#define | CAN_ACCEPT_BASE_ADDR 0x4003C000 |
| #define | CAN_DRIVER_IS_MINOR_VALID(minor) |
#define | CAN_DEFAULT_BAUD_RATE 1000000u |
#define | CAN_DEFAULT_INTERRUPT_CONFIGURATION 0 |
#define | MAX_NUMBER_OF_CAN_BITS 25u |
#define | MIN_NUMBER_OF_CAN_BITS 4u |
#define | CAN_BRP_EXTRA_BIT 1u |
#define | CAN_TSEG_EXTRA_BITS 3u |
#define | MAX_TSEG1_TSEG2_BITS 22u |
#define | CAN_GSR_RBS_MASK 1u |
#define | CAN_CMR_RRB_MASK 4u |
#define | CAN_MAXIMUM_DATA_SIZE 8u |
#define | CAN10_MAXIMUM_ID 0x7FFu |
#define | CAN_BTR_TSEG1_SHIFT 16u |
#define | CAN_BTR_TSEG2_SHIFT 20u |
#define | CAN_BTR_SJW_SHIFT 14u |
#define | CAN_BTR_BRP_SHIFT 0u |
#define | CAN_BTR_TSEG1_MASK 0x000F0000U |
#define | CAN_BTR_TSEG2_MASK 0x00700000U |
#define | CAN_BTR_SJW_MASK 0x0000C000U |
#define | CAN_BTR_BRP_MASK 0x000003FFU |
#define | WRONG_BTR_VALUE 0xFFFFFFFF |
#define | CAN_INTERRUPT_TYPE_MASK 0x1ffu |
#define | CAN_MOD_RM 0x00000001U |
#define | CAN_ACCF_AFMR_ACCOF 0x00000001U |
#define | CAN_ACCF_AFMR_ACCBP 0x00000002U |
#define | CAN_ACCF_AFMR_EFCAN 0x00000004U |
#define | CAN_IER_RIE 0x000000001U |
#define | CAN_IER_TIE1 0x000000002U |
#define | CAN_IER_EIE 0x000000004U |
#define | CAN_IER_DOIE 0x000000008U |
#define | CAN_IER_WUIE 0x000000010U |
#define | CAN_IER_EPIEX 0x000000020U |
#define | CAN_IER_ALIEX 0x000000040U |
#define | CAN_IER_BEIEX 0x000000080U |
#define | CAN_IER_IDIEX 0x000000100U |
#define | CAN_IER_TIE2 0x000000200U |
#define | CAN_IER_TIE3 0x000000400U |
| enum | can_tseg_number { CAN_TSEG1
, CAN_TSEG2
, CAN_NUMBER_OF_TSEG
| | The Time segments of a CAN bit.
| enum | can_transmit_number { CAN_TRANSMIT1
, CAN_TRANSMIT2
, CAN_TRANSMIT3
, CAN_NUMBER_OF_TRANSMIT_BUFFERS
| | The transmit buffers of the CAN device.
| enum | can_pin_number { CAN_TX_PIN
, CAN_RX_PIN
, NUMBER_OF_CAN_PINS
| | A TX or RX pin for each CAN device .
| enum | can_format { CANStandard = 0
, CANExtended = 1
, CANAny = 2
| | The possible CAN formats for a message.
| enum | can_type { CANData = 0
, CANRemote = 1
| | The types of message.
CAN controller for the lpc176x controller.
