RTEMS 6.3
Global BSP definitions. More...
#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <libcpu/rm5231.h>Go to the source code of this file.
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | BSP_SHARED_HANDLER_SUPPORT 1 |
| #define | CPU_CLOCK_RATE_MHZ (200) |
| #define | CLOCKS_PER_MICROSECOND ( CPU_CLOCK_RATE_MHZ ) |
| #define | rtems_bsp_delay(microseconds) |
| #define | RAM_START 0 |
| #define | RAM_END 0x100000 |
| void | WriteDisplay (char *string) |
| uint32_t | mips_get_timer (void) |
| void | init_tlb (void) |
| void | resettlb (int i) |
