RTEMS 6.3
Board Support Package for `Generic' Motorola MC68360 */. More...
| int | rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| void | M360ExecuteRISC (uint16_t command) |
| void * | M360AllocateBufferDescriptors (int count) |
| void * | M360AllocateRiscTimers (int count) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| void | _Init68360 (void) |
| rtems_isr_entry | M68Kvec [] |
| char | M360DefaultWatchdogFeeder |
| int | m360_clock_rate |
/* Copyright (c) 1996 Eric Norum eric@.nosp@m.noru.nosp@m.m.ca
COPYRIGHT (c) 1989-1999. On-Line Applications Research Corporation (OAR).
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license/LICENSE.
