RTEMS 6.3
This header file contains the shared Clock Driver implementation. More...
#include <bsp.h>
#include <rtems/clockdrv.h>
#include <rtems/score/processormaskimpl.h>
#include <rtems/score/smpimpl.h>
#include <rtems/score/timecounter.h>
#define Clock_driver_support_install_isr(isr)
 Do nothing by default.
#define Clock_driver_support_find_timer()
 This method is rarely used so default it.
#define Clock_driver_support_at_tick(arg)
#define Clock_driver_support_set_interrupt_affinity(online_processors)
typedef rtems_vector_number Clock_isr_argument
void Clock_isr (Clock_isr_argument arg)
 Clock_isr.
void _Clock_Initialize (void)
 Initialize the clock driver.
volatile uint32_t Clock_driver_ticks
 ISRs until next clock tick.
This header file shall only be included by a particular Clock Driver implementation source file.
◆ Clock_driver_support_at_tick
#define Clock_driver_support_at_tick ( arg)
Value:
do { (void) arg; } while (0)
◆ Clock_isr()
void Clock_isr ( Clock_isr_argument arg)
Clock_isr.
This is the clock tick interrupt handler.
Parameters
argis the clock interrupt handler argument.
Variable Documentation
◆ Clock_driver_ticks
Clock ticks since initialization
