skip IRQ setup */
38
39
/* PCI Memory Layout setup, used by the auto-config library in order to
40
* determine the addresses of PCI BARs and Buses.
41
42
* All addresses are in PCI address space, the actual address the CPU access
43
* may be different, and taken care of elsewhere.
44
45
struct
pci_auto_setup
46
int
options;
47
48
/* PCI prefetchable Memory space (OPTIONAL) */
49
uint32_t mem_start;
50
uint32_t mem_size;
/* 0 = Use MEMIO space for prefetchable mem BARs */
51
52
/* PCI non-prefetchable Memory */
53
uint32_t memio_start;
54
uint32_t memio_size;
55
56
/* PCI I/O space (OPTIONAL) */
57
uint32_t io_start;
58
uint32_t io_size;
/* 0 = No I/O space */
59
60
/* Get System IRQ connected to a PCI line of a PCI device on bus0.
61
* The return IRQ value zero equals no IRQ (IRQ disabled).
62
63
uint8_t (*irq_map)(pci_dev_t dev,
int
irq_pin);
64
65
/* IRQ Bridge routing. Returns the interrupt pin (0..3 = A..D) that
66
* a device is connected to on parent bus.
67
68
int (*irq_route)(pci_dev_t dev,
int
irq_pin);
69
70
71
/* Do PCI initialization: Enumrate buses, scan buses for devices, assign
72
* I/O MEM and MEMIO resources, assign IRQ and so on.
73
74
extern
int
pci_config_auto(
void
75
76
/* Register a configuration for the auto library (struct pci_auto_setup *) */
77
extern
void
pci_config_auto_register(
void
*config);
78
79
/* PCI memory map */
80
extern
struct
pci_auto_setup
pci_auto_cfg;
81
82
#endif
pci_auto_setup
Definition
cfg_auto.h:45
