RTEMS 6.3
canbtrs.h
2
8
9/*
10 * Copyright (C) 2019, 2020 Cobham Gaisler AB
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef __GRLIB_CANBTRS_H__
35#define __GRLIB_CANBTRS_H__
36
46
47#ifdef __cplusplus
48extern "C" {
49#endif
50
51/* CAN Baud-rate parameters, range of valid parameter values */
53 unsigned int max_scaler;
54 char has_bpr;
55 unsigned char divfactor;
56 unsigned char min_tseg1;
57 unsigned char max_tseg1;
58 unsigned char min_tseg2;
59 unsigned char max_tseg2;
60};
61
63 unsigned char scaler;
64 unsigned char ps1;
65 unsigned char ps2;
66 unsigned char rsj;
67 unsigned char bpr;
68};
69
70/* @brief Calculate CAN baud-rate generation parameters from requested baud-rate
71 *
72 * @param baud The CAN baud rate requested
73 * @param core_hz Input clock [Hz] to CAN core
74 * @param sampl_pt CAN sample point in %, 80 means 80%
75 * @param br CAN Baud-rate parameters limitations
76 * @param[out] timing result is placed here
77 *
78 * @retval 0 Baud-rate parameters sucessfully calculated
79 * @retval negative Failure to generate parameters with less than 5% error
80 * margin from requested baud-rate
81 */
82int grlib_canbtrs_calc_timing(
83 unsigned int baud,
84 unsigned int core_hz,
85 unsigned int sampl_pt,
86 struct grlib_canbtrs_ranges *br,
87 struct grlib_canbtrs_timing *timing
88 );
89
90#ifdef __cplusplus
91}
92#endif
93
94#endif
Definition canbtrs.h:52
Definition canbtrs.h:62
