RTEMS
6.3
Toggle main menu visibility
bsps
sparc64
include
arch
mm
cache_spec.h
1
2
* Copyright (c) 2008 Jakub Jermar
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
9
* - Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* - Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
* - The name of the author may not be used to endorse or promote products
15
* derived from this software without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20
* IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27
28
34
35
#ifndef KERN_sparc64_CACHE_SPEC_H_
36
#define KERN_sparc64_CACHE_SPEC_H_
37
38
39
* The following macros are valid for the following processors:
40
41
* UltraSPARC, UltraSPARC II, UltraSPARC IIi, UltraSPARC III,
42
* UltraSPARC III+, UltraSPARC IV, UltraSPARC IV+
43
44
* Should we support other UltraSPARC processors, we need to make sure that
45
* the macros are defined correctly for them.
46
47
48
#if defined (US)
49
#define DCACHE_SIZE (16 * 1024)
50
#elif defined (US3)
51
#define DCACHE_SIZE (64 * 1024)
52
#endif
53
#define DCACHE_LINE_SIZE 32
54
55
#endif
56
