RTEMS
6.3
Toggle main menu visibility
libmisc
capture
capture_buffer.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* COPYRIGHT (c) 2014.
14
* On-Line Applications Research Corporation (OAR).
15
16
* Copyright 2016 Chris Johns <chrisj@rtems.org>.
17
* All rights reserved.
18
19
20
* modification, are permitted provided that the following conditions
21
* are met:
22
* 1. Redistributions of source code must retain the above copyright
23
* notice, this list of conditions and the following disclaimer.
24
* 2. Redistributions in binary form must reproduce the above copyright
25
* notice, this list of conditions and the following disclaimer in the
26
* documentation and/or other materials provided with the distribution.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef __CAPTURE_BUFFER_H_
42
#define __CAPTURE_BUFFER_H_
43
44
47
#ifdef __cplusplus
48
extern
"C"
49
#endif
50
54
typedef
struct
rtems_capture_buffer
55
uint8_t*
buffer
56
size_t
size
57
size_t
count
58
size_t
head
59
size_t
tail
60
size_t
end
61
size_t
max_rec
62
63
64
static
inline
void
65
rtems_capture_buffer_flush (
* buffer)
66
67
buffer->
end
= buffer->
size
68
buffer->
head
= buffer->
tail
= 0;
69
buffer->
count
= 0;
70
buffer->
max_rec
= 0;
71
72
73
static
inline
void
74
rtems_capture_buffer_create (
* buffer,
size_t
size)
75
76
buffer->
buffer
= malloc(size);
77
buffer->
size
= size;
78
rtems_capture_buffer_flush (buffer);
79
80
81
static
inline
void
82
rtems_capture_buffer_destroy (
* buffer)
83
84
85
free (buffer->
buffer
86
buffer->
buffer
= NULL;
87
88
89
static
inline
bool
90
rtems_capture_buffer_is_empty (
* buffer)
91
92
return
buffer->
count
== 0;
93
94
95
static
inline
bool
96
rtems_capture_buffer_is_full (
* buffer)
97
98
return
buffer->
count
== buffer->
size
99
100
101
static
inline
bool
102
rtems_capture_buffer_has_wrapped (
* buffer)
103
104
if
(buffer->
tail
> buffer->
head
105
return
true
106
107
return
false
108
109
110
static
inline
void
111
rtems_capture_buffer_peek (
* buffer,
size_t
* size)
112
113
if
(rtems_capture_buffer_is_empty (buffer))
114
115
*size = 0;
116
return
NULL;
117
118
119
if
(buffer->
tail
> buffer->
head
120
*size = buffer->
end
- buffer->
tail
121
else
122
*size = buffer->
head
- buffer->
tail
123
124
return
&buffer->
buffer
[buffer->
tail
125
126
127
void
* rtems_capture_buffer_allocate (
* buffer,
size_t
size);
128
129
void
* rtems_capture_buffer_free (
* buffer,
size_t
size);
130
131
#ifdef __cplusplus
132
133
#endif
134
135
#endif
Definition
capture_buffer.h:54
rtems_capture_buffer::head
size_t head
Definition
capture_buffer.h:58
rtems_capture_buffer::max_rec
size_t max_rec
Definition
capture_buffer.h:61
rtems_capture_buffer::tail
size_t tail
Definition
capture_buffer.h:59
rtems_capture_buffer::count
size_t count
Definition
capture_buffer.h:57
rtems_capture_buffer::size
size_t size
Definition
capture_buffer.h:56
rtems_capture_buffer::buffer
uint8_t * buffer
Definition
capture_buffer.h:55
rtems_capture_buffer::end
size_t end
Definition
capture_buffer.h:60
